Old 29th September 2007, 11:56   #1
kutlee's Avatar
Thanked: 202 Times
Default silencer fallen off. help!!
My OHC's 'B' part of the exhaust system is rusted and the expansion chamber(of front silencer) has fallen off. The Sundaram guys say that the 'B' part costs 12k. As i am planning a turbo (well still not able to make it), will it be useful to buy this? Or go for a local stuff (welding ruled out by welders here..may be some experts still there...)?
Any shops in Hyd who sell local made exhaust parts?
another option is to get the exhaust system (to be done with turbo job) and fit it ahead of the actual turbo job being done to avoid double costs.
Any pointers??
Regds..............
kutlee is offline   Reply With Quote
Old 29th September 2007, 13:33   #2
nikhilv12's Avatar
I think it will be better if you go for a complete FFE (excluding the exhaust manifold). Later, get the custom exhaust manifold, with your turbo.
nikhilv12 is offline   Reply With Quote
Old 29th September 2007, 15:10   #3
Jaggu's Avatar
Thanked: 8,694 Times
go with nikhils advice....
Old 29th September 2007, 15:13   #4
v1p3r's Avatar
Thanked: 27 Times
As discussed, get a mechanic to weld a sleeve on to it. Should hold for a few thousand km atleast. Once you get the turbo job, you can think about an FFE, depending on sound levels.
Old 29th September 2007, 15:25   #5
Jaggu's Avatar
sleeve jobs are pain and temp fix, avoid it if you can.
Old 29th September 2007, 19:29   #6
razor4077's Avatar
Thanked: 258 Times
What Nikhil said makes sense. An entire FFE (with headers) will cost you as much as what Honda is quoting you for a part of the system. Since performance is part of your future plans, fitting a FFE is a good start!
razor4077 is offline   Reply With Quote
Old 11th October 2007, 20:34   #7
kutlee's Avatar
Thanked: 202 Times
problem solved. fitted free flow without header.
Thanks for suggestions..
ORVM cap has fallen off from my 1 week old Chevy Spark karty_83 Technical Stuff 20 25th May 2010 15:26
Apache RTR - Bar-end weights fallen, please help! rahulsingh007 Motorbikes 5 8th May 2009 15:41
Bought a "new" OHC, 1.5 AT, hardly used, fallen in love with her! loving_alaap Test-Drives & Initial Ownership Reports 36 17th February 2009 14:32
The FALLen trees, The SMOKYing Mountains, The MAZDA Saurabh M Travelogues 52 14th November 2008 22:46
The curse has fallen upon Rossi! turbo_v12 Int'l Motorsport 10 24th May 2006 01:26
