Thread Tools
Old 18th September 2007, 14:39   #1 (permalink)
VC12's Avatar
Exclamation Servicing car as per the kms listed by Car maker?
I own a Ford Ikon flair 2006 and my running is very less only in City with office quiet close to my place and I keep travelling every fortnight out on Business travel.
Considering this, my car is natrually does less kms around 6000+ since 2006 May.
I seeking clarifications, is it a must to get the car serviced as per no Kms it reaches or by or by the time( months/yrs)?
If its by the time, can some one explain what are those vital apescts which needs the car to be serviced.
I noticed during one of the service visit, the engine oil is not dark or thick, but the service folks insisted to change and so I have got it changed.
Pls. share your thoughts here.
__________________
VC 12=>>>
VC12 is offline   Reply With Quote
Old 18th September 2007, 15:09   #2 (permalink)
One should stick to the number of KM's run for your routine servicing, like tuning, wheel balancing, tyre rotation but in your case since your overall running is too low. You should get an oil change done half yearly, since oil viscosity increase over time (even if not used) and therefore needs a change.
I suggest you should get a complete servicing done every 6 months, irrespective of you running under these circumstances.
Originally Posted by VC12 View Post
Old 18th September 2007, 15:20   #3 (permalink)
VC12's Avatar
Thank you Dadu,
Let me know any specific check list I need to ensure while get the service done.
In terms of oil change , which oils( brake, engine, clutch, power streeing.. etc) are vital to be changed?
__________________
VC 12=>>>
Old 18th September 2007, 15:36   #4 (permalink)
kapilsharma80's Avatar
Get your engine oil changed as suggested by dadu.
Keep a regular check on the levels of the following:
  1. Powe steering oil
  2. brake oil
  3. coolant
The service checklist would be given in your car's service book.
The checklist is usually printed at the back of service slips.
You can also request the service centre to give you a one sheeter (service checlist), which they use.
__________________
Drive your Desire!!
kapilsharma80 is offline   Reply With Quote
Old 18th September 2007, 23:41   #5 (permalink)
Team-BHP Moderator
Jaggu's Avatar
stick to service intervals, in your case months. with your kind of running periodic check up every 6 months is fine, instruct service guys to do a overall check up instead of routine repair and replace job.
routine check list is available with all manufacturer, follow that and then decide if any job is required, will cost you 600 to 800 bucks max (each visit) between 10 k kms marks. once you reach 10k km mark, do the prescribed service for that interval.
unless you demand, they will follow the clock work procedure of doing 10k service (iKON) on each visit.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 30th September 2007, 05:22   #6 (permalink)
memo45_m's Avatar
I seeking clarifications, is it a must to get the car serviced as per no Kms it reaches by or by the time( months/yrs)?
PLEASE Follow what the owner's manual or service guide supplied with the car, AS the manufacturer RECOMMENDS.... The guys who compile these documents are Automotive Engineers and Aotomotive Technicians with at least 15 years of experience under them in this field......
If its by the time, can some one explain what are those vital aspects which needs the car to be serviced.
Remember there will be the THREE free service and then the paid service coupons, it will be mentioned on that.(it is a set rule, that the info should be given.)
Ya oil by its nature will not turn bad, but the additives that are added in the Oil during manufacturing tend to do the harm over time, specially you will have a lot of waxing over the valves, in the valve stems, in the ring groves, bearing gaps and that wax will spoil the flow to and from the oilfilter (causing something called dry starts, which will REALLY hurt the engine). So its better to change oil if your not using the car a lot, by the time schedule mentioned by the manufacturer.
__________________
I am NEVER a BAD Infulence, just a GOOD Example....!!
memo45_m is offline   Reply With Quote
Old 3rd October 2007, 10:58   #7 (permalink)
VC12's Avatar
Thanks Memo,
I intend to get in new oils as prescribed in service check list...
I dod agree even the oil appear neat but it vicosity levels may vary and hence the works manager suggeste dto keep this changed as well.
Cheers!!!
__________________
VC 12=>>>
Thread Tools
Maruti to shed low-cost small car maker image ashutoshb The Indian Car Scene!! 4 23rd December 2007 19:28
Toyota becomes world's biggest car maker rahul_intlad The International Automotive Scene 36 9th June 2007 12:09
India's People car maker amit The Indian Car Scene!! 17 28th December 2006 15:56
Renault Saved Japan's Second Largest car maker devarshi84 The International Automotive Scene 3 12th February 2006 09:21
Which is the most knowledgable car maker when it comes to Service in modern cars DRC The Indian Car Scene!! 11 3rd January 2006 13:08
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
