Closed Thread
Old 20th September 2007, 11:53   #1
easyrider's Avatar
Default Need gear changing tips for Scorpio (new)
What is the best & optimum method to change gears, both upshift & downshift?
I guess with each car/suv this changes. What is the right rpm and speed that one has to change gears (Up/Down).
Ashok
easyrider is offline
Old 20th September 2007, 14:39   #2
kapilsharma80's Avatar
Thanked: 28 Times
Easyrider,
Owner's manual has everything you want to know about.
Would suggest to follow whatever is written in the owners maual (OM)
Your vehicle will perform best if you follow the instructions given in the OM.
kapilsharma80 is offline
Old 20th September 2007, 20:41   #3
Rehaan's Avatar
Thanked: 25,037 Times
Hi easyrider,
There are several threads on changing gears, and a few on optimum gear change speeds etc. Please do a search and continue the discussion in those threads.
Thread closed.
cya
R
Rehaan is offline
Closed Thread
Changing Gear Ratios wildchild4lyfe Technical Stuff 13 25th November 2012 21:46
My new Gypsy so many questions - Changing the gear ratios mrgizzer Modifications & Accessories 6 28th August 2012 12:51
Bullet 350 - Gear changing issues ac 427 Motorbikes 51 8th October 2010 21:12
Tips to drive better: But are the tips correct? Spinnerr Technical Stuff 11 22nd June 2009 13:00
Changing Compression Ratio & Gear Ratio adheesh Technical Stuff 7 3rd October 2007 09:54
