Old 17th September 2011, 16:18   #31
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
Default Re: Swift ZXi/VXi Nippon Security System Question
Originally Posted by DieselFan View Post
Thanks a ton Biju the scanned document is most helpful. It is of lesser resolution hence is not very clear reading it on the system but if I take a printout it should be fine.
Let me know if the printout is clear and legible. If it is not, I will try to scan it at a higher resolution or try another method to post the manual.
pjbiju is offline   Reply With Quote
Old 18th September 2011, 20:40   #32
bigblackshark's Avatar
Thanked: 31 Times
Does anyone know how to pair a new remote with the system, I remember getting a new control unit when my last one was giving problems. The procedure was something like turn the key on then off and then press the valet switch for 2 times and then do something with your remote and then the other remote and it would activate. Till then the new one would not work, and you can only use your key directly.
If anyone knows the procedure please post the same, as it would help users who would get a new remote and the nippon service advisor forgot to set your other remote for you
bigblackshark is offline   Reply With Quote
Old 8th October 2011, 01:41   #33
nisarg86's Avatar
Thanked: 12 Times
Can anyone help me out with resetting the security system ?
Thing is from last 4-5 days whenever i unlock i get 3 chirps instead of 2.
I have read the manual and according to manual it says Door/Trunk Intrusion. Visual Led Should be 3. which is glowing whenever i unlock.
Now how do i reset it ?
nisarg86 is offline   Reply With Quote
Old 8th October 2011, 10:47   #34
vikram_d's Avatar
Thanked: 940 Times
There is no reset function for the security system. If your car is giving 3 chirps while locking that means one of the door switches is malfunctioning. Check the bonnet switch. I faced similar problems because of the bonnet switch not getting engaged properly.
vikram_d is offline   (1) Thanks Reply With Quote
Old 8th October 2011, 18:06   #35
anky's Avatar
Thanked: 107 Times
Talking Re: Swift ZXi/VXi Nippon Security System Question
For my alto nippon 2 button security turn the car on / off rapidly six times then press I no button on the remote , you will get conformation beep then remote is paired . By On/Off i do not mean starting the car and shutting it but just put key to ign ON pos then OFF six times .
anky is offline   (1) Thanks Reply With Quote
Old 8th October 2011, 18:14   #36
ankurvirmani19's Avatar
Thanked: 76 Times
1. The doors get unlocked when the key is removed from key cylinder. Nothing happens in case if ignition is turned off.
2. When the key is in cylinder, the remote stops working.
I think you should get your Nippon CSS checked by authorized agent, it may be a programming fault.
ankurvirmani19 is offline   Reply With Quote
Old 8th October 2011, 22:16   #37
anky's Avatar
Thanked: 107 Times
Red face Re: Swift ZXi/VXi Nippon Security System Question
you have the newer nippon system if you call the nippon service centre he will tell u how to pair the remote . That is how I came to know .BTW 6 times on off means just that switch on off rapidly without starting the car or removing key from ign then the car gives a beep after the sixth time then you press I key on the remote then one acceptence beep then paired .
anky is offline   Reply With Quote
Old 10th October 2011, 01:29   #38
nisarg86's Avatar
Thanked: 12 Times
vikram. solved it. it was indeed bonnet switch. thanx.
Old 11th October 2011, 13:16   #39
DieselFan's Avatar
Thanked: 234 Times
For the benefit of folks who have Nippon NCS-099 car security system. I detail out how to pair the remote with the security system.
1.Open the door of the car (after disarming it )and keep it open.
2. insert the key and switch it on then off and then again to on position (do not start the car)
3. Press and release the in car security switch once.(in Car Switch that you normally use for programming)
4. Now again press and hold in car security switch
5. you now hear a beep
6. Press the remote (The one that you want to pair) lock button while holding the car security switch. release the security switch.
7. turn the ignition key to off and on and then to off.
Walla the remote in now successfully paired with the car security system.
DieselFan is offline   (3) Thanks Reply With Quote
Old 11th March 2012, 09:54   #40
SuperBee's Avatar
Thanked: 61 Times
I have a Swift Vxi with NCS-099 fitted by the dealer. Of late, the Siren has stopped working. The security system all works without problems, immobilizer et al. But there is no sound/no chirps. Before I give it to MASS, I wanted to check it out myself if the connections to the Siren are loose, but i'm unable to find the Siren.
Can anybody here help me out with the possible location of the Siren?
Thanks.
Raghav
SuperBee is offline   Reply With Quote
Old 11th March 2012, 10:28   #41
vikram_d's Avatar
Thanked: 940 Times
The siren hooter is normally placed right behind the battery. Looks like a smaller version of the megaphone.
Old 11th March 2012, 11:06   #42
SuperBee's Avatar
Thanked: 61 Times
Found and fixed. Never would have guessed that black thing would be the Alarm Siren. Thanks.
The wire coming from the hooter was disconnected, took me some time find the wire it was supposed to be connected to. I guess it was removed when i had given it for AC servicing.
Thanks.
Raghav
Old 25th August 2012, 21:45   #43
amitpunjani's Avatar
Thanked: 101 Times
Default Re: Sx4 Zdi Security Led not blinking
Hi People,
I have a bit of concern, the security switch light LED light is not blinking, even when the doors are locked. Read the manual but its dam confusing
Awaiting for your valuable inputs.
Amit
amitpunjani is offline   Reply With Quote
Old 18th December 2012, 15:32   #44
Thanked: 30 Times
My 2005 swift ZXi came with nippon security system preinstalled. I have both the remotes working except that the buttons are gone. Is it possible to just change the case & keep the remoted intact. pls suggest.
ravigop is offline   Reply With Quote
Old 18th December 2012, 17:05   #45
vikram_d's Avatar
Thanked: 940 Times
It should be possible assuming they are willing to sell just the case as a spare.
Help required on nippon security system in my SX4 ZXI premanshu Modifications & Accessories 4 22nd December 2015 16:15
Swift Vxi Nippon Security system - Issue? iamswift Technical Stuff 7 19th May 2011 08:38
SX4 - Mid term review at 4000km and How to (Nippon Security system) car-go Long-Term Ownership Reviews 12 23rd December 2009 14:31
How good is Maruti MGA Nippon Security system? lordofgondor Modifications & Accessories 17 26th June 2007 20:00
