Old 24th September 2007, 11:04   #1
sinhsha's Avatar
Thanked: 71 Times
Default Air filter got wet in Octavia 1.9 TDI
I had to drive through 2 feet water yesterday in my octy in the middle of night. After few meters car started like coughing. Somehow I made it to home and opened the air filter box and found it soaked. Should I just dry and clean the filter and put it back or should I do something else. I love my car.
sinhsha is offline   Reply With Quote
Old 24th September 2007, 13:24   #2
rohan_fonseca's Avatar
Don't start the car again. Get it towed to the a.s.s and get it checked.
rohan_fonseca is offline   Reply With Quote
Old 24th September 2007, 13:26   #3
theMAG's Avatar
Thanked: 1,574 Times
Sound piece of advise.
Old 24th September 2007, 22:37   #4
Jaggu's Avatar
Thanked: 8,692 Times
get it checked, to be on the safe side DONOT crank also. hope am not too late with the reply.
Old 25th September 2007, 10:54   #5
Thanked: 253 Times
Gentlemen he already DROVE home after the water crossing.
Ostensibly nothing very serious happened (lucky!).
Now of course a full inspection (open the oil pan/chamber) and clean-up (if required) would be in order. Tappet cover should also be taken off and valve gear checked.
The ASC will know all this......
Old 26th September 2007, 10:24   #6
sinhsha's Avatar
Thanked: 71 Times
Thanks all for your sound advice. The car engine is quite ok. Service guy checked and started. Engine oil gear oil is ok. Though the car is not movable yet. The clutch got stuck as it got wet. The service guy told to keep it under sun for one day and then after putting it into 3rd gear to crank it several time. If it doesn't work then they have to tow the car and open the clutch housing.
DIY: Volkswagen Vento TDi - Air Filter Cleaning thoma DIY - Do it yourself 7 19th August 2017 21:18
Air filter and Air intake sunilvarma Technical Stuff 10 4th November 2010 10:58
air filter wet harry2223 Technical Stuff 10 26th June 2008 00:49
Best air filter or cold air intake for Skoda RS Kartik9500 Modifications & Accessories 9 7th February 2008 03:43
