Old 26th September 2007, 14:31   #1
Default Dropping FE of my SWIFT-VXI
Hello Friends,
I have SWIFT-VXI which has clocked 13K in last 21 months.Recently I have nticed that there is sudden drop in FE of the car.Actually,I have maintained an EXCEL sheet on my PC where I have all the data like odo reading,fuel filled,date,amount etc.Though in between I had stopped recording these details.
Today,when I was going through these details I was shocked to see the dropping performance.
Recently I have filled 37.5lt of fuel in my car and today after clocking 305kms.the needle is one line below the half mark in the fuel meter.
What I have noticed from my data that in 35lt of fuel car has run about 480kms in past.The driving conditions are more or less the same.I mean I use AC all the time whenever I drive.
Please suggest.
raja748 is offline   Reply With Quote
Old 26th September 2007, 16:06   #2
bblost's Avatar
Thanked: 6,980 Times
The following thread deals with mialge issues in an Alto
http://www.team-bhp.com/forum/techni...nomy-woes.html (Alto Fuel Economy Woes)
it however has a lot of input in factors causing a drop in milage.
read it thru.
my 2 cents..
did u change your petrol bunk by anychance.
Old 26th September 2007, 16:18   #3
"the needle is one line below the half mark in the fuel meter" = less than 20 lts or less right? which means FE of 15
where as ur previous FE was 13.7
vinodbijlani is offline   Reply With Quote
Old 26th September 2007, 16:23   #4
Actually,I had asked attendant to tank-full the car and it was 37.5lt when it auto stopped.That,means I had approximate 41 or 42lt.of fuel in car...right? i am not that strong in mathematics
Old 26th September 2007, 21:14   #5
n_aditya's Avatar
Thanked: 2,781 Times
Thats not the right way to calculate raja. The nearest accurate reading is obtained in the following way:
Fill up the tank till the auto stop. Any more fuel after the auto cut off can cause this extra fuel to evaporate. Petrol being highly volatile needs some "breathing space" or to say expand in hot conditions.
Note down the Odometer reading and drive around. Next time you fill fuel, fill till the auto cutoff again. Now see how many kms you have run (if the trip meter is reset) or subtract the new odo readings from the previous one. Divide that number by the quantity of fuel you JUST filled in. That will give you the nearest accurate FE reading.
Do note that not all petrol bunks dish out the correct quantity or quality of fuel which adversely affects FE. Also driving conditions, usage of a/c, tire pressures, vehicle condition (tuning etc) matter a lot.
Old 2nd October 2007, 06:21   #6
clean your fuel system with sonax additive
decarb your engine , change oil , oil filter & fuel filter - change spark plugs , flush radiator
hope you use mobil 1
5w50 api sm
lovely
cyneverdie is offline   Reply With Quote
Mercedes AMG Dropping 6.2-liter V8 for Bi-Turbo 5.5-Liter V8 hanmust The International Automotive Scene 3 19th December 2009 18:47
Why not realistic pricing, and effect of price dropping? sgiitk The Indian Car Scene 15 10th July 2009 12:07
Dropping in to say hi! DrudKh Introduce yourself 4 16th March 2009 00:30
Revs not dropping during gear change ! normally_crazy Technical Stuff 22 8th March 2009 18:57
Swift vxi or Esteem vxi ? bsm3477 Hatchbacks 11 15th October 2006 13:38
