Thread Tools
Old 17th September 2007, 13:28   #1 (permalink)
Default Santro Problem
When I break my car @ 80Kph, my steering wheel starts shaking !
At lower speeds this problem is not present. Can somebody tell
me whats wrong. Do I need wheel balancing/alignment ?
nd81 is offline   Reply With Quote
Old 17th September 2007, 15:59   #2 (permalink)
rohan_fonseca's Avatar
looks like you are due for balancing/allignment.
rohan_fonseca is online now   Reply With Quote
Old 17th September 2007, 16:50   #3 (permalink)
Incase your tyres are in a good condition and evenly wornout, then pls. get them rebalanced and aligned at a reputed tyre workshop
autoenthusiast is offline   Reply With Quote
Old 17th September 2007, 17:00   #4 (permalink)
iraghava's Avatar
You need to get your wheels balanced. This can be done at any reputed tyre shop.
__________________
Until you've lost your reputation, you never realize what a burden it was.
Old 17th September 2007, 17:02   #5 (permalink)
extreme_torque's Avatar
@guys.. the vibration comes when breaking at speeds of 80 kmph, I dont think its an issue with the alignment.
Get you brake disc and brake pads checked (front and rear both).
extreme_torque is offline   Reply With Quote
Old 17th September 2007, 17:41   #6 (permalink)
DieselFan's Avatar
Some Santros have the Brake pads issue. Mine had it too. Get the same checked by your A.S.S.
__________________
If you have not failed you have not tried enough.
Swift Diesel VDI - Feb '07 onwards
Santro LS- Mar '01-Feb '07(59000 KM) Sold.
DieselFan is offline   Reply With Quote
Old 17th September 2007, 17:48   #7 (permalink)
iraghava's Avatar
Oh sorry, didn't read the query properly. You have what is called "Brake Judder" which means that when braking from speeds, your steering starts vibrating. I had this problem in my Santro too.
Solution is to go to the Hyundai guys, demonstrate to them the problem & ask them to change the clean the discs & pads & see if that solves the problem otherwise ask them to replace the discs under warranty (if the car is still covered by it that is).
__________________
Old 17th September 2007, 17:54   #8 (permalink)
ND81 ,, get the Balancing done .. thats all the u r set to Rock n Roll,,
nicejits is offline   Reply With Quote
Old 17th September 2007, 18:02   #9 (permalink)
aditya.86's Avatar
just check the allignment and do the balancing and if necessary do tyre rotation also.guess your problem will be solved
aditya.86 is offline   Reply With Quote
Old 18th September 2007, 01:10   #10 (permalink)
Oops did not read about the braking part! Get the brakes checked, check the wear on the brake rotors and a visit to tyre to check for uneven tyre wear will not be a bad idea as well.
Old 18th September 2007, 08:04   #11 (permalink)
Looks like wheel balancing and brake rotor problem. Your brake pads must have worn out and the rotor is slipping out hence the vibration. Had the same problem in my SANTRO solved by replacing brake pads and balancing / alignment under warranty.
Lifewater is offline   Reply With Quote
Old 18th September 2007, 09:59   #12 (permalink)
I too had this problem in my Santro (7+ years old). The problem is because of uneven wear of discs. So when you brake hard, bake pads tends to catch the uneven surface of the disc and passes it to steering wheel.
Try getting the discs polished or abraded to bring them in order. After getting brake discs treated, the steering vibration problem in my car is addressed to some extent but it seems I may have to get the discs changed in next couple of thousand KMs. Disc polishing/abrading can only be done to a certain extent only as brake discs have to be of certain minimum thickness otherwise brake pads would not hold them well and may even come loose (affecting braking drastically), which may lead to a disaster.
__________________
Pedal_To_Metal
ms_rana is offline   Reply With Quote
Old 18th September 2007, 13:04   #13 (permalink)
I did a services recently and the guys cleaned the brake pads. I think
an balancing/aligment should fix the issue.
Old 24th September 2007, 10:09   #14 (permalink)
ok I did an wheel rotation,balacing and aligment, but no
luck. I guess its something to do with the brakes..becos
when I press them, then the steering starts shaking...also this happens only on speeds above 50kmph.
Thread Tools
Wiper problem in Santro subhojitb Technical Stuff 13 25th October 2008 08:59
Sudden FE problem in Santro coolmob Technical Stuff 4 20th July 2008 01:48
Santro A/c problem kalaks2000 Technical Stuff 18 15th December 2007 12:18
FM reception problem in Santro kousikorama Ask the Gurus 4 9th July 2007 15:05
Streeing problem in Santro. F1amit Technical Stuff 4 16th January 2007 23:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
