Old 26th September 2007, 02:18   #76
shuvc's Avatar
Thanked: 283 Times
Originally Posted by BlackPearl View Post
will ask Joydeb Da tomorrow morning if anything can be done about this. he has quite a few people known in maruti, so may be he can help. no harm in giving it a try.
Thanks. All inputs/assistance welcome !
Originally Posted by 1100D View Post
Thats quite thoughtless of the owners of the contributors to the orchestra.
I saw the owner of this car go down to fix it. Not sure what he did, but wasn't successful.
Most of the other cars were those which are parked in rented spaces. Hence the owners do not stay in that particular apartment block. Cell networks were poor all through these 2 days + even if the owner was apprised of the situ, his place could be a few blocks or more away. It would be a daunting task to come down.
Ah ! The smile. I've found my stoic nature come to the fore in this case.
Old 26th September 2007, 02:41   #77
binz's Avatar
Thanked: 411 Times
Whoa,thats a sad sight.
Originally Posted by shuvc View Post
- What are the consequences of water in the exhaust pipe?
My noob instincts tell me that water would have entered your head,atleast till the exhaust valves.Bcause its very clear that your manifold is under water,and that liquids seek their own level blah blah ..
Take every possible precaution,if you overlook even the tiniest thing,chances are the car won't ever be the same.
Best of luck!
Old 26th September 2007, 08:45   #78
Ram
Ram's Avatar
Thanked: 146 Times
Here're my thoughts.
The car must be pushed/towed to wherever it will be serviced.
It needs a good wash, shampoo and dry and disinfection so that the bacteria and germs that invariably dwell in stagnant water are exterminated.
Genuine wool, cotton and leather (organic substances) would certainly be ruined and must be replaced. Comfortably, a Baleno is not a Jaguar or a Rolls-Royce so it does not use genuine wool, leather and suede. The synthetics like rexine, faux-leather, nylon plush and polyurethane foam moulded seat cushions can be safely washed, shampooed and reused.
All the oils and lubricants must be changed.
Disconnecting the battery was the most important thing to do and you have done that. Electronics that was not already inundated when you disconnected the battery is likely to be safe. The car will just start and run after it has been thoroughly worked on.
One challenge will be getting all the flotsam and gunk out of the car. When the water recedes, the impurities in the water (clay, dirt, hair, discarded food, etc) stay stuck to the car.
Most places in India lack steam cleaning, hot water pressure wash, wet vaccuum, and machine drying facilities. And common garages are notorious for their lack of attention to detail.
I don't mean to rub it in but, this car now deserves the kind of attention that classic car restorers lavish, not common garages that make new cars old (Many of our garages fall in this latter category).
Some of our Bangalore, Coimbatore, Chennai automobile aficionados are known to roll-up their sleeves and do many things themselves, from sourcing specialty parts to modding, personally washing and polishing and installing non-standard items. I would connect with them.
Close supervision and personal attention to detail, will be key to good results.
Ram
Ram is offline   Reply With Quote
Old 26th September 2007, 10:02   #79
Shuvc, i wish you get your car up and running asap - without a big dent on your pocket. All the best!
dhiman is offline   Reply With Quote
Old 26th September 2007, 10:57   #80
nikunj_cal's Avatar
@shuvc- Just saw the pics ! Really sad to see your car.I dont know what i would have done in your situation.My sister lives is in lake town and they are experiencing 3 ft water still underneath their house. They are seriously thinking of relocating and I think you should start too. The rains came down so hard that it seeped in my Indica(it was standing in the open parking lot all the time) and created a mini swimming pool inside .I think i will need to change the rubber lining of the entire car :(
nikunj_cal is offline   Reply With Quote
Old 26th September 2007, 11:12   #81
benbsb29's Avatar
Thanked: 3,603 Times
Quite a shock actually seeing the pics. The others have already said what needs to be done, so i shall resist from the same.
As for the car, hope it comes out with no major damages.
benbsb29 is online now   Reply With Quote
Old 26th September 2007, 11:40   #82
shuvd's Avatar
All the best to Silver Arrow. Our best wishes to her. Your phone is still "not reachable/switched off".
shuvd is offline   Reply With Quote
Old 26th September 2007, 12:10   #83
razor4077's Avatar
Thanked: 252 Times
To take a cue from what ram said, most workshops do not clean the interiors thoroughly. I think Vinay & Co. recently started a Car Spa that offers some extensive car care services. You could give him a call and find out if they can help restore the interiors. I can vouch for the quality of their work.
If you need any help, gimme a call. Been trying to get in touch with you, but your cell is still not reachable.
razor4077 is offline   Reply With Quote
Old 26th September 2007, 12:31   #84
toiingg's Avatar
Thanked: 74 Times
Feeling lost for words man, feeling damn bad for the silver arrow, and the owner.
toiingg is offline   Reply With Quote
Old 26th September 2007, 12:40   #85
vrooooooom's Avatar
I saw the pics today. Was really shocked. I can well understand what is going through you now. But I have a feeling that there would be less damage. Luckily you opened the battery and handled the intake pipe. Dont worry about the electronic stuff. They should be fine. Just have to ensure that before you start the engine, everything has dried up and your fingers are crossed. Just keep your faith on Suzuki :-)
The only pain would be thoroughly cleaning the car.
All the best for the silver arrow and your pocket
vrooooooom is offline   Reply With Quote
Old 26th September 2007, 12:56   #86
shuvc's Avatar
Thanked: 283 Times
@binz - you're right. Water has probably reached the exhaust valves. But it shouldn't enter the engine from there.
@ram - your post actually gave me a lot of hope !
@razor - I have thought of the Vinay angle. But I guess all that will come later. The first thing I need to ensure is that the car is DRY and all fluids changed, before it is cranked. This, I can do only at Mohan Motors. If a Spa is required after I receive the car from there, then Vinay might come into the picture.
Cell network is still poor. Am at the 3rd floor flat now. You may be able to get through.
Current update - approx 40hrs after water entered the car. The level has gone down by 4 inches. The headlights are not covered anymore - it's just at the bottom of the headlights. I can see some water accumulation in both the headlight assemblies.
Maruti service engineer wanted to send a tow truck today. But when I mentioned the water level, he said it's best to wait till it goes down some more. They had sent the tow truck to another area (Dhakuria) yesterday. The truck stalled and broke down !
Old 26th September 2007, 13:12   #87
suman's Avatar
Thanked: 257 Times
Man, this is terrible - what's frustrating to hear is the amount of time its taking for the water to go down even after the rain's stopped! Must be heart breaking for you, I'm sorry!
Reminds me of 1999 monsoons in Kolkata - we were staying in Golf Garden then. Place resembled a lake, water inside ALL our cars - Maruti 800s & a Fiat Delite. The rains stopped & the water receded EVERYWHERE except a one kilometer radius around our house . But it was nowhere near what I'm seeing here - though we did have to spend some bucks getting the Fiat back in shape. The worst bit was the STINK once the carpets had dried.............
Old 26th September 2007, 13:39   #88
MaserQ's Avatar
Thanked: 51 Times
Have courage my friend. You and your silver arrow will come out stronger than ever before! When are the car makers going to do a weather-proof version?!
MaserQ is offline   Reply With Quote
Old 26th September 2007, 13:46   #89
supremeBaleno's Avatar
Thanked: 1,651 Times
shuvc, that's a real sad situation with your car. Feel bad just seeing the pics.
Hope you get her back soon without any major damage (to the car and your wallet).
Old 26th September 2007, 15:43   #90
nikunj_cal's Avatar
Arre sir he is a top shot in one of the biggest software companies, i am not at all concerned about the wallet (wink, wink) , it is just the car condition that kills me :-( !!
Car was half submerged in water - What to do? csentil Technical Stuff 60 23rd November 2015 19:21
Floods in Thailand - Honda factories submerged - Will it affect India? sahakar The Indian Car Scene 23 2nd November 2011 06:52
My i10 was half-submerged in yesterday's rains! NK@Hyd Technical Stuff 8 29th October 2010 01:00
Civic submerged at Dakshin Honda EDIT: Now resolved ajmat Indian Car Dealerships 84 12th September 2009 00:55
Maruti Zen submerged in water AKNAN Technical Stuff 9 28th August 2009 18:16
