| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #61 (permalink) | |
| BHPian Join Date: Mar 2005 Location: Minneapolis
| Quote:
| | #62 (permalink) | ||||
| Senior - BHPian | Quote:
Cedia- Haven't checked the 4G94. Nice to know that it has an MAF. Again, about alpha-n; okay, the Escort has an MAF. If it's running alpha-n, that's news to me as well. But I still do not get what alpha-n has to do here. Quote:
__________________ DAD Last edited by veyron1 : 14th September 2007 at 02:14. | ||||
| | #63 (permalink) | ||
| Quote:
veyron sir I know exactly what happens when engine is cold but thanks for the valuable inputs. we usually say the ecu is in open loop, choke mode is a new term for me... | ||
| | #65 (permalink) | |
| Quote:
15,16,17 = cc i.e 1600,1700 or 1500 cc thats why I call it D15 by mistake. I know its an asian model but plz remember it is very similar to a USDM D series. .. but I got ur point asian honda city is named differently but its not a totally diff type of engine... | |
| | #66 (permalink) | |
| BHPian Join Date: Mar 2006 Location: Bangalore
| Quote:
| | #67 (permalink) |
| Team-BHP Support ![]() | 4 days up and the car is still revving over 7100 rpm. Last I checked, the limiter kicked in at 7500 rpm ![]()
__________________ GTO Change the way you think, and watch the world change around you.
| | #68 (permalink) | |
| Quote:
You'll have a good time. You can pretend to be upset about the whole thing. These ASSs should get their due sometimes.Last edited by doomsday : 16th September 2007 at 19:48. | |
| | #69 (permalink) |
| BHPian Join Date: Jun 2007 Location: Mumbai
| My car Ikon 1.6 has RPM problem too. At stand-still, when I press & release throttle the RMP takes about 2 seconds to come back to idle. I take this to be normal. On the move, say 60-70 kmph, I release throttle, press clutch & put gear to neutral, the RMP stays high. It remains high even after long period. In neutral with clutch fully depressed I start decreasing speed, the RPM gradually lowers. It comes back to idle when I am stand-still or almost. Clutch seems okay as I can engage all gears effortlessly. Including reverse. Driving is quiet unpleasant in this condition as I am unable to use engine braking efficiently. Will appreciate any help. |
| | #70 (permalink) |
| BHPian | This is regarding the question posed by QuickSilver, I too have pondered the same. Isn't positioning the O2 sensor in a single cylinder's exhaust pipe a rather inaccurate way to measure stoichiometric ratio ? Or is the difference trivial enough to ignore ? |
| | #71 (permalink) |
| BHPian | I saw this higher idling problem in my cousin's 3 day old Maruti SX4. As soon as the car is started the rpm shoots to 12-1300. After a few seconds it settles around 800. Now that's ok. It's not such a big problem. But what is very irritating is that even while driving the rpm keeps shooting every time you press clutch to change gears. It is very irritating in city driving because after changing gear when you release clutch the car just jerks forward as though it would hit the rear bumper of the car ahead. Any idea where the problem lies. |
| | #72 (permalink) |
| BHPian Join Date: Sep 2005 Location: bangalore
| Few things that can help us all ![]() 1.Most cars with MAF also have a MAP sensor. 2. Idle Air Control still has a lot of work to do even when throttle goes from 0 to wherever. Thats where drivability comes in. 3. Rev limiter on almost all cars is based on time between reference signals ( cmp , ckp) and not on analog voltage 4. ECM resets cannot increase rev limit. |
| | #73 (permalink) | |
| Team-BHP Support ![]() | Quote:
| | #74 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
But i generally shift at 6900-7000 so it's not that big a deal for me. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #75 (permalink) | |
@ rdkarthik : How?
| Thread Tools | |
Similar Threads | ||||
| Baleno altura high rpm at idling and malfunction indicator | sukrit7 | Technical Stuff | 2 | 6th November 2008 12:14 |
| Vibrations in Baleno at all times (Low varying Idle RPM) | rohanmeets | Technical Stuff | 8 | 25th February 2008 11:36 |
| Idling problem in my WagonR Lxi..EDIT : Now solved. | ramki067 | Technical Stuff | 8 | 17th December 2007 11:19 |
| High Idling RPM. What went wrong? | saurabhkum | Technical Stuff | 8 | 25th October 2007 21:00 |
| Fiesta engine jerks and rpm varies while idling | tortoise | Technical Stuff | 16 | 13th March 2007 20:22 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
