Thread Tools
Old 10th September 2007, 11:19   #1 (permalink)
Super-Admin
Default Problem with Vtec idling...varying RPM. EDIT : Solved!
This had happened about two months back, but rectified itself automatically. However, since this morning, the problem has resurfaced.
At idling, the RPM keeps on shooting between 800 - 1500 rpm by itself. The car has completed around 52,000 kms and most of you know the minimal mods I have put on it. I didnt want to take a chance so just parked her back in the garage.
Whats up?
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 10th September 2007, 11:29   #2 (permalink)
iraghava's Avatar
Is this happening only with the A/C on?
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 10th September 2007, 11:31   #3 (permalink)
Team-BHP Moderator
Sounds like the air intake sensors are dirty. Honda will say replace and 16k whereas the part costs a lot less. You might get away with getting them cleaned for the short term
__________________
I love the whoosh, but i miss the bellowing
Old 10th September 2007, 11:36   #4 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
I'm least knowledgeable here to comment but as Ishan says, you may need to check your vacuum idle switch for AC. Also check if accelerator cable getting stuck.
Old 10th September 2007, 11:37   #5 (permalink)
Super-Admin
@ Iraghava : Dunno but will be able to check only in the evening now.
@ Ajmat : Anything to do with the K&N plumbing?
__________________
Old 10th September 2007, 11:38   #6 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
You mean to say air intake is correct but sensor acting funny?
Old 10th September 2007, 11:42   #7 (permalink)
Super-Admin
@ irags : Driver just checked. Problem is there even without air-con.
@ Rudra : No problem with accelerator cable.
__________________
Old 10th September 2007, 11:49   #8 (permalink)
rdkarthik's Avatar
Is the check light coming on?
Chk the O2 sensor, try to get a replacement from another car to test if possible. If thats okay then check MAP sensor - vacuum connection from manifold to sensor, broken/shorted wires, etc.
rdkarthik is offline   Reply With Quote
Old 10th September 2007, 11:54   #9 (permalink)
BUSA's Avatar
I think thats something to do with KnN, i have noticed with KnN the car revvs automatically sometimes, maybe drawing in more air.
__________________
thecarsandmore.blogspot. com
Old 10th September 2007, 11:56   #10 (permalink)
sushrutha's Avatar
I'm new to OHC.
Every morning when I start my OHC 1.3Exi , my car RPM needle raises till 1,300RPM and after 1 min or so it comes down to 750 -800 Rpm mark.
Is this normal ?
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 10th September 2007, 12:00   #11 (permalink)
Team-BHP Moderator
Jaggu's Avatar
check air leaks as well as air filter > clean the sensors (throttle body and O 2) > then move on to injector cleaning
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 10th September 2007, 12:02   #12 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Originally Posted by sushrutha View Post
I'm new to OHC.
Is this normal ?
normal.. for achieving optimum engine temp its devised
__________________
Old 10th September 2007, 12:03   #13 (permalink)
suren181's Avatar
Used to have this problem on a regular basis on my Santro. The solution for me was to change the petrol pump after removing the old petrol that was in the tank. Have been poring petrol from select pumps and ever since have not had this problem. Well, might not be the remedy but just my experience.
suren181 is offline   Reply With Quote
Old 10th September 2007, 12:18   #14 (permalink)
mclaren1885's Avatar
Even I am having the exact same problem and added to that my engine goes off everytime the needle comes below 1000 rpm. My car will be going in tomorrow to rectify this idling issue. Will keep this thread updated on what was carried on.
But by the looks of it could it be:
1. IAC valve malfunction?
2. TPS malfunction?
3. Vacuum leak?
4. Cam position sensor malfunction?
Karthik, in my case there is no check light & O2 sensor seems to be working fine. Because when I run with the O2 sensor disconnected I get really bad FE. And it betters by a lot when I connect it back.
__________________
I am proud of you, binzy boy !!! Keep up the good work.
Old 10th September 2007, 12:33   #15 (permalink)
I too developed this problem in my car after the throttle body was cleaned , it did somehow rectify itself ..
rchimni is offline   Reply With Quote
Thread Tools
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 10:19
High Idling RPM. What went wrong? saurabhkum Technical Stuff 8 25th October 2007 20:00
OHC trouble after engine flush. EDIT : Now Solved! ankitahuja Technical Stuff 56 22nd August 2007 16:21
Fiesta engine jerks and rpm varies while idling tortoise Technical Stuff 16 13th March 2007 19:22
Whats the mystery on bsmotoring.com? EDIT : Now SOLVED on page 3 Sahil The Indian Car Scene!! 40 1st September 2006 16:15
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
