Thread Tools
Old 12th September 2007, 17:44   #31 (permalink)
Rtech's Avatar
I wonder if it is actually carbon of lousy fuel gumming up??
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 12th September 2007, 18:05   #32 (permalink)
Yup, thats what Monkey called me up to say. He had a similar issue with bad fuel in his vRS.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 12th September 2007, 20:20   #33 (permalink)
shrivz's Avatar
Well, it was actually a smaller problem than I thought. No problem with the sensors or anything......there was carbon build-up on the throttle body.
I sent the Honda over to Arya Honda, since I am very happy with the service Shaman (same group) has given my Indigo. They cleant it up on the same day and car is back to smooth purring.
Thanks for all the help, guys!
Well, I got my throttle body cleaned a few days back, but the problem hasnt got solved!
But then again, it could probably be the fuel!
__________________
Don't part with your illusions. When they are gone you may still exist, but you have ceased to live.
Mark Twain
shrivz is offline   Reply With Quote
Old 12th September 2007, 20:30   #34 (permalink)
triggercool's Avatar
I had same problem with my Honda Vtec. Detected O2 sensor
triggercool is offline   Reply With Quote
Old 12th September 2007, 21:51   #35 (permalink)
veyron1's Avatar
Originally Posted by Rtech
Maybe they meant the same thing as mentioned here...dirty MAF sensor.
Don't you mean MAP? VTEC is N.A.
__________________
DAD
veyron1 is offline   Reply With Quote
Old 12th September 2007, 22:38   #36 (permalink)
chetanhanda's Avatar
You had mentioned you had noticed higher rpms upto 1500.
Definately this was due to excess air during idle, so the leakage of excess air was due to the Throttleplate being partially stuck open due to carbon deposits.
Right ? how else will RPM shoot up to 1500 without air leakage ?
just want to know exactly what happened ..Im curious..
chetanhanda is offline   Reply With Quote
Old 12th September 2007, 22:48   #37 (permalink)
Rtech's Avatar
Does a OHC use a MAF or MAP? Don't know. But what does it being NA have to do with it?
__________________
____
Old 12th September 2007, 22:53   #38 (permalink)
narayan's Avatar
Originally Posted by sushrutha View Post
I'm new to OHC.
Every morning when I start my OHC 1.3Exi , my car RPM needle raises till 1,300RPM and after 1 min or so it comes down to 750 -800 Rpm mark.
Is this normal ?
thats perfectly normal....
narayan is offline   Reply With Quote
Old 12th September 2007, 22:55   #39 (permalink)
narayan's Avatar
This had happened about two months back, but rectified itself automatically. However, since this morning, the problem has resurfaced.
At idling, the RPM keeps on shooting between 800 - 1500 rpm by itself. The car has completed around 52,000 kms and most of you know the minimal mods I have put on it. I didnt want to take a chance so just parked her back in the garage.
Whats up?
had the same problem after i replaced my O2 sensor...
got solved when the service guys checked all the connections and said there was a loose link - they fixed it - reset the battery and all was fine.....
in fact i had this problem even when going slowly in 1st gear and suddenly loss of RPM
Old 12th September 2007, 23:03   #40 (permalink)
definately Carbon buildup due to blowby, the EGR allows exhaust gas to flow thru the TB, and EGR gas becomes more damaging if the engine is not burning fuel perfectly
fuel wont be able to gum the Throttlebody,throttleplate or even the IACV.
There is no contact with the fuel... why are you having this doubt ? the injectors are further downstream...
Old 13th September 2007, 02:34   #41 (permalink)
veyron1's Avatar
MAF is for boost applications, dear Robeen...
MAP sensor is that tiny black sensor on the manifold tube. MAF is situated at the TB end for boosted cars...the big black thingy with the circlip..
Nevertheless. I still do not understand how a dirty TB would affect the idling. Perhaps a dirty checkvalve/Idle Air Control Valve, but....
@chetanhanda; A faulty Ignition Control Module would cause cylinder missing/misfire, which would show up throughout the rev range, na...not just idling, right...
__________________
DAD
Old 13th September 2007, 04:28   #42 (permalink)
Even NA cars have MAF sensors, where did you get this idea that NA cars have to be MAP , some stock cars even have Alpha-n ...You cant make a rule NA= MAP..
Exactly opposite of what u are saying : dirty IACV etc should create a low idle not a fast idle as it is not supplying enough air toidle at 800rpm
if ur Throttleplate is not closed completely due to some carbon crap , it will contribute to the air supply provided by the IACV...
nope, some misfires/missing are not detectable when revving higher, but more noticeable during idling.
Old 13th September 2007, 11:08   #43 (permalink)
Ford Rocam's Avatar
Originally Posted by chetanhanda View Post
Originally Posted by veyron1 (Problem with Vtec idling...varying RPM. EDIT : Solved!)
There is something like Throttle Position Sensor or (T.P.S), a variable resistor connected to butterfly of throttle plate, when throttle is closed it generates "x" voltage say for eg: 0.45V that value goes to ecu as throttle is closed & the engine should idle so it activates I.A.C valve to routine idling operations. If there is dust accumulated due to carbon buildup the throttle will not fully close & the T.P.S sensor will think as if throttle is slight open & o/p voltage will be different & ECU cuts off IAC valve since throttle is closed the engine doesnt gets enough air for idling & tries to die down, an abnormal state the ecu detects this abnormal condition & reactivates iac to keep engine running so engine is getting air from IAC & through small opening near t.b which is not fully closed causing weired idling.
This is also a common problem observed with people who have enlarged their T.B, if T.P.S is not calibrated properly for fully open/fully close to stock value of TPS volatge w.r.t stock T.B you will notice all kind of weird issues wrt idling & part throttle driving.
__________________
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
Ford Rocam is offline   Reply With Quote
Old 13th September 2007, 11:30   #44 (permalink)
Umm guys.......the revv limiter is not kicking in at 7100 rpm . And it isnt one single instance. I had three separate runs on the way to work this morning. She is revving upto 7400 rpm. I didnt have tarmac to take it further but even at 7400 rpm, the limiter didnt kick in. The first time it happened, I thought it was my mistake in reading the gauge. So I tried again, and yet again. The rpm is going uptil 7400 - 7500 and still the limiter is not kicking in.
Psycho says this is due to the ECM reset. Whatever it is, who is complaining ?
BTW, with reference to the idling problem....I spoke to the techie again and this is what he has done: Cleant sensors, cleant TB and reset ECM. It has to be one of these since the idling is butter smooth now.
__________________
Old 13th September 2007, 11:35   #45 (permalink)
Rtech's Avatar
My question as well Atul! What made you conclude that only forced induction vehicles would use a MAF sensor?
__________________
____
Thread Tools
Baleno altura high rpm at idling and malfunction indicator sukrit7 Technical Stuff 2 6th November 2008 12:14
Vibrations in Baleno at all times (Low varying Idle RPM) rohanmeets Technical Stuff 8 25th February 2008 11:36
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 11:19
High Idling RPM. What went wrong? saurabhkum Technical Stuff 8 25th October 2007 21:00
Fiesta engine jerks and rpm varies while idling tortoise Technical Stuff 16 13th March 2007 20:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
