Old 14th September 2007, 13:01   #16
Zappo's Avatar
Thanked: 2,079 Times
Ok prasana, since you could not find the thread we did it for you. You have already started getting responses now. Jaggu is a good guy to start with. I hope from now on you will follow up on this problem here.
EDIT: Jaggu, does the M800 has two separate fans for the radiator and the AC or does it make do with the same fan?
Zappo is offline   Reply With Quote
Old 14th September 2007, 13:04   #17
Default Hi Pls Help Me
No my radiator fan is working properly. I checked out the same too if thts the problem it could be ended up with boiling or overheating problem right.
prasana_19 is offline   Reply With Quote
My Yamaha R1 woes - Engine troubles EDIT - Now Resolved Rossiter Superbikes & Imports 42 16th July 2009 17:11
wiper arm troubles in new UVA rapidsnail Technical Stuff 3 31st May 2009 11:37
Ikonic Troubles wolfinstein Technical Stuff 18 27th June 2008 15:52
Xeta troubles: Faults and faultier! phamilyman Long-Term Ownership Reviews 14 13th September 2007 01:26
Hyundai India's troubles-Business Today Article; May 8, 2005 Revvmaster The Indian Car Scene 20 6th May 2005 09:50
