Thread Tools
Old 3rd October 2007, 15:44   #16 (permalink)
Jaggu and Nura,
Thanks for your valuable input.I will get this checked at the garage keeping the points you both mentioned in mind.
fergus is offline   Reply With Quote
Old 3rd November 2007, 23:54   #17 (permalink)
Default fuel smell in swift
hi people
got a petrol swift
always fill up a full tank at a time
always got the smell of petrol in my car after filling up ONLY after filling up , ; then it would die away
always forgot to mention it to maruti
today got stuck somewhere & filled up 200 rs of xtraprem on an empty ish tank ...the smell was stronger then usual & this problem has been slowly getting worse but as usual even this subsided
any clues any body
will ask my mechs too
on monday
ANY SWIFT OWNERS ' FEEDBACK WOULD BE GREAT
cheers people
thanks again
cy
cyneverdie is offline   Reply With Quote
Old 3rd November 2007, 23:56   #18 (permalink)
abhibh's Avatar
Most probably its the case of the fuel lid / fuel lid cap. Get it checked. Have experienced same but not in swift.
__________________
For every idiot there is an equal and opposite gender idiot. Singles are people with incomparable intelligence!
Old 4th November 2007, 00:12   #19 (permalink)
no mate pretty sure thats not it
windows are always kept up & the ventilation is closed to fresh air ::whilst i fill up
& of course the cars s off whilst filling up
cy
Old 6th November 2007, 03:41   #20 (permalink)
chetanhanda's Avatar
Originally Posted by cyneverdie View Post
hi people
got a petrol swift
any clues any body
on monday
cheers people
thanks again
cy
dude, this seems like a dangerous thing, I suggest u go to a dealership ASAP to see if they can figure out something.
But in the meanwhile does :
1]the smell of the petrol increase while the engine is running and car is stationary ? or it only comes while filling up with the engine off ?
2]If it comes while engine is runnig can u can u raise the hood and check if it is coming from the engine bay ?
3] Does it come from the rear of the car ?
chetanhanda is offline   Reply With Quote
Old 6th November 2007, 04:33   #21 (permalink)
hi the smell is due to the breather pipe of fuel tank blocked clean up the pipe the smell will vanish.
rags is offline   Reply With Quote
Old 10th December 2007, 17:56   #22 (permalink)
Team-BHP Moderator
Zappo's Avatar
All the similar threads have been merged into one. Carry on your discussion here.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Old 25th February 2008, 10:08   #23 (permalink)
planet_rocker's Avatar
i have the similar problem in my car since last 2-3 months. there is smell of petrol inside the cabin most of the time.
i have checked/replaced:
1. checked carb - no overflow issue - no leaks
2. replaced carb packing with a new one
3. cleaned jets / tightened bolts - w'atever.
4. opened the boot > tried to locate the source of the smell near the breather pipe - seems OK
5. removed the LHS rear wheel > checked the breather pipe there - seems OK
6. checked under-body / fuel line - there is no leak from anywhere.
7. replaced the fuel pipes (a. the one connecting to the fuel pump?? & b. the one connecting the fuel pump to the carb) with new ones.
i dont get the smell if i keep all windows rolled up.
the smell becomes prominent if i keep the front windows opened - but there is less smell if all 4 windows are rolled down - :
the smell comes only when the car is moving.
the car behaves absolutely normal - no hickups!
what should i do / check / replace?? i own a Padmini by the way
@ 1100D / Mr. Dhabhar / Karl / Gurus - any suggestions??
__________________
Planet, Sonja, ETC - "Elements of Life"
planet_rocker is online now   Reply With Quote
Old 25th February 2008, 10:14   #24 (permalink)
ram_hyundai's Avatar
Check for the smell in the airfilter case too.maybe you are running rich and the excess fuel would be pushed through the airfilter.have a long run and check immediately.You wont see the petrol anywere as it gets vapourised soon when the engine is hot,but you will get the smell for sure.
ram
__________________
Become MAD SOON and join the MON SOON Drive.
one more from me-
hey MAN come SOON for the MONSOON drive
ram_hyundai is offline   Reply With Quote
Old 25th February 2008, 10:57   #25 (permalink)
deetee's Avatar
In the case that the connecting tube from petrol inlet (where we fill fuel at bunk) to the petrol tank is made of rubber , do check that also. In my case , this rubber tube has become brittle with age and slowly developed holes . This will cause some leak every time you fill petrol and later one even vapours from tank also will escape through it , hence some petrol smell may also be found.
deetee is offline   Reply With Quote
Old 25th February 2008, 11:13   #26 (permalink)
ram
i doubt that the car is running rich - but i will get it checked. PUC is due on 29th Feb - so i will get the reading.
previously it used to smell after each fill for sometime. but now it smells all the time.
but dont you think that there will be smell in the boot if the fumes evaporate from the rubber pipe in the boot? there is NO smell if the car is stationary (with / without engine running) - PLUS - i said that if i keep all windows rolled up i Donot get any smell (stationary / moving) - it is quite difficult to get the smell from outside (obviously) - BUT i will check out the rubber pipe for sure
__________________
Old 25th February 2008, 12:12   #27 (permalink)
deetee's Avatar
Well buddy, you may not believe it, i never got the petrol smell into the car even with that broken tube-only once when i stood close to the car while refilling that i got some scent . But i ruled it out thinking it is normal in a petrol bunk . The broken tube was found only at the workshop when the car was hoisted for detailed checkup.I was startled and never allowed myself to estimate how much fuel i may have lost at refills and due to evaporation :(
Old 25th February 2008, 12:23   #28 (permalink)
ok - i will get it(also the breather pipe) re-checked / replaced.
i have also noticed that @ some pumps - the petrol spills out suddenly - but it doesnt happen always. has it got something to do with the breather pipe??
__________________
Old 25th February 2008, 19:29   #29 (permalink)
1100D's Avatar
There are a lot of factors to it.
For one I beleive its the carb itself. Does the smell come irrespective of the engine being warm or cold? Have you checked visually the area around the carb whilst the warm engine is running. I think its improper needle valve height causing the carb to overflow. I will give you a call, bear with me till then.
__________________
________________________
Every Ferrari is always a Fiat
1100D is offline   Reply With Quote
Old 26th February 2008, 09:48   #30 (permalink)
like i said the petrol spilling out thingy doesnt happen always.
i also think the same thing - even after changing the carb packing - there is a lil bit of petrol that seeps out from the packing part - my mech said its just moisture that forms normally
the smell comes when the engine is warm - i have checked while the engine is running - i couldnt find the source of the smell with the hood open. i also think that the needle valve height is the main culprit - i will get it checked.
__________________
Thread Tools
How does your car smell Neel Modifications & Accessories 73 21st May 2008 14:56
burning smell in car cabin harry2223 Technical Stuff 9 28th January 2008 16:50
Aromatherapy oil usage for making your car smell better arunkumar_rec Technical Stuff 13 8th December 2007 10:45
Bad smell after starting the car (NHC-2004) anandpadhye Technical Stuff 35 23rd August 2007 10:50
Beware of that new car smell amit The International Automotive Scene 3 28th September 2005 14:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
