Closed Thread
Old 9th October 2007, 22:29   #16
gemithomas's Avatar
Thanked: 136 Times
why dont we get any updates. is it that the problem is not solved ir is it that you wanna keep it a secret as to how it got solved@!!!
gemithomas is offline
Old 12th December 2008, 15:06   #17
Default Hi...
Well, yeah a year after, I'm giving updates... Sorry....
2 reasons. half way down I just lost hope and forgot about this issue...
Second, I was tarvelling...
OK So I flushed radiator etc and everything and it was the same. well now I run the car with a/c on always even now in dec.
the fan has a problem with a/c, it kicks in sometimes and sometimes it just doesn't. A/C gas leakage is there, needs to be fixed.
So with A/C on it stays at 1/4th . without A/C it jumps to half...
yes, the blower does blow hot air at the first go... will get that checked...
Samy
urdudesamy is offline
Old 13th December 2008, 10:34   #18
gemithomas's Avatar
Thanked: 136 Times
Isnt it normal to go just upto the halfway mark? I think there is a problem only if it goes above the half mark.
Closed Thread
Ikon Engine Overheating and Damage zuch Technical Stuff 69 30th May 2014 19:25
Indica V2 DLS - Engine overheating/AC issues ajaysurfs Technical Stuff 8 18th June 2012 20:54
Fiat Uno With a Siena / Siena Weekend 1.6 Engine moralfibre Modifications & Accessories 9 1st August 2008 14:20
Esteem - engine overheating - TECH2 gives normal reading ad75 Technical Stuff 22 10th March 2008 12:01
Engine Overheating: Urgent Help Needed! Su-47 Technical Stuff 14 3rd March 2007 10:38
