Closed Thread
Old 4th October 2007, 04:02   #1
Default best gear oil & best coolant & best engine decarb: please
Mod Note : Please continue the discussion in our Engine Decarbonisation Article (Engine Decarbonising - Demystified). Thanks
hello people
i need to know whats the best gear oil i can buy in mumbai at least.
drive a petrol swift done 12000 odd , time to change
also the best coolant ??
OWS makes a coolant not sure of it
i have been using wurth's "new formula for tropics" coolant
anybody on SHELL s coolant or its gear oil or brake oil ??
check it out at
Shell in India - Shell Specialties
plus no help on my engine decarb scenario
bardahl's "powetune" anyone??
please do read my last thread
http://www.team-bhp.com/forum/techni...powertune.html (OWS Vs Mobil 1 + best engine decarb [ Bardahl's Powertune ?])
thanks in advance
cheers people
Cy
Last edited by GTO : 13th March 2013 at 12:00. Reason: Adding link to decarb article
cyneverdie is offline
Old 4th October 2007, 11:34   #2
gd1418's Avatar
Thanked: 656 Times
Castrol EP80W-90 ( Mineral based extreme pressure, multi-purpose gear oil, containing anti-oxidant and anti-corrosion additives )
Coolant - Golden Cruiser Premium
Engine decarb - STP
Originally Posted by cyneverdie View Post
hello people
check it out at
thanks in advance
cheers people
Cy
gd1418 is offline
Old 5th October 2007, 04:48   #3
Engine Decarbonizing Machine Manufacturer,Engine Decarbonizing Machine Exporter,Engine Decarbonizing Machine Supplier India
this sounds good
as well as the injector testing
Is what i am looking for
viper suggested the pump near Muchad Paan [ mumbai ]
see the scene there later in the day
buying 12 lts of mobil1 5w50 [ Rs 9800 ] from official mobil 1 india guys
Lubricants
buying the OWS engine flush & k&n oil filter
planning to decarb the car later today
decarb
flush
change oil & filter
re clean injectors
re oil k&n air filter
change gear oil : waiting for some mobil 1 synthetic to come
flush & change coolant : wurth or shell
maybe change my plugs OWS are not available for the swift now in mumbai
bosch fuel filter and advanced carbon cabin air filter sooon
then i move to my brakes...
cheers
Old 5th October 2007, 19:13   #4
nitroxx's Avatar
Thanked: 26 Times
i use mobil 1 delvac engine oil, castrol gear oil with bardahls treatment and once every 2500 kms go for an injector cleaner from abro that should do it..
nitroxx is offline
Old 5th October 2007, 19:41   #5
n_aditya's Avatar
Thanked: 2,781 Times
guys, my esteem has run 45K kms in the last 5 years with 4 trackdays of spirited driving included. Do i need to decarb my engine or is it unnecessary at this time? There are no issues with acceleration although i feel the FE has reduced a wee bit.
I'm also going to get synthetic oil for her in a weeks time.
Just want to know if its ok to go for a decarb or wait for some more time.
n_aditya is offline
Old 6th October 2007, 04:14   #6
at least i would do the following
50 000 km tune up
decarb your engine [ check out Engine Decarbonizing Machine Manufacturer,Engine Decarbonizing Machine Exporter,Engine Decarbonizing Machine Supplier India ]
flush out your engine oil { use a flush i say OWS}
machine check & clean your injectors
clean throttle body
flush radiator
change gear oil
clean/put in a k&n air filter
fill up mobil 1 5w50 api sm :: improved engine leak additives hence suitable for older engines
change oil filter too go k&n
change fuel filter : i like bosch over purolator
change spark plugs [ OWS ]
also before you decarb
its important
dump a bottle of sonax fuel system cleaner in your car to neutralize any acidic water etc run that full tank dry ; fill up then go thru the above procedure
trust me you wont regret it.
rock on
cy
check out
http://www.marspetrochem.com/pdf/Mob...ynBrochure.pdf
Vitamins for your car
15. Can I use Mobil 1 in older vehicles with high mileage?
Yes you can. Mobil 1 can help increase the life of all engines, even those in
older vehicles and/or with high mileage. The extra cleaners in Mobil 1 can
help clear stuck rings to help restore engine efficiency. Keep in mind,
however, that Mobil 1 cannot correct an existing engine problem
Old 6th October 2007, 07:23   #7
DieselFan's Avatar
Thanked: 234 Times
After 45K it is always advisable to go for Engine flush before you change to synthetic oil to avoid sludge formation after changing to synthetic.
DieselFan is offline
Old 19th October 2007, 03:57   #8
Engine decarb - STP
hmph
""Engine decarb - STP"" : do you know what a decarb is man?
i dont think so
but cheers for the info anyway
cy
Closed Thread
OWS Vs Mobil 1 + best engine decarb [ Bardahl's Powertune ?] cyneverdie Technical Stuff 3 20th June 2012 18:50
P150 Engine Decarb at 22K kms _abhishek Motorbikes 6 14th June 2010 17:34
