Old 12th September 2007, 16:39   #1
Knight Rider's Avatar
Thanked: 11 Times
Default Issues with Headers - Alto
Team,
Has anyone else done headers in a 3 cyl Alto? The Steel-Wool get's burned up really fast in my car, The result is an annoying sound to which is not really 'Music to ears' One solution that my installer has suggested is to go for a SS Expansion chamber and End-can,
What do you guys think the reason for this can be or do I have any other alternative other than going for the SS Chamber and end can?
All inputs would be valuable
Thanks in advance
Knight Rider is offline   Reply With Quote
Old 12th September 2007, 18:13   #2
n_aditya's Avatar
Thanked: 2,781 Times
Our Tbhp member, speedzak has headers on his alto.
Contact him for any clarifications.
I faced a similar issue in my car (esteem with 4x1 headers) where there was way too much flutter from the end can. Sounded more like an interstate bus. But i switched to a SS muffler and now... problem solved.
A SS muffler wont cost more than 5k and you get a lot of mugen, magnaflow replica's in the market.
Old 13th September 2007, 13:08   #3
Thanked: 11 Times
Hey thanks @n_adityaI had asked zak regarding this, and he also gave me the same reply, I cannot go for mugen or magnaflow replicas, It would look wierd on my alto, I already have an option for a custom SS muffler which is not as huge as the mugen or magnaflow replicas and expansion chamber,
However I wanted to know if there are any other options rather than this
Old 13th September 2007, 13:41   #4
Thanked: 17 Times
Hey! I did reply yesterday. But for some reason the post didn't appear here it seems. Posted from my phone.
I had Automech FFE installed in my Alto. It was mild steel one and it did last all the while till the car did. I didn't have to change the steel wool even once. And it was more than a year or so.
Could you please check if there is any leakages in your exhaust? Especially near the joints. Who did the installation for you? Did you speak to the people who made the headers for you?
Old 13th September 2007, 13:52   #5
Thanked: 11 Times
Thank you zakko, I got my headers done from Raj, , They suspect water seeping inside the expansion chamber and as a result the Glass-wool burns faster than it should so yes it can be a leak somewhere. Is there a simple way of checking it?
Advice was to go for a SS expansion chamber and a Muffler, I wanted to know if there is any other option available?
Old 13th September 2007, 14:03   #6
planet_rocker's Avatar
Thanked: 368 Times
A bit offtopic:
how long do the MS headers, pipes, expansion chamber last?
@ zak - the exhaust in your alto is back to stock?
planet_rocker is offline   Reply With Quote
Old 13th September 2007, 14:16   #7
Thanked: 17 Times
A very simple way of checking for leaks is to choke the engine. Yes! using some force, block the exhaust outlet while the engine is running. If it stops immediately, then there can't be a leak. If it carries on running (even if it is for sometime), or produces some leaking noises you can suspect a leak or two.
Oh my Alto! It is in a totalled state now! It had a BEEEG stunt and is almost beyond repair.
Old 13th September 2007, 14:49   #8
Thanked: 11 Times
Yeah, That is a very innovative way to check for leaks if any, Thanks Zakko,
I didnt know about your car, Sorry about that? Is it a Total loss? Are you planning to bring it back to life????
Planet rocker, As far as I know anywhere between 1-1 1/2 years, Again there are cases wherin the same has been used for 3 or 4 years without any issues, A lot depends on your driving style
Old 13th September 2007, 14:57   #9
Tapan
Posts: n/a
This type of problem exists in alto ? I have bought one just now and its weird to hear this.! :(
Thanks.
Old 13th September 2007, 15:59   #10
rishibravo's Avatar
Hey Tapan ... Trust me you dont have headers in your new alto.. So you dont worry about this... The day you get a Free Flow exhaust fitted in your car ,then you might need to visit this thread
Originally Posted by Tapan View Post
Thanks.
rishibravo is offline   Reply With Quote
Alto Issues jinojohnt Technical Stuff 741 15th March 2017 21:29
Issues With Alto Steering S.I.N.G.H Technical Stuff 9 24th January 2012 15:42
Alto LXI - 2700 kms and some issues travelwriter Test-Drives & Initial Ownership Reports 23 14th December 2011 11:17
Alto : Engine Oil Light stays on. And some other issues abhibh Technical Stuff 33 18th September 2011 22:07
