Old 14th September 2007, 13:36   #1
Default Suspension problem in 97'ZEn
Hi team - bhp ians ,
I am facing this suspension prob in my 97' zen which i bought it Second-hand hand just 20 days back , it has clocked 61k kms , this prob started ever since i went over 3 Speed Bumpers @ 60 km/hr in B'lore .
The problem is like the front wheel is rubbing against something , and it can be heard inside the car .
I also get a sound like some balss cracking when i move the car in 1st gear .
I think the Ball joint is completely weared-out.
I thought it was a wheel aligment problem and so did a Wheel Alignment at LAL's Chennai
Even after doing that i am facing the same prob . Now a new prob has come up .
I get queek-queek Noise when i go over the pathholes .
I think the Lower Arm and the Dampeners should be changed or is this the prob wid Struts ? I dont know whether the provios owner had changed the suspension ,.
BHP-ians plz advice me on this ,and wher to get it fixed ?
wolverinchandru is offline   Reply With Quote
Old 14th September 2007, 19:10   #2
Thanked: 253 Times
Your best bet would be to go to a Maruti authorized service station, discuss with them and decide what you want to have done, depending on how much you are willing to spend.
Good Luck.
Old 18th September 2007, 11:24   #3
Thanks for the suggestion . Any more Suggestions from the other T- Bhpians ???
Old 18th September 2007, 11:43   #4
Jaggu's Avatar
Thanked: 8,671 Times
For around 6k you can have a complete overhaul for zen suspension, replace the lower arm, tie end, bushes also the strut bush kit (if your struts are fine).
Get axles checked and if necessary replaces, and you will have a trouble free experience with the car.
Its always advised to do a complete overhaul job with a second hand buy to avoid unpleasant surprises.
Suspension overhaul for Zen skidrock Technical Stuff 18 16th December 2015 11:55
Suspension Upgrade on Zen Handling nice blueraven316 Modifications & Accessories 15 7th July 2010 02:30
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Suspension upgrades for Zen. speedsatya Modifications & Accessories 0 30th May 2005 23:05
carb zen suspension options? heavy_foot Technical Stuff 14 15th May 2005 11:59
