| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Sep 2007 Location: Bangalore
| Hi Experts, I am sure there would be multiple threads on this topic but I was not able to find one easily hence thought of posting one more .I own a Santro eRLX XO bought Jan 2007, leaving in Bangalore. Before I post my queries a few points: 1- I drive with A/C, never drove without it 2- Use normal unleaded petrol 3- Gear shifting is almost as recommended I have the following (lots of) queries and would highly appreciate your help/advice: 1- I am getting 11-11.5 KM/Litre in Bangalore city (haven't tried the highway yet). Is this a good mileage? 2- I am using shell/bp normal unleaded petrol. Do you think I should switch to Shell Super Unleaded for the compression ration the Santro has, 8.9:1? Is it advised? Would it improve performance/mileage? 3- What is the Octane level of Shell Super Unleaded (91/93/97)? 4- I keep adjusting the temperature control depending on the heat outside. Would keeping the temperature control at the coolest point consume more fuel than keeping it at mid-point? 5- Do car A/Cs have an air filter similar to home A/Cs? If yes, how can it be cleaned in a Santro? 6- What is an A/C neutrilizer? Many Thanks, hdoshi |
| | #3 (permalink) |
| Senior - BHPian | the mileage seems ok. you can try super unleaded and see for yourself. it is 93 i think since the normal shell is 91. just keep it at the coolest. sometimes in the morning when it is cool you can adjust it. but remember the compressor give out the same temp air whenever it is on, the heater makes the air slightly warmer when you adjust the thermostat. |
| | #4 (permalink) |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Mr. Doshi, 1) Yes, your mileage seems OK. 2) Mileage is likely to drop with premium. Performance might increase. 3) I'm not sure but I think it is 91. 4) Yes, your car will consume more if you keep the AC at max. In most budget cars, the compressor cuts in and out to maintain temperature. 5) Car ACs have an air filter very similar to domestic window units. Sorry, I don't know about Santro, since I'm a WagonR user. 6) Is that the car 'perfume'? I've no idea. You're welcome. |
| | #6 (permalink) | |
| BHPian Join Date: Dec 2006 Location: Bangalore
| Quote:
Is there anyway to improve that!? Mileage of around 12 with A/c on is normal I guess, for a Santro. I too get the same number! | |
| | #7 (permalink) |
| Hi All, first of all thanks for all your responses. Highly appreciated. Akshay1234 - I will try the super unleaded as soon as I reach the last drop of the unleaded fuel currently in my car. Mr. Anupmathur, you can call me Doshi, please don't be formal. I will find out the car filter from the service engineer/centre. I had seen an ad, GULF AC Neutrilizer - its some kind of a spray that is sprayed in the vents...probably used to remove bad odour (stale smell)...not sure but will find out. Lukeskywalker, my understanding is the additives help keep the fuel system like pump, injection etc clean. If so, then it would be an advantage - will post my result as soon as I try the super unleaded for a couple of full tanks. Shyamhedge, In fact, the exterior smell does penetrate into the car with the fresh air option closed and AC running...since you are in Bangalore - try the double road opposite big bazaar (mori)...I don't think there is an option but to use a good quality air freshner :-) Speaking about air freshners...I recently had a bad experience. I bought a new air freshner, made in china, wax based in a casing that looks like a big dice. Initially it smelt nice, but after a few days, I fell ill...eyes started burning, throat irritation. To prove it, I removed it from my car and placed it near my bedside...guess what...the health problem now started happening when I went to sleep and not in the car...please use caution when trying out new air freshners. |
| | #8 (permalink) | |||||
| Senior - BHPian | Quote:
__________________ ~ I n d i v i d u a l l y , we are one drop. Together, we are an ocean. ~ | |||||
| Thread Tools | |
Similar Threads | ||||
| Santro Xing eRLX XO: 15 months, 25000 kms report: | sidindica | Long-Term Ownership Reviews | 3 | 14th April 2008 11:02 |
| Santro Xing erlx A/C and suspension problem | varunghatge | Technical Stuff | 15 | 2nd November 2007 01:23 |
| Santro eRlx Short test drive | DCEite | Test-Drives & Initial Ownership Reports | 43 | 15th April 2007 15:12 |
| Old Santro Vs New Santro eRLX: Worth a change? | ms_rana | Hatchbacks | 20 | 5th July 2006 16:22 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
