Thread Tools
Old 26th September 2007, 16:12   #1 (permalink)
HSV
HSV's Avatar
Default Indigo Tyres worn out in the corners!?
Guys,
At the outset I'd like to inform y'all that I am not a very cluey guy when it comes to diagnosing problems with cars. My Tata Indigo LX Oct 2004 model has done me great service. It has completed a little over 42000 kms on the odo.
From the past 2-3 months (not exactly sure when) I noticed that all the tyres have worn out in the corners (both innner and outer). The middle part of the tread seems quite good infact. I have tried to maintain 30 psi tyre pressure whenever I can remember! Oh BTW, my stock tyres (which came with the car) are JK Tyres 175x65x14.
Now a month back just a few days after my regular service I got my workshop to do the wheel alignment and wheel balancing. During the wheel alignment I had noticed that it was slightly out and even the wheel balancing was slightly out too. So go that done and even asked him to do a tyre rotation - front to back (though I must admit that the rotation I got done after a substantially long period of say 20000kms ). Now after this whenever I drive the car it bounces and bubbles a little and the steering even wobbles a little around 80kmph. This was certainly not the case earlier. I could take the car to 120kmph and not feel anything. Now I dont have the confidence to go beyond 80kmph as it doesnt feel that sure footed.
I took it back to my workshop for some minor work and told the supervisor to check the wheel alignment and balancing as I suspected that the guy hadnt done it properly. When I went to pick my car he told me that he had checked and the problem was in my tyres! he said that the surface (which connects to the road) was slightly uneven which is why my car was bubbling. He said that the tyres needed to be replaced!
BTW, On casual interations during puncture repairs, with the local tyre-wala I was severly told by one and all that JK Tyres suck big time. However he exclaimed that it can still run ok for another 5-8000 kms. I asked him if its safe and if I can take the car out of town etc. He said it should be ok.
Now, my questions are:
1) Is the wearing out of the tyres normal - since I neglected the wheel alignment/balancing for a little too long?
2) Are JK Tyres really that bad?
3) Having driven 42000 kms in nearly 3 years is it normal for me to change the tyres now? Sorry I dont have pictures of my tyres - however I'll upload them soon to give you guys an idea of what the wear looks like. I dont mind changing the tyres now as I give lot of weightage to safety, however since the tread in the middle doesnt look too worn out (except for the corners) which makes me unsure.
4) I hope my workshop guy is not trying to take me for a ride by saying what he said so that they dont have to do the alignment/balancing job again. Further I hope there isnt anything wrong in my suspension which has caused this kind of wearing in the corners! If so then my car is still under extended warranty for another month - and I should take it back straight away.
5) Frankly I plan to keep the car for another year before I sell it. Is a tyre change recommended?
I plan to go for a little hill-station trip with the family early next month. So it would appreciated if someone can give me a little feedback/advice as to whether I should change the tyres now or hold on for another 5-10000 kms?
Best regards,
HSV is offline   Reply With Quote
Old 26th September 2007, 16:18   #2 (permalink)
speedmiester's Avatar
You should look at changing your tyres soon, since you haven't rotated the tyres at proper intervals.
The Tyres will wear out unevenly and this will be reflected in the handling characteristics.
Go for new tyres even if you are thinking about keeping the car for an year. It is not worth the risk of using the same tyres.
__________________
"My car is not leaking oil, she is just marking her territory"
speedmiester is offline   Reply With Quote
Old 26th September 2007, 16:22   #3 (permalink)
HSV
HSV's Avatar
Could you recommend some good tyre brands for the Indigo? Goodyear, MRF, Bridgestone etc? Further should I go for w/tubes or tubeless? Someone did mention that the Indigo's stock steel rims are a little soft so are the tubeless recommended?
I am not looking at any high performance stuff, as an Indigo is not high performance . Anything durable and safe should be pretty ok, considering I plan to keep the car only for another year (may sell it sooner if I get a good deal).
Last edited by HSV : 26th September 2007 at 16:25. Reason: forgot 2 add another thing.
Old 26th September 2007, 16:48   #4 (permalink)
with sm, but inthe meantime you can rotate them back (if you remember how you did it in first place itself) or place the better ones in the front, your wobbling will be gone.
Old 26th September 2007, 16:52   #5 (permalink)
Check out the tyres and alloys section, you will find the perfect tyres for your car.
I personally prefer bridgestone or michelin. They are the best.
__________________
Old 26th September 2007, 17:17   #6 (permalink)
ad75's Avatar
indigo being on the heavier side 42-50k is very much the life of a tyre.would suggest you to go for bridgestone/mrf since you plan to sell the car in a years time.hill station trip with family surely calls for a tyre change.
ad75 is offline   Reply With Quote
Old 26th September 2007, 20:03   #7 (permalink)
HSV
HSV's Avatar
thanks sm, dadu and ad75. How about point number 4? I hope there is nothing wrong with my suspension - although it doesnt seem so. But just thinking aloud?!
Old 26th September 2007, 20:28   #8 (permalink)
rohan_fonseca's Avatar
The issue looks like because of a long gap in the wheel allighnment/bancing schedule. 42k is high time for a tyre change anyways. My dads got stock bridgestones on his indigo(tubed) and are pretty adequate. You could go for them.
rohan_fonseca is offline   Reply With Quote
Old 26th September 2007, 21:02   #9 (permalink)
condor's Avatar
Originally Posted by ad75 View Post
indigo being on the heavier side 42-50k is very much the life of a tyre..
Shouldn't be so. Have done almost 60K on stock Bridgestone's, and hoping to stretch these another 10K.
__________________
Life is Analog. Digital is an approximation.
All kinds of animals come here ... and the occasional demon too !
Old 9th October 2007, 17:17   #10 (permalink)
HSV
HSV's Avatar
Default Thanks for everyone's advice! Replaced 4 tyres with Bridgestone Tubeless 185x65x14.
Thanks guys, for all your advice. I changed all four tyres to brand new Bridgestones 185x65x14 Tubeless. I kept one old tyre as a stepney. It cost me 13000/- for four tyres (i.e., Rs 3250 per tyre). The dealer even gave me a tubeless tyre puncture kit for Rs 150, which he said he normally retails for 250/-.
The dealer told me that my JK Tyres 175x65x14 were no good as there had appeared a slight unevenness due to which I could feel the slight bouncing - I got this point double checked by another tyre dealer. He said JK's normally dont last that much on an Indigo as its a heavy car.
Anyways, the car handles like a dream now! Took it for a long drive of over 600kms this weekend to Jaipur and the car handled great! So much so that it feels like new. I had been seriously contemplating selling my Indigo as it wasnt feeling very great to drive.
However after the tyres change I think I want to keep the car for another year. I am just loving the new tyres!
BTW got a milage of 18.15 kmpl with my new tyres! So thats great.
Mods, you're most welcome to close this thread.
regards,
Thread Tools
ES100 on Elantra worn,now what? .anshuman Tyre & Alloy wheel Section 13 4th September 2008 21:13
detecting worn engine mounts harry2223 Technical Stuff 20 20th April 2008 02:55
Renault Logan 1.4 with CNG or Indigo LS (diesel) EDIT: Bought Indigo! panky12345 Sedans 28 29th February 2008 13:18
Replace only two worn out tyres forbhaskarm Tyre & Alloy wheel Section 11 5th January 2008 11:28
Labelling on plastic instruments getting worn out sandhurs1 Technical Stuff 6 30th October 2007 13:31
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
