Thread Tools
Old 1st October 2007, 09:52   #1 (permalink)
PatienceWins's Avatar
Default Thick oil for new car
I changed engine oil of my new getz at 2500 to shell helix 20W-50 mineral oil. Hyundai recommends 20W-40 for getz. Later I discovered that shell helix 20-50 is a thick oil, mainly suitable for older vehicles. On internet, I read that thicker oils are not good for new cars as it hinders the free flow of pistons and not good for run in of the car. Should I change my oil? If so, should I go for hyundai oil, i believe castrol or some other oil?
PatienceWins is offline   Reply With Quote
Old 1st October 2007, 10:47   #2 (permalink)
rjstyles69's Avatar
Hope you read this thread before you went in for an oil change.
If you are keen on changing synthetic oil , pick up Mobil 1 (5w50) or you could also try Shell Helix 5W50.
Shell 5w50 grade oil has become a rare commodity now. Last I checked 3/4 weeks none of the outlets had it and all I could find was 15w50 grade.
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
rjstyles69 is online now   Reply With Quote
Old 1st October 2007, 10:55   #3 (permalink)
DieselFan's Avatar
Please do not go for Synthetic oil till your engine has run in. Engine run in process would be incomplete if you go for Synthetic oil. Stick to the manufacturer recommended mineral oil till at least 10000 kms of run.
__________________
If you have not failed you have not tried enough.
Swift Diesel VDI - Feb '07 onwards
Santro LS- Mar '01-Feb '07(59000 KM) Sold.
DieselFan is offline   Reply With Quote
Old 1st October 2007, 11:19   #4 (permalink)
Thanks for your responses.
I had gone for shell mineral oil, not synthetic oil. My query is regarding the grade of the oil. Any issues with using a thicker oil on a new car?
I intend to go for synthetic only after 10000 km.
Old 1st October 2007, 12:42   #5 (permalink)
lordofgondor's Avatar
Hey PW, I believe its imperative that one sticks to an oil with the grade same as the one as suggested by the manufacturers. An oil with more viscosity might hamper a smooth running in of the engine components. But then, Castrol GTX, which is used for many of the petrol cars has the 20w-50 grade. So I don't think it would be a problem if you are using a Shell mineral oil of 20w-50 grade. Rest I would say is your call. Hope I haven't confused you more!
__________________
Not only is the universe stranger than we imagine, it is stranger than we can imagine!
lordofgondor is offline   Reply With Quote
Thread Tools
ARTICLE: Synthetic oil vs Mineral oil GTO On modifying a car 1013 14th July 2008 12:05
So.... why do we need those thick wires?? Sam Kapasi DIY - Do it yourself 103 26th May 2008 20:05
How to tell whether they really serviced the car(oil change) tsk1979 Technical Stuff 50 24th May 2008 11:41
Aromatherapy oil usage for making your car smell better arunkumar_rec Technical Stuff 13 8th December 2007 10:45
Need of new car Vs Peak Oil. subscrive Hatchbacks 3 25th July 2007 14:52
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
