| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #17 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| It is a common mistake done by many people to shift to 5th gear as soon as possible. It takes more effort for the engine to pull the car in 5th gear at speeds less than 35 kmph than the 4th gear and hence consumes more fuel. This is the reason why we need to upshift after we attain a certain RPM. usually 2500 for petrol and 2000 for Diesel.
__________________ If you have not failed you have not tried enough. Swift Diesel VDI - Feb '07 onwards Santro LS- Mar '01-Feb '07(59000 KM) Sold. Last edited by DieselFan : 8th September 2007 at 23:39. |
| | #18 (permalink) | |
| BHPian Join Date: Jan 2005 Location: Bangalore
| Quote:
of course, if the car is driven at 2000 rpm in 1st gear, it consumes more fuel than in 2000 rpm in 5th gear - but only because the car moves slower, taking much longer to cover the same distance. i doubt that the engine would drink more fuel lugging the car at low speeds just because it lacks the torque at that rpm. but i need to know more about this - maybe i'm wrong about how it works.
__________________ Sometimes you're the windshield, sometimes you're the bug... Last edited by skandyhere : 9th September 2007 at 18:22. | |
| | #19 (permalink) | |
| Senior - BHPian | Quote:
__________________ Got Bhp? Team-Bhp.com | |
| | #20 (permalink) |
| Newbie Join Date: Aug 2007 Location: New Delhi
| Hi All, I want to know is it OK if i change to 1st gear when the speed drops below 10 ? Someone says that 1st should only be used when u start a vehicle which is stalled !! Please advice. I am a learner driver of Alto LXI !!! |
| | #21 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | can somebody post a chart for Indica Diesel V2....I mean for the BEST FE, after what speed once should change gears? It would be a help for people like me who dont have tachos in our cars.
__________________ Ford, Bullttt Te Raffle Dunaali Shaan hai Jattan dee.. |
| | #22 (permalink) | |
| Senior - BHPian Join Date: Jun 2007 Location: Chennai
| saurabh, all of the stuff we just said applies. It is not about speed, it is about circumstances. Quote:
If the engine is unable to propel the car because you are moving too slowly for the current gear, or if you release the clutch with the car in gear, but forget to release the brake, the engine will simply give up and stop. This is stalling. Just as you tend to take longer and slower strides (putting more power into each one) when you leave the flat and walk up a steep hill, so your engine needs you to change down. Let the sound of your engine, tell you when to change down, not the speedometer. Actually, the tachometer is a more appropriate tool, but get to rely on your car sense, not on needles: not all cards have all the gadgets, and if you need instruments to tell you when to change gear then you're not looking at the road enough! | |
| | #23 (permalink) |
| BHPian | Well put Thad. You would find most of the taxiwallahs changing to a higher gear as soon as possible. As if their aim in life is get the car off and switch to the top, and almost all of them drive on half-clutch, without realising that the engine would be severely underpowered. With practice one gets the hang of it and shifts by instinct with the engine noise as the guide. Conversely it is also important that one doesn't keep the lower gears engaged at higher speeds. I have seen a lot of new drivers do that. Maruti manual provides a driving chart for gear shifts, at least my '92 M800 manual has it. You could have a look and follow that till it comes automatically to you. |
| | #24 (permalink) |
| Newbie Join Date: Apr 2007 Location: Cochin, Kerala
| [COLOR=black]Guys. Thanks for the advice. All this time in my Accent 1.5 GLS, I used to up shift to 5th gear soon as the speed reaches 40. And yes, I do experience the jerk or shudder at times, which means I was lugging the engine, not good!! Just learnt that now.[/COLOR] [COLOR=black] But, back home I have my 6 month old Aveo 1.4, and the sales guy kept raving about VGIS and the ability to cruise at 25 km [FONT=Verdana]IN 5TH [/FONT]without jerking or anything. It actually did work but to climb back to speed at that gear from 25 kmph or so was difficult!! It felt like a good idea at first, like, it could be useful in slightly heavy traffic but after reading all this, I think it's a bad idea. [/COLOR] [COLOR=black] Anyone knows the best speed to shift gears in the Aveo 1.4. My Accent manual says it for the Accent but the Aveo doesn't.[/COLOR] [COLOR=black] So everyone has agreed that staying at top gear at less than optimal speed is [FONT=Verdana]NOT [/FONT]essentially the best way to increase the FE right?[/COLOR] |
| | #25 (permalink) | |
| Quote:
Forget about speeds to change gear at. They do not exist. Truly. Although I've noted whether various cars I've driven will run comfortably in higher gears in various city speed limits, I have never in my driving life changed gear by speed. You can check the tachometer needle for when to change down, if you must --- but still no need. If the engine is labouring, or not pulling then change down (you guys seem to call it lugging; do you say 'labouring' here? Do we mean the same thing? Indian/British English!) Listen to the engine and feel the car response. | |
| | #27 (permalink) |
| you may actually go by a single point agenda when you're thinking about when the change gear. just stay at the highest gear that will allow you to move the car comfortably without depressing the gas pedal too much. 'too much' should not be too much of a problem to determine, i hope - subjectivity notwithstanding. upshift if u hear your engine crying for its life and downshift if the car isn't responding well to the accelerator.
__________________ Sometimes you're the windshield, sometimes you're the bug... |
| | #28 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
The fuel consumption depends on the load, not rpm alone. | |
| Thread Tools | |
Similar Threads | ||||
| Changing gears without using the clutch | Lalvaz | Technical Stuff | 32 | 30th July 2008 13:19 |
| Vibrations in lower gears. | madhukar_n | Technical Stuff | 1 | 7th February 2008 20:37 |
| How to change gears | speedsatya | Technical Stuff | 114 | 7th July 2007 12:33 |
| What happened to M800 with 5 gears | vincentt | The Indian Car Scene!! | 24 | 7th September 2006 19:46 |
| Acceleration at low gears | zen-ith | Technical Stuff | 8 | 4th July 2006 21:57 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
