Old 19th September 2007, 12:44   #1
payam's Avatar
Default Help!!my car is getting sunk
Yesterday when i drove the car after 3,4 days i noticed some strange noise in it.
It sounds like car is carrying a river inside,first it was only driver door but today i saw it is same in all the doors.
Due to heavy rain in these days in pune i suppose water is gatherd in the doors.
I ask kiran by phone yesterday he said there must a crack on your car but now it is all the four doors.
Guys what is this,what should i do?what cant it do to my car??
payam is offline   Reply With Quote
Old 19th September 2007, 12:54   #2
moralfibre's Avatar
Thanked: 6,532 Times
God I didn't mean a crack!! Do one thing, on each of the 4 doors in your Palio (Built like a water tank now), there is a rubber plug. Pull that out from all doors and water should drain out. If you can't then wait till evening and I'll do it for you. If it is in the running board then its difficult.
Old 19th September 2007, 13:11   #3
esteem_lover's Avatar
Thanked: 451 Times
I think someone else had a similar problem with their palio as well. Damn my old attic, i can't remember right.
Old 19th September 2007, 13:18   #4
swale84's Avatar
Water collecting in the doors is a petty common problem with the Zen as well. Some times what happens is, the drain holes get clogged with leaves, twigs etc. As a stop - gap method you can try and clear the hole with a screwdriver or any pointy object. Next time you give your car for servicing, ask the them to clean the doors from the inside.
swale84 is offline   Reply With Quote
Old 19th September 2007, 13:22   #5
moralfibre's Avatar
Don't ask the service guys to clean the door insides. They will rip off the valuable for money damping that you have in the front doors
Old 19th September 2007, 14:16   #6
streetlife's Avatar
Thanked: 11 Times
I think that was me buddy.. All the four drain holes were clogged with mud.. i got it cleared and removed the rubber plugs as mud was collecting in them.. Dont know if it will make a difference..
Didnt get to check it as it didnt rained after that...
streetlife is offline   Reply With Quote
Old 19th September 2007, 14:31   #7
gbpscars's Avatar
Water in all 4 doors!!
Your car must be moving like the "Going to Ibiza" van!!
gbpscars is offline   Reply With Quote
Old 19th September 2007, 19:38   #8
payam's Avatar
not too much different in moving dude,but the noise ofwater is killing me.
Old 19th September 2007, 19:47   #9
streetlife's Avatar
Thanked: 11 Times
Payam you can do it yourself also.. Just take a small screw driver and clean the rubber plugs and then shake the door.. The water will drain...
Old 20th September 2007, 02:04   #10
rohan_fonseca's Avatar
Payam all those squids in goa and now this!
rohan_fonseca is offline   Reply With Quote
Old 20th September 2007, 15:25   #11
payam's Avatar
now i can keep the water inside the doors and start breeding squids
Old 20th September 2007, 15:55   #12
kapilsharma80's Avatar
Thanked: 28 Times
Payam, any break through or water still inside your doors!!
kapilsharma80 is offline   Reply With Quote
Old 20th September 2007, 16:49   #13
amtak's Avatar
Thanked: 382 Times
wasn't that me...?
http://www.team-bhp.com/forum/techni...ery-noise.html (Zen "Watery" noise)
amtak is offline   Reply With Quote
Old 20th September 2007, 16:52   #14
moralfibre's Avatar
The water inside the doors was just removed. It was contributing to ICE and some breeding of fish. Payam was here at my office and we cleared the mess.
Old 20th September 2007, 17:00   #15
hydrashok's Avatar
I hope the speakers are all right?
Help!Water getting inside car sans33 Technical Stuff 34 21st September 2015 12:02
Help! - Engine fumes getting into the car & causing health problems Mr_Bean Technical Stuff 27 21st September 2010 10:42
Complete Car + Car audio noob. Need help getting things clarified. hellmet In-Car Entertainment 2 17th January 2008 12:24
Help wanted in getting a small car prabuddhadg Hatchbacks 53 8th May 2006 15:14
