Thread Tools
Old 2nd October 2007, 20:47   #16 (permalink)
CrAzY dRiVeR's Avatar
2 wheel alignment.
  1. Angle readings are measured at all four wheels.
  2. The steering wheel is centered.
  3. Front wheels are referenced to rear thrust line and set to specifications.
Result: All four wheels are parallel and the steering wheel is centered.
4 wheel alignment.
  2. Rear wheels are set to specification. (Rear thrust line corresponds to vehicle centerline.)
  3. Steering wheel is centered.
  4. Front wheels are referenced to the rear thrust line and set to specification.
Result: all four wheels are positioned straight ahead and parallel, and the steering wheel is centered.
Q. What are the “symptoms” of a car that's out of alignment?
  • Excessive or uneven tire wear.
  • Steering wheel pulls to the left or right.
  • Feeling of looseness or wandering.
  • Steering wheel vibration or shimmy.
  • Steering wheel is not centered when car is moving straight ahead.
Source: What Everyone Should Know About Wheel Alignment
This thread gives info on independent rear suspensions
http://www.team-bhp.com/forum/technical-stuff/28649-why-car-makers-abandoning-independent-rear-suspension.html
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 2nd October 2007, 21:10   #17 (permalink)
IMP
I think cars having all wheel independent suspension need/have alignment on all 4 wheels. Other cars who have other suspension types at the rear do not need or maybe do not have adjustment at the rear. My optra got all 4 wheels adjusted the last time i got the wheel alignment done.
IMP is offline   Reply With Quote
Old 2nd October 2007, 23:41   #18 (permalink)
gemithomas's Avatar
does thAt mean that all cars with independent suspensions should get all wheels aligned. But on my adventure the guy sits towards the front of the car and does something in between the front wheels. ANd he gives me a sheet of paper with some values and colours!!!!!!!!
Oh. And a bill of around Rs.300/-
Can anyone get me the actual values. I cant find them in my manual. PLease also confirm if i need to get all four wheels aligned and how is this done exactly. I mean should he adjust anything t the rear also as he does in the front.?
__________________
"Our world is in its current state because of the choices WE made ...or failed to make"
Old 3rd October 2007, 00:00   #19 (permalink)
dustDevil's Avatar
In WagonR, i was pointed out that camber and toe could be adjusted. And an incorrect value of camber is due to worn parts!
Isn't the Mcpherson Strut suspension supposed to have a varying camber (that changes with suspension travel)? It is one of the basic differences between McPherson strut and a double wishbone setup.
__________________
Motorsport is the only 'REAL' sport.... all others are just Games!
Aalap Patel
'97 Zen
'88 RD350
dustDevil is offline   Reply With Quote
Old 3rd October 2007, 00:50   #20 (permalink)
rohan_fonseca's Avatar
Aren't cars with indepedent suspension suppossed to have their rear wheels aligned as well. Have never seen this happening at the tyre shops.
Are camber angles adjustable on a zen?
rohan_fonseca is online now   Reply With Quote
Old 3rd October 2007, 01:13   #21 (permalink)
ananthkamath's Avatar
All types of independent suspension are designed to have some camber gain as they compress. Wheel alignment can only change the static camber and not the camber gain rate.
Mcpherson strut is a low-cost alternative to double-wishbone and does not have favorable camber gain as the latter.
__________________
V8 POWER, BABY!!
ananthkamath is offline   Reply With Quote
Old 3rd October 2007, 01:53   #22 (permalink)
namit's Avatar
as per my checks Optra has an all wheel independent suspension so needs all 4 wheels to be alligned.
Aveo and Verna have front independent susp but torsion beam axle at rear which means allignment required only for front tyres.
Fiesta - Front suspension Independent MacPherson struts
Rear suspension Semi-independent twist-beam
Now what this semi independent suspension means dont know .......
namit is offline   Reply With Quote
Old 3rd October 2007, 03:48   #23 (permalink)
Which is a good place for wheel alignment in delhi? Because i got my Xing wheels aligned twice but not satisfied with the alignment, Steering has become harder than before, even the guy adjusted the center of the steering but to no avail. The guy told me to change the front tyres as they are wornout from inside.I have bridgestone S322 & they are just 26k Kms. Please advise what to do, i am also planing to get alloys.
singharry is offline   Reply With Quote
Old 3rd October 2007, 12:29   #24 (permalink)
iraghava's Avatar
The best place for alignment in Delhi is the petrol pump right after Ansal Plaza while coming from the South Ex side. There is a small garage at the pump which is reputed to be the best place for alignment.
__________________
Until you've lost your reputation, you never realize what a burden it was.
Old 3rd October 2007, 12:39   #25 (permalink)
kpzen's Avatar
Ishan
You mean the HP petrol pump right.
__________________
Prajesh
Pssssssh thE whisTling is gonna gEt Deadlier ..Coming Sooooon....;)
kpzen is online now   Reply With Quote
Old 4th October 2007, 09:36   #26 (permalink)
gemithomas's Avatar
i guess the baleno with all four mcpherson setup should be the ideal candidate that needs to have an alignment both at front and rear. Can owners confirm?
__________________
Old 4th October 2007, 09:47   #27 (permalink)
viper's Avatar
OHC has 4 wheel alignment or at least the Vtec does for sure as my car has it. Its is always advisable to do all 4 providing the car in question has/supports 4 wheel alignment.
Viper
Originally Posted by gbpscars View Post
good thread indeed.
a question:
when my friend's OHC went through a suspension bush change (both front and rear), he took it to a wheel alignment centre, and only the front wheels were aligned.
please let me know if this is right practice.
viper is offline   Reply With Quote
Old 4th October 2007, 12:28   #28 (permalink)
gd1418's Avatar
On the dot. Yes..it is the one
Ishan
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 5th October 2007, 04:35   #29 (permalink)
Thanks man, i will surely visit there.
Old 5th October 2007, 11:02   #30 (permalink)
gemithomas's Avatar
Is there no one who can help me with the actual values of each parameter on the FIAT Adventure!!!
__________________
Thread Tools
Wheel Alignment and afterwards Neel Technical Stuff 18 24th November 2008 16:58
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 22 13th September 2007 00:54
Wheel alignment query. ronline Tyre & Alloy wheel Section 8 8th December 2006 11:32
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
Questions on wheel alignment! DRC Tyre & Alloy wheel Section 14 29th September 2005 13:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
