Old 29th September 2007, 00:23   #1
bhp
bhp's Avatar
Thanked: 152 Times
Default Baleno belt problem!!
The ac and power steering belt of my baleno has worn out...i can see cracks on it...and now its making some unusual noises
so it needs urgent replacement...also decided to change the alterantor belt with it...
viteese quoted :
ac and power steering belt : 2000
alternator belt : 200
labour : 500
+ taxes
total : 3000 approx
took the car to my local mechanic he said original belts are available outside as well..
both belts : approx 400 rs
labour : 150 rs
also inquired with 2 spare parts shops they say good quality (branded) belts are available in the market for all cars...
i have never given my baleno to the local garage beside alignment so wat should i do ....
get it frm maruti at viteese or get it done locally ??
the margin between both the places is just 2 much...
how long lasting is the belt in the baleno...my car has just clocked 40 k kms
bhp is offline   Reply With Quote
Old 29th September 2007, 01:28   #2
Jaggu's Avatar
Thanked: 8,686 Times
if your local garage is reliable, buy MGP parts and replace it there, belts can last anything from 40 to 60 k kms, its normal to change belts at 40 k kms
Old 29th September 2007, 08:04   #3
Thanked: 253 Times
Belt life is also age dependent, apart from weather conditions and how often it got wet etc....
It would be a simple matter to have a good branded belt put by a local shop. But please be present when having it done. (To confirm use of correct tools and to verify that no nuts/bolts are left loose).
Old 29th September 2007, 12:22   #4
bhp
bhp's Avatar
Thanked: 152 Times
alright...thx for the help guys
My seat belt is stuck cheatingdeath Technical Stuff 15 7th November 2017 09:27
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Santro power steering problem & timing belt prob coolmob Technical Stuff 14 11th April 2014 18:57
Power steering belt snapped (Baleno). Can i drive 60 kms without damaging anything? rock75 Technical Stuff 22 17th December 2011 20:35
Fan Belt problem in my Ford Ikon 1.6 sanju.sreekumar Technical Stuff 14 11th March 2009 12:13
