Old 18th September 2007, 20:20   #1
chetanhanda's Avatar
Thanked: 42 Times
Default Power valves - What are they / how do they work?
Guys, Im a little confused with this terminology "Power valves"
I came across this in one of the posts in TBHP by Veyron1...
I used to think it was something to do with bikes and 2 strokes etc.
Can anyone can provide more info,links etc what this is and where is it used in cars ? I tried google but it kept showing me stuff related to bikes etc but nothing related to cars.
Is it something too exotic and found only in "concept" engines?
chetanhanda is offline   Reply With Quote
Old 18th September 2007, 21:05   #2
crazydiablo's Avatar
Thanked: 21 Times
yamaha patented tech is power valve.
crazydiablo is offline   Reply With Quote
Old 18th September 2007, 22:16   #3
Thanked: 3,507 Times
It is a round cylindrical device which sits just outside the exhaust port of a power valve equipped two stroke motor. This device will alter the exhaust port timings in accordance with the rpm of the motor. At low rpm the exhaust port is partially closed to provide good low end torque and as the rpm increases the power valve opens up the exhaust port and thus allowing the engine to revv higher and make more power at the top end. The movement of the power valve is controlled electronically using a servo motor which gets the signal from the ignition module.
Kawasaki, Suzuki and Honda also tried their bit with the power valve system but they call it using different names.
Old 18th September 2007, 22:16   #4
Thanked: 42 Times
Thanks , in short you mean its got nothing do with "cars"
I was told it is found in VGT or very high end turbocharged engines..like the ones found in WRC and they are located between the intake runner and the TB's to regulate boost etc...I really dont know.
hmm..thats why I was so confused - never heard of it in cars.
dude so you are sure its got definately nothing to do with cars and the intake system, like used for regulating boost in between the TB and the intake runner..?
Hey Veyron1, your comments ? Im sure Veyron1 is trying to take me for a ride on this WRC "power valve"
Last edited by Rehaan : 9th June 2009 at 20:03. Reason: Old posts, but merged nonetheless.
Old 18th September 2007, 23:39   #5
veyron1's Avatar
Thanked: 37 Times
No, chetan. Not trying to take anybody for any ride on any "WRC" cars. Perhaps I'm not aware of the exact technical term for the device. I shall try to get the exact jargon for you, as you'd like.
Clear you inbox, pal. Tried to PM you.
veyron1 is offline   Reply With Quote
Old 30th September 2007, 14:29   #6
Thanked: 42 Times
Inbox cleared ... please PM
Old 11th October 2007, 00:59   #7
nitroxx's Avatar
Thanked: 26 Times
Document Abstract: this should tell you something chetan and its also termed as as sleeve valve i believe not sure though,read on ...2-stroke power valve system - Wikipedia, the free encyclopedia
Sleeve valve - Wikipedia, the free encyclopedia
nitroxx is offline   Reply With Quote
Old 11th October 2007, 01:20   #8
nitroxx's Avatar
Thanked: 26 Times
you know what forget what i said this should do the trick actually
Carburetor Valve Problems - Tech Article - Chevy High Performance Magazine
Old 11th October 2007, 02:17   #9
Thanked: 42 Times
Hey thanks Nitroxx .. this is what I was waiting for
Seems power valves is not something which is NOT found exclusively in very exotic engines, its even found in regular low end econo boxes too.
I just saw the link , dude this is for carb based fuelling systems, I was looking for only FI systems..thanks
Last edited by Rehaan : 9th June 2009 at 20:07. Reason: Old posts, but merged nonetheless.
Old 11th October 2007, 02:54   #10
nitroxx's Avatar
Thanked: 26 Times
a found a couple of links to forum posts about a few nissan engines running them and stuff thats all...
Old 9th June 2009, 16:51   #11
Mr_Bean's Avatar
Thanked: 128 Times
There is a power valve associated with the carbs, I recently got it replaced on my esteem.
Mr_Bean is online now   Reply With Quote
Premier Padmini S1 : Valves leaking. Suggestions needed urgently !! kavesh55 Technical Stuff 2 17th April 2008 09:30
Palio 1.1 to get 16 valves & 1.3 MJD by end of year BUSA The Indian Car Scene 58 31st March 2008 00:43
2 valves per cylinders devsus Motorbikes 4 17th April 2006 16:59
need reed valves sanket12 Shifting gears 0 26th June 2005 09:36
Valves and bits, what's this ? DueLLeR Technical Stuff 2 27th May 2005 14:41
