Old 15th September 2007, 11:13   #1
Exclamation Smoke from brand new Fiesta
On the first day of driving my brand new Fiesta 1.4 ZXi Petrol (in very heavy rain) I noticed smoke coming from the hood. This happened for a short distance (about 100 mts). I stopped and started the car again and the problem "went away". From the inside, everything seemed normal. I did not smell anything odd.
Was it something due to the heavy rain? Is there something I can check to see if everything is fine?
calvinkrishy is offline   Reply With Quote
Old 15th September 2007, 11:25   #2
vkochar's Avatar
Thanked: 219 Times
At times Smoke does come out - little bit from the bonet or AC Vents ( Its not smoke really ) - this happens in very heay rains.
I am not a technical person so cannot explain why ( BUT it does happen ), maybe some one here would be able to explain you the exact reason of this SMOKE ..
vkochar is offline   Reply With Quote
Old 15th September 2007, 11:33   #3
Hi! This is normal I guess. The smoke you're talking about is white right? If yes, its just the rainwater touching the radiator when it's hot, so nothing to worry about.
cya
A
Absar is offline   Reply With Quote
Old 15th September 2007, 11:51   #4
akash_m's Avatar
Thanked: 88 Times
Default Completely normal
Actually, its not the smoke but water droplets evaporating on the hot bonnet. Try this phenomenon any day when you get back home after a drive by spraying water on the bonnet. You can see the water vapour!
I had experienced this many times!
akash_m is offline   Reply With Quote
Old 15th September 2007, 11:53   #5
panky12345's Avatar
Thanked: 150 Times
Yes, very true Absar.... water droplets go over a hot engine and it evapoartes rapidly, nothing else.
Old 15th September 2007, 12:02   #6
Thanked: 253 Times
Could also be 'steam' formed with water spraying on to the hot exhaust piping in way of the engine bay.
The fact that there was no odd smell only reinforces the guess that it was all steam/water vapour.
Nothing to worry about.
anupmathur is online now   Reply With Quote
Old 16th September 2007, 00:08   #7
Pankaj401's Avatar
The workshops use oil to shine up the engine bay ( new car as well as during service ). When the engine gets hot it burns/vapourizes that oil which is seen emanating from under the hood.
Pankaj401 is offline   Reply With Quote
Old 16th September 2007, 10:53   #8
DieselFan's Avatar
Thanked: 234 Times
No workshop worth its salt would do this. definitely not a A.S.S. with a new car - never.
DieselFan is offline   Reply With Quote
Old 16th September 2007, 12:46   #9
Jaggu's Avatar
Thanked: 8,693 Times
a) it can be water spilling on to hot engine parts,pipes, radiator etc
b) can be the diesel which the service guy sprayed evaporating
c) ac condensation will show up inside the cabin not outside
If you dont find any burning smell, ignore for now.
Old 16th September 2007, 13:12   #10
deepaktpatil's Avatar
Thanked: 93 Times
must be water vapor and you may have observed it at low speeds. At higher speeds you wont be able to observe it because of the wind.
deepaktpatil is offline   Reply With Quote
Old 6th May 2011, 15:58   #11
Thanked: 55 Times
Default Re: Smoke from brand new Fiesta
Spraying diesel on to the engine is a common practice at most A.S.Ss.
I have seen them do it at Mahindra as well as Maruto A.S.Ss.
ff1609 is offline   Reply With Quote
Brand New Fiesta refuses to start! anachronix Technical Stuff 50 13th November 2009 19:58
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Which brand do you smoke?? Sam Shifting gears 151 15th November 2008 16:28
Brand New FIESTA Pulls like a TVS Moped on Test Drive!! DileepKS Street Experiences 30 30th July 2007 10:42
Brand New Fiesta With 850 Kms On ODO!! 1self The Indian Car Scene 26 25th October 2006 22:46
