Thread Tools
Old 12th September 2007, 17:07   #1 (permalink)
kapilsharma80's Avatar
Default palio 1.2 nv 'pressure sensor error and water pump issue'
Lately theres a strange 'ktrr ktrr' sound coming from the car's engine. The frequency of sound increases with the the speed. its not loud and could only be heard when the bonnet is open. The temprature needle also touches the half mark when the car is neutral (this happens when i have done about 4-5 kms of driving) but comes back to 1/4th mark while in motion. Dont know whats happening.
I hope the pistons are alright.
The car has done 5 thousand kms. The car has been serviced once and the next service/oil change is due in december.
I took the car for a check up today.
the ecu analyser showed an 'intermittent error in the pressure sensor' , which the service guy deleted through the computer. I hope its not a seious problem.
The service guy said that the 'kkrr kkrr' sound is coming from the 'water pump'or a bearing connected to the timing belt.
They did not have both and ordered from mumbai. Will let you know once i visit the work shop next weekend.
your comments please!!
__________________
Drive your Desire!!
kapilsharma80 is offline   Reply With Quote
Old 15th September 2007, 09:27   #2 (permalink)
Kapil, if you could be a little clearer in your description of the problem, some people might try to help. Your first para is confusing, regarding the temperature.
The ECU showing 'error in PRESSURE sensor' with fault being temperature, etc.. is all too confusing.
The noise could be from some bearing (usually ball bearings are used) in the belt path - water pump, alternator, idler pulleys etc..
Perhaps that is why there is no response from anyone.......
And why on earth are you doubting your pistons?!
anupmathur is online now   Reply With Quote
Old 17th September 2007, 10:15   #3 (permalink)
Anup,
I will try to be clear this time.
Problem 1 -
The temp neddle touches the half way mark sometimes when the air conditioner is not on or switched off after usage. I recently topped up the the coolent also ('Puroguard manufactured by Anand').
When i park the car overnight or for long, the coolant marks on the pavement can be seen. the mark is 2 inch in diametre.
Problem 2 -
As i mentioned before, the ECU analyser showed an intermittent error in the pressure sensor. I have no clue as to what is the function of the pressure sensor.
Problem 3 -
There is a strange nose around the engine. the service guys pointed out that the fault is either with the water pump or a bearing.
__________________
Drive your Desire!!
Old 17th September 2007, 13:35   #4 (permalink)
rishibravo's Avatar
Firstly your coolant is leaking. Get it rectified. And hope its from the L-point and not from any of the waterplugs . The L-point leakage can be rectified in an hour or so but if its leaking from the waterplugs its half a days job coz they might have to down your gearbox.
Is the car under warrently. If it is then insist on getting the faulty parts replaced immediately. Clearing the error wont cause any problem . If there is a problem with the pressure sensor then the error will pop again.
__________________
Boyz will remain Boyz.......Only their Toyz change
rishibravo is offline   Reply With Quote
Old 17th September 2007, 15:44   #5 (permalink)
Rishi, thanks for the advice.
yes, the car is under warranty. Will go to the work shop in couple of days time and let you know the leak point.
Would you please point out as to what kind of problems can an error in pressure sensor cause!
__________________
Drive your Desire!!
Old 17th September 2007, 17:58   #6 (permalink)
Kapil, if your car is in warranty, do take a tough stand and have these issues sorted out. Fiat are not known for good service; expect to make a bit of a scene!
The coolant should not leak ONE DROP after overnight parking.
The noise from the engine MUST go.
The pressure sensor error would be hard to rectify till your car shows some 'symptoms'. If you can get them to show it again on the Analyzer, ask that the same test be done on another similar vehicle at the garage. If that one shows no error then you better insist that the concerned sensor be replaced in your car under warranty. And do WRITE COMMENTS on the delivery note after the service or repair call. This could come in handy later on if something turns out to be amiss.
Good luck and keep us posted.
Thread Tools
Wash cars under water pressure ? brraj The Indian Car Scene!! 71 22nd August 2008 21:18
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 43 24th February 2008 08:27
Palio 1.2 Nv pressure sensor problem kapilsharma80 Technical Stuff 0 21st September 2007 11:04
Fuel Pump Pressure valve cheatingdeath Technical Stuff 1 27th November 2004 11:05
Accords Fuel pump pressure regulatory valve cheatingdeath Technical Stuff 2 8th June 2004 11:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
