Thread Tools
Old 3rd February 2008, 13:28   #16 (permalink)
hi friends,
I had mentioned about the wheel bearing problems i had before! i did change the wheel bearing of the rear RHS wheel and the problem was solved! I am posting my present day query in this thread itself! My present day problem is regarding the silencer unit of my ford ikon!
my car is ford ikon 1.3(roacm engine) 2003 model clocked 35k till date!! I live in mangalore (karnataka). the climatic condition in this part of the country is such that 'Rusting' is predominant here! i had a few problems with the muffler unit of my silencer! it got rusted and that created a hole in my silencer unit (muffler). so i had got it welded a couple of times before! but now, the problem has worsened! i have been adviced by the people at ford that the muffler cannot take anymore welding on it and i have to change the entire silencer unit!
now my problem is, they told me the silencer unit costs about 17k !!! Now tats a pretty deep hole for my pocket! my question to all you guys is:
1)should i change the whole silencer unit?? the problem exists with the muffler part only! the local mechanics have told me that its enough to change only the muffler part! but i feel i must get the work done at ford service centre itself! suggest me what do i do! i cant spend 17k right now!! is there any other cheaper way out??? is there any problem if i get the work done at any local garage instead of doing it in ford service centre???
can i approach this problem in the following manner???
2)is it possible to get the silencer unit (sparingly used) of any other ford ikon which has been damaged in an accident and tagged-"total loss"??? i have searched for such vehicles in mangalore! but the people at ford are not helping me as they know that, if i get the used muffler unit, i wont buy the 17k product from them!! but a mechanic at ford has told me that, in a place like bangalore which has so many cars, i might be able to find a muffler unit for my IKON! so anyone at bangalore can help me regarding this???
pls help me!! thanks a lot in advance!!
bdn317 is offline   Reply With Quote
Old 3rd February 2008, 15:57   #17 (permalink)
condor's Avatar
Your car is a 2003 model, so you wouldnt have to worry about warranty. Hence, it is not necessary for you to stick with the dealer for this problem. But dont rule out some fussy behaviour later on, when some one may blame the outside job as the cause of any (even un-related) problem.
You should be able to source it from BLR.
Any Ikons here with a FFE ?
__________________
Life is Analog. Digital is an approximation.
Old 3rd February 2008, 20:20   #18 (permalink)
Absar's Avatar
Shouldn't be a problem in replacing only the muffler part from Ford,atleast here in Madras. And hey,how about getting a new end-can?
Btw,yes there are Ikons here with FFE,but can't remember out the owners of them.
cya
A
__________________
Ford Ikon 1.6 Nxt ZXi, 2005
I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM.
Absar is offline   Reply With Quote
Old 3rd February 2008, 22:04   #19 (permalink)
Team-BHP Moderator
Jaggu's Avatar
retain the cat cone and replace the bit from there till the tail
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 4th February 2008, 05:16   #20 (permalink)
nitrous's Avatar
Why?
Taking off the cat con will give oodles of extra power.
Old 4th February 2008, 16:38   #21 (permalink)
well friends,
am not looking for any performance upgrade like extra power or something like that!! my dad uses the ikon most of the time as i have been given a jeep for myself!! but ya, with the fuel prices rising, i would like to have the best possible mileage!!
(i was told the silencer unit of a car affects the mileage - is this true??? if yes, how does it actually affect?? pls tel me)
so a simple solution to my problem would be better!! please help me get a descent muffler unit for my ikon!!
thanks in advance!!
Old 4th February 2008, 22:00   #22 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Originally Posted by nitrous View Post
Why?
just suggesting that he can retain his headers till catcon (included) if he aint upto complete free flow.
__________________
Old 4th February 2008, 23:20   #23 (permalink)
danlalan's Avatar
Infractions: 0/2 (11)
Hey,
I have an ikon 1.6, Faced similar issues like yours. Tires getting old, Changing Muffler. Others that you are might come across is Ignition coil cable 5500/-, and suspension 5000/- only shocks. Not trying to scare you or anything but just in future keep 10k aside for that.
I changed my Silencer unit for 4000/- from a mech and not from ford. It still runs good. Only got an s.s end can, so it looks better.see my garage. Got the S.unit with cat con and centre muffler and stock end can.
Get your Silencer unit done from a mech outside and not from FORD.
Tires, its recommended to change after 4 yrs or less. Ive a 00' ikon and its time to change my set for the third time now. USed 322's earlier. Will be going in for p6000's or Es100's if i do get them in 185/65,r14.
As for RIMS, hate the 100pcd. Dont get good choices with that PCD. So i too have been looking for used alloys, the 5 spoke ones. Did find a set but did not like them too much.Costed 6000/-. I asked the company also for 5spoke alloys but they had none in stock.
danlalan is offline   Reply With Quote
Thread Tools
Front Speakers Query - Ikon gr8guzzler Modifications & Accessories 30 24th October 2007 19:00
Ford Ikon mod - fiesta head on ikon block? madhunm Modifications & Accessories 2 2nd July 2007 09:24
query about used ford endeavours aadix SUVs, MUVs & 4x4s 11 31st May 2007 21:11
Ford Ikon 1.6 at 5.4? RX135 Sedans 3 12th January 2005 18:30
Ford Ikon v12 The Indian Car Scene!! 1 24th February 2004 10:35
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
