Old 1st October 2007, 22:40   #1
adheesh's Avatar
Thanked: 35 Times
Post Changing Compression Ratio & Gear Ratio
Hi. I wanted to know if there is any (cost effective) way to change :
1. The compression ratio of an engine
2. Gear ratio of a car.
adheesh is offline   Reply With Quote
Old 1st October 2007, 23:19   #2
amitpunjani's Avatar
Thanked: 101 Times
Default compression ratio
The cheapest way to increase the compression ratio is by installing an another head gasket or else you could go overbore the cylinder liners. This would require complete overhaul of the engine.
amitpunjani is offline   Reply With Quote
Old 2nd October 2007, 00:15   #3
flipsyde's Avatar
Thanked: 62 Times
its not clear whether he wants to increase or decrease his compression ratio. installing another head gasket would only decrease the compression ratio.
shaving the head would effectively increase the compression ratio.
wats all this for anyway?
flipsyde is offline   Reply With Quote
Old 2nd October 2007, 00:21   #4
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
To increase CR of engine.
1. Shave head.
2. Use high CR pistons.
3. Use longer conrods.
4. Use a thinner head gasket.
To change gear ratios you have to change the gears with different ratios .
Old 2nd October 2007, 11:54   #5
Thanked: 54 Times
To increase compression get a higher deck piston , and to lower get a lower deck piston .
Old 2nd October 2007, 13:08   #6
adheesh's Avatar
Thanked: 35 Times
Exclamation
Thanx for the quick response. I would like to increase the compression ratio fRom 7.1:1 to about 9:1. Can it be done just by changing the header gasket ? Also would the changing of gear ratios require the replacement of whole gear box or just some off the gears?
Old 3rd October 2007, 00:15   #7
ananthkamath's Avatar
Thanked: 63 Times
7.1:1 hmmm...is this a Fiat we are talking about? If yes then shaving the head is the way to go. Yes, it is the most cost effective way.
ananthkamath is offline   Reply With Quote
Old 3rd October 2007, 09:54   #8
Thanked: 35 Times
Shaving the head as ananth has mentioned. If you can give the dimensions of the pistons maybe someone might be able to recommend some high comp pistons as well.
Changing of gear ratios would include changing of some gears & if need be the final drive and not the entire gearbox.
Is it possible to increase the compression ratio pratheesh Technical Stuff 30 10th April 2010 17:58
Second gen Gypsy (1000cc) compression ratio & oil consumption question xxaarraa Technical Stuff 1 19th November 2007 21:38
Variable compression ratio engine! amitoj Technical Stuff 8 20th December 2005 21:01
Compression Ratio and NOS Ford Rocam Modifications & Accessories 9 28th June 2005 03:13
Vtec's compression ratio!!! Shan2nu Technical Stuff 8 7th May 2005 23:07
