Thread Tools
Old 6th September 2007, 02:19   #1 (permalink)
Default Need help with my Zen
Hey Guys,
First of all i am so happy to have found this place. No other resource like this on the net for cars especially Indian.
I recently got my first car a 1998 Zen. Agreed its not much of a car but thats all that i could get with my first years payoff. I need help with the following.
1. Can i add on power steering and central locking.
2. How do i improve the AC cooling effect.
3. Can somebody find me a Zen user manual or something that will help me understand the underside of my car's bonnet.
Thanks a lot in advance
predator is offline   Reply With Quote
Old 6th September 2007, 08:58   #2 (permalink)
Hi Predator
Congrat's on buying your first car, my comments to your quires are below.
I don't think adding a power sterring is a good idea, first of all it's an expensive affair and it won't be as good as when it comes from the company, being a Zen you should be able to drive without power sterring as it is not too heavy on the hands, adding central locking is something you could try, it may cost you somewhere between 4-6k, but then again, weigh the pro's and con's as there expenses cannot be recovered when you sell the car. My advice would be to keep things as they are and instead spend the some money doing up the exteriors and some basic stuff like , changing the fulids, wheel bearing, chutch overhaul, suspension overhual, engine tuning, wheel balancing, these changes will make your car feel fantactic.
You may get a complete AC serviving done, should cost you around 2k if nothing is replaced, with coolent top up, the carb zen AC which I pretty sure is the one you have since it's a 98 model, insn't too powerful, so don't expect super cooling from the same, however a proper service will get it cool addiquetly.
Well, I can't help you with all the inside stuff, but here is my2 cents, inside the bonnet, it's basically a 1000cc engine generating 50 bhp. make sure there is adequte break fulid in the beak fluid contaner, coolent is toped up, check the colour of the engine oil, it is recommeded if you change it anyways if you have just bought it, also change the gear box oil.
Apart from the above the Zen is a real work horse and it will keep going, just try and change all the fulids once every 5k km's, and gear box oil every 15-20k km's, and don't try to add too many things to the car instead spend the money on getting the stock car at it's functional best.
Hope my comments help.
musicmanaman is offline   Reply With Quote
Old 6th September 2007, 11:40   #3 (permalink)
sushrutha's Avatar
@ predator. Fantastic car mate. You'll definetely enjoy the car if it's a well maintanied one.
I second musicmanaman suggestions/comments. U have rightly pointed out the issues. Adding power steering will be hole in the pocket for a 98 Zen.
PM me ur email id so that I can send you the owner's manual for carb - Zen
Happy driving
__________________
Honda City
Hyundai Santro
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 10th September 2007, 15:09   #4 (permalink)
I changed the air filters, cleaned the condenser and refilled the coolants. The Ac cooling is a lot better now. But i still have leaks on my windshield and a door panel. Gotta fix it and check the cooling after that.
Thanks a lot Sush for the manual. Gave me the all the basics i needed before getting my hands dirty.
Post that i have changed the timing belt, clutch assembly and the fuel pump. Next week will be for my engine...
Old 10th September 2007, 15:28   #5 (permalink)
Predator, Good to hear your Car's getting better, you may change the clutch assembly, however if its not necessary the don't change the timing belt and especially the fuel pump. I guess the fuel pump is working fine, otherwise the car would have not started in the first place.
What's the mileage you're getting with and without AC?
Old 10th September 2007, 17:13   #6 (permalink)
sushrutha's Avatar
Why was the timing belt changed ? Has your car run above 80,000 kms. If yes then ok.
Get an Engine flush / Carbon cleaning done.
__________________
Honda City
Hyundai Santro
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 11th September 2007, 15:57   #7 (permalink)
Yup My car has done about 84k now. Hence i put in a new timing belt.
About the fuel pump when i cold start the car makes a choking noise and goes dead sometimes. Feels like not enough fuel is being pumped in. Hence i though perhaps the fuel pump has to be changed.
My mileage is bad 10 kmpl with AC and 12 without AC. But considering the fact i driving wheel to wheel to traffic most of the time i guess its Ok. Any tips to increase my mileage are welcome.
Now my car has a new
Air filter
Fuel filter
Clutch assembly
brake pads
Old 11th September 2007, 17:23   #8 (permalink)
im_srini's Avatar
Predator, if you're seriously looking to 'discover' what's underneath your hood, simply email Maruti. The ContactUs link on the MarutiUdyog site is a good place to start. I know it's incredulous, but they do reply to your queries !
Two things you might be interested in are the parts catalog, & the service manual. I emailed Maruti & they promptly replied that these books can be ordered from their authorized dealers just like regular spare parts. I service with ABT, & on inquiry, was told that their office in Guindy-somewhere would be able to help me out with the catalog & manual
im_srini is offline   Reply With Quote
Old 12th September 2007, 09:04   #9 (permalink)
Predator, those mileage figures are not bad, I have a 99 carb Zen which now shows 52k on the odo (maybe tampered as I bought it second hand), get 8-9 kmpl in city with A/C, don't know the w/o AC figures as my AC is always on. The car is smooth to drive, the max I have driven is at 115-120 kmph, on a short open streach within the city.
The only area I have not yet attened is a carb overhaul, it was done 6k back, when I had just bought it, maybe this should increase the mileage.
Can any senior members thorw some light on how much a carb overhaul would cost for a Zen?
Keep updating us on how things are going with your zen.
Old 12th September 2007, 11:25   #10 (permalink)
sushrutha's Avatar
A carburettor overhaul should cost you around 600Rs. Get it done only by an authorized dealer.
@ predator
The mileage what you are getting is not at all bad considering the traffic situation.
Also get ur Spark plug cleaned/replaced
__________________
Honda City
Hyundai Santro
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 13th September 2007, 18:09   #11 (permalink)
Its nice to hear that my mileage is good. I forgot to mention that i just changed the spark plugs along with the other spares.
One of my friends told me that i should never drive with low fuel in the tank. Apparently sediments that come along with petrol always exists at the bottom of the tank and if i run it to the last litre all the time then these would end up inside my carb. Can someone throw more light on this.
Old 13th September 2007, 18:21   #12 (permalink)
Sideways's Avatar
Hi Predator, congrats on your first car. Have the cooling coil, which is located behind the dash board, cleaned. Airconditoning should improve a whole lot.
__________________
Form is Temporary, Class is Permanent.
Sideways is offline   Reply With Quote
Old 13th September 2007, 19:08   #13 (permalink)
Thats new too . First thing i changed when i got the car couple of months back. The coil itself had damaged linkages and hence i had to change it.
Thread Tools
Want to Convert My Zen to a Carbon/Steel ZEN bugatti_86 Modifications & Accessories 20 27th November 2008 01:16
S-Zen?(Swift engine in a Zen) raghuram.cg Modifications & Accessories 14 21st September 2008 11:52
Wanted: Maruti Zen vxi or Zen Carbon ollie Shifting gears 0 20th January 2007 11:32
No more ZEN for Zen Lovers abhibh The Indian Car Scene!! 65 8th May 2006 18:17
E-Zen & B-Zen.... MustangMan The Indian Car Scene!! 3 2nd July 2005 22:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
