Thread Tools
Old 26th September 2007, 02:13   #1 (permalink)
Question Need help on selecting an engine for a racing car
Hello frenz, i'm a engineering student and i'm working on a project of international level and i really need ur help. Our team is building a " Single seater racing car" for an event organised by SAE known as FSAE.
I am basically looking for an engine. but it's mentioned that the car must have a four stoke piston engine(s)with a max displacement of 610cc. If 2 or more engines are used, the total displacement should not exceed 610cc and the air to all the engines has to be provided through a single common air intake restrictor.
And in order to restrict the power capabality from the engine, a single circular restrictor has to be placed in the intake system between the throttle and engine and all the air must flow throu this ristrictor to the engine. Any device used to downstream the engine is also prohibited and the max diameter of the restrictor can be 20mm.
So i need ur help in searching an engine within these limits that can yet be powerful enough to win a race...
santy_p4 is offline   Reply With Quote
Old 26th September 2007, 08:07   #2 (permalink)
Rehaan's Avatar
santy_p4,
Do a search for FSAE on Team-BHP.
cya
R
Old 26th September 2007, 09:04   #3 (permalink)
harsh87's Avatar
Infractions: 0/1 (5)
santy_p4
Its nice to see a lot of indian colleges stepping into FSAE
Which college are you from
Your best bet on the engine is
a) Honda cbr 600 engine
b) Yamaha r6 engine
c) Suzuki GSX-R 600
Not in any particular order, availability is also an issues
Another option is the WRX-450 or aprillia sxv550 motor but wouldn't recommend these to you, as you need a sub 180kg car to use these motors to their fullest
harsh87 is offline   Reply With Quote
Old 26th September 2007, 23:46   #4 (permalink)
Thanx harsha, but i was thinking of using two cbr250 engines coupled ona common crankshaft. What do u think??? Or should i use a single engine only???
Thread Tools
Hi all - help a new member in selecting a car vikrantw1 Hatchbacks 12 10th August 2006 18:30
help me out in selecting the car AnandPatil Sedans 8 7th July 2006 22:51
please help on selecting a car audio! ! ! cool_sizzlers Ask the Gurus 21 7th April 2006 12:37
Need Help Selecting a Car Technocrat Sedans 8 11th January 2005 23:52
Racing Car Sounds? khaadu75 Shifting gears 1 20th August 2004 20:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
