| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: May 2007 Location: Pune
| hi, I am a new car user. so I will try to put my question in the best possible way. I use a Zen which is around 9 yrs old. Living in Pune, with cluttered roads and being quite used to commuting on my bike, I rarely get a chance to drive the car. Usually it is on the weekends. Also interms of fuel expenses this suits me. So my car is parked for prolonged periods.. say 5-6 days at strech. But whenever I get a chance, I start the ignition and let the engine idle for a while. yesterday (after about 2 weeks of rest) when I tried to start the car, I found that is started well in the first instance. I let it idle for 30sec or so. Then I turned off the key. Then when I tried to start the car, it would not start. Also When I turn ON the key, there is a gradual decrease in the frequency of sound from something revolving(that of crank???) I got the battery charged just about a 4 weeks ago. So I dont think it is the battery. The make of the battery is Sonic (is it good or bad??) Looks like I might have to jump start the car. I would like to know if something else can be done. I want to get my hands dirty so that I can learn. Also if there can be any precaution taken so that this incident doesnt repeat. Thanks |
| | #2 (permalink) |
| BHPian Join Date: Nov 2006 Location: kolkata
| Rockrider, I think you should check the fuel pump, also it is advisable to drive the car for alteast 20-30 in a week, if possible at a streach for things to remain good, the more the car runs the fitter it remains. |
| | #3 (permalink) |
| BHPian Join Date: Sep 2007 Location: Chennai
| The gradual decrease in the cranking points to only the battery. Like #MusicManaman points out, driving the car is better than resting it. You will start developing other sort of problems like Dried up machine parts (due to insufficient lubrication as oil does not move around) Dried up oil (dust and grime and settled oil making it useless for lubrication) Gooey fuel (our fuel is not the purest and you will find that petrol will start separating into layers with gooey stuff in the bottom) All of these will start screwing up other parts of the vehicle. Unfortunately only the battery will show the first signs and the rest of the vehicle will show signs only after much damage is done. If you really do not find use for the car for more than once a week, sell it and use an auto/cab. Finally, IDLING DOES NOT CHARGE A BATTERY. IDLING CONSUMES BATTERY. The popular misconception is that the battery starts charging as soon as the engine starts turning. No, that is not the case. Apparently, the battery charging voltage is reached only after the engine RPMS rise more than idling speeds and at idling speeds (a) The battery does not get charged (b)if your idling is very low , the battery supplements the dynamo to make the spark plugs work. So, next time you try to charge it, press the accelerator down a bit or best take her out for a spin. |
| | #5 (permalink) | |
| Senior - BHPian | Quote:
@rockrider... ithink you need to ride that car of yours a little bit. Just take it for a 3km ride everyday (at least) specially since it is an old car.
__________________ R.I.P Islero | |
| | #6 (permalink) |
| I am still not conviced that it is the battery. The reason is that all the electricals are functioning well. The headlights, indicators, horn and even the stereo. Do these equipment run at with low battery as well? If that is the case, then I will take the battery to the service station. Also it hasnt been too long since I got the batter checked. And yes, got the lesson. Venkatesh, thanks for listing the possible damages. And I agree with each one you guys. I Will take better care of the car. |
| | #7 (permalink) |
| Thanks for your valuable inputs. Thanks Venkatesh for pointing out the possible damages. I will take care of these things in future. Will take my car for a spin regularly. I am still not convinced that it is a battery problem That is because it has been less than a month that I got the battery recharged. All the electricals are functioning fine. Checked the headlight, Indicators, music system and horn. The battery indicator is on. is it possible that these electricals work even when the battery is down (with the engine off)? If yes, then I will take the batter to the service station. Thanks again for your suggestions. |
| | #8 (permalink) | |
EL is right! Im sure u haven't checked with a multimeter. Anyways, I like the confidence U show although what U say is wrong.
__________________ youtube.com/watch?v=FiVicNOA3bY | |
| | #10 (permalink) |
| OK. Thanks EL and @Nitrous, I stand corrected. Obviously you guys know and do this better. I was not myself very very sure and thats why i had put in an 'Apparently' in my original post. - No more defences. and no, i have not checked with a multimeter. Guilty as charged. Does the alternator always charge at idle for all cars? No exceptions? Does it then mean that the alternator generates more current /voltage than is demanded by all the sparkies that it can supply leftover to the battery for charging? Thanks folks for the corrections. Passing on incorrect info is worser than not passing any. I will take care in future |
| | #11 (permalink) | |
| BHPian | Quote:
take your car for a short spin,.. after all, anything unused will rot ![]()
__________________ ...looking forward to sit a few feet above mean road level and away from potholes... | |
| | #13 (permalink) | |
| Quote:
please ignore my multiple posts. As I am newbie my post are being moderated and they dont appear for a while. and when they appear, I cant delete em. ![]() | |
| | #14 (permalink) | |
| | #15 (permalink) |
| Rockrider, a good idea would be to push the car and see if it starts, if it does start then take it for a 10-15 km drive, but make sure you don't turn the car off when away from home (you may get stranded), turn the car off when back home and see if the car starts again, if the battery and alternator are fine, then the battery should get charged by this streach of a drive and if the car does not start even after pushing, then the problem may not be the battery and may lie else where. |
| Thread Tools | |
Similar Threads | ||||
| Santro fails me in middle of desert | LLL | Long-Term Ownership Reviews | 12 | 12th June 2008 14:58 |
| 3-day old Avenger 200 fails to start !! | VSG12777 | Motorbikes | 19 | 2nd April 2008 09:40 |
| Maruti Estilo fails to live up to expectations??? | rahul_intlad | The Indian Car Scene!! | 99 | 27th July 2007 09:49 |
| What to do when Power window fails? | mail4ajo | Technical Stuff | 22 | 17th January 2007 10:49 |
| Bentley fails homologation test | ajmat | The Indian Car Scene!! | 9 | 8th April 2004 04:41 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
