Thread Tools
Old 18th September 2007, 09:55   #1 (permalink)
Amey's Avatar
Default Turbo in Octavia 1.9TDi
Hi guys,
I wanted to get this query solved for some time now.
Pardon me if this query is too noobish
Ok here it goes,
It is a known fact that the Octavia 1.9TDi comes with a Turbo, now as far as my knowledge goes, there is a turbo lag in any turbo fitted car.
For example in the Swift Diesel, the car shoots after 2k RPM, i assume this is where the turbo kicks in.
Now i have had the Octy for over 2.5 Yrs now and how much ever i have tried, i have failed to recognize when the turbo kicks in.
So my question is simple, When does the Turbo in the Octy Kick in [@ what RPM] and i don't know if its just me but why don't i feel it kick in as in the swift ?
Amey
Amey is offline   Reply With Quote
Old 18th September 2007, 10:21   #2 (permalink)
The absence of turbo-lag shows how well-matched and engineered that turbo-diesel is! The fact that its a smaller turbo also helps in reducing lag. If I remember correctly, it kicks in around 1700 rpm.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 18th September 2007, 10:31   #3 (permalink)
Amey's Avatar
1700 RPM, thats nice.
It surely is a well engineered car, no wonder its fun to drive even though its non CRDi and is a simple Direct Injection Diesel Motor.
@ GTO, would like to know more about - 'Smaller Turbo"
Old 18th September 2007, 14:45   #4 (permalink)
nitrous's Avatar
Amey, when the turbo is smaller in size, there is very little lag.
Downside of a small turbo is it produces lesser boost than a bigger turbo.
__________________
Speed thrills. But kills. If you ain't got skills!
nitrous is online now   Reply With Quote
Old 18th September 2007, 15:13   #5 (permalink)
Little lag in smaller turbo so you will not recognize the turbo lag.
In Impreza turbo lag starts at 2k and turbo kicks in after 4k.
Mugen_Power is offline   Reply With Quote
Old 18th September 2007, 15:59   #6 (permalink)
shazikon's Avatar
lag starts at 2k ? mind explaining?
__________________
Cheers,
shaz
shazikon is offline   Reply With Quote
Old 18th September 2007, 18:21   #7 (permalink)
Originally Posted by shazikon
lag starts at 2k ? mind explaining? __________________
I guess he means at 2K rpm there is a distinct lack of performance which lasts until 4K rpm when you feel the turbo kick in.
That is why now, many manufacturers (BMW in the 525d) are using two turbos...
A smaller one for low RPMs and a larger one for higher rpms. This more or less eliminates Turbo Lag and you get good performance even at higher rpms.
Another way is the method Porsche is following. VGT or Variable Geometry turbine.
Here, the geometry of the vanes of the turbine change depending on the rpm to give maximum performance.
Old 18th September 2007, 18:28   #8 (permalink)
Amey's Avatar
Thanks for clarifying my doubts
Any scope of adding a bigger turbo ?
Old 18th September 2007, 18:37   #9 (permalink)
It wont help in your car.... the engine capacity itself is just 1900cc.
It would be better if you get a Pete's tuning box....
Old 18th September 2007, 18:41   #10 (permalink)
shuvd's Avatar
Or, the Custom Code remap. IIRC, a Delhi member got it done.
__________________
I (still) feel the need...the NEED for SPEED
shuvd is offline   Reply With Quote
Thread Tools
Additional Lights for Skoda Octavia 1.9TDi arunjohnpaul Modifications & Accessories 16 15th November 2008 15:10
225/R16 tires for octavia 1.9tdi arunjohnpaul Tyre & Alloy wheel Section 9 28th August 2008 20:18
Remapped Skoda Octavia 1.9TDi Ricky_63 Modifications & Accessories 110 18th March 2008 13:50
Skoda Octavia 1.9Tdi Rtech Long-Term Ownership Reviews 49 7th May 2005 21:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
