| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Aug 2007 Location: Mangalore
| Hi friends!! I own a ford Ikon (03') with the rocam engine1.3. Its run around 25k kms. Its still running with the bridgestone tyres(original fit). I recently have noticed a wierd sound (& a bit of vibration) when the vehicle is in motion. People here tel me the tyre threads have almost vanished!! but i dont think so!! the threads are still prominent!! I have owned an opel astra before this!! i Hav used the opel for 7 years!! (97-03') I had similar bridgestone tyres on it!! But i never have noticed the above discussed sound in it!! so am confused!! i know that the tyres stil have a minimum life of 10k kms more!! Pls give your comments regarding this matter!! how should i go about it!! I also wanted to know if second hand alloy wheels are available for my vehicle!! how much would they cost approx!! and is it available in my city?? (mangalore) |
| | #2 (permalink) |
| BHPian | hi Tyre does not depend on number of years, it all depends on how the car runs and the condition of road, in your case we cant tell exactly what could be the problem, if you can post some pics of tyres, we can help you out.. cheers
__________________ "To the question of your life, you are the only Answer. To the problems of your life, you are the only Solution" |
| | #6 (permalink) |
| Distinguished - BHPian ![]() | Vibrations can either be caused by wonky Wheel Alignment or by tyres which have got bulges in them. Basically in the first case all you have to do is get the balancing done again but if the tyres have bluges than you have to replace them.
__________________ Until you've lost your reputation, you never realize what a burden it was. |
| | #8 (permalink) |
| BHPian Join Date: Feb 2007 Location: Kolkata
| I remember reading somewhere that after 5-6 years tyres should be replaced even they are not worn out, as rubber deteriorates as it gets older. For the same reason, it is important to check the manufacture date at the time of purchase of new tyres.
__________________ Every man has his follies. And often they are the most interesting things he has! |
| | #9 (permalink) |
| Distinguished - BHPian ![]() | Yes, tyres generally have a life of around 5 years so it's recommended to replace them after that period (from the date of manufacturing) to ensure that there are no problems like sudden blowouts or poor grip due to ageing & hardening of the rubber.
| | #12 (permalink) |
| BHPian Join Date: Mar 2005 Location: goa
| After 25 k kms you should not need to change the tyres, unless there is severe mis-alignment. I had this problem on my old Escort, alignment was never done properly due to some suspension component that needed replacement and the tyres chaps just did their alignment (every 5000 kms) to the best they could, but never told me it was out of whack so much. After 25 k tyres were badly worn out on one side, and eventually I replaced them at 30 k. But never had a noise. Please have this checked thoroughly before you put new tyres. Have them rotate the tyres, see if the noise goes away, then you know it's the tyres. Have them check that the alignment is spot on, no deviation should be tolerated. It may be a suspension component, in which case get it done before you put new tyres.
__________________ Hyundai Getz 05 Baleno Vxi 05 |
| | #13 (permalink) | |
| Senior - BHPian | Quote:
Your treads may have some life left, but the rubber is ageing. Like Iraghava said, check the tyres for bulges.
__________________ Goodbye Dada, you made us proud. | |
| | #14 (permalink) |
| Hi friends!! In my 1st query in this post, i had complained about some noise and vibrations in my car!! i had asked everyone whether the tyres played a part in it!! Now my problem still remains the same!! but the people at ford told me today, that my tyres stil have a minimum life of 5k-10k kms in it!! They also told that the wheel bearing of the RHS-rear wheel was the source of the problem!! My vehicle has done around 28k kms till date!! what i would like to know from all of you: 1)wats your opinion regarding the comments made by the people at ford about this problem??? Do you feel the bearings are the source of this??? 2)is it a proper time for wheel bearings to get worn off?? i mean its just clocked 28k!! isnt it too early?? wat might be reason for this??? 3)They have also told me it will cost me around 3000-3500 rs. to rectify it!! is it a fair price?? 3)they have informed me tat, i shud get this job done soon!! else if i delay it, i might have to change the drums as well!! how true is this??? pls do give ur opinion about this and suggest me how do i go ahead from here!! Thank You!! |
| Thread Tools | |
Similar Threads | ||||
| Ford Fiesta-- JBL setup query. | fidaford | Ask the Gurus | 24 | 3rd December 2008 11:01 |
| Query on Ford Ikon ROCAM cam timing | madhunm | Technical Stuff | 11 | 24th July 2008 15:01 |
| Front Speakers Query - Ikon | gr8guzzler | Modifications & Accessories | 30 | 24th October 2007 20:00 |
| Ford Ikon mod - fiesta head on ikon block? | madhunm | Modifications & Accessories | 2 | 2nd July 2007 10:24 |
| query about used ford endeavours | aadix | SUVs, MUVs & 4x4s | 11 | 31st May 2007 22:11 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
