Old 4th October 2007, 17:40   #1
Thanked: 327 Times
Default Battery for Alto LXi 2003 Model
Hi guys,
My Alto LXi is abt 4 yrs old on the stock battery. think its time to change it coz having rare cold start issues (after 3-4 days of "no-use")
Which would be a good battery? i think the stock one is a Standard Furukawa.
How much wud it cost ? and where shud i get it from in Delhi?
P.S: i was out on the road last Friday when it rained like hell in Delhi. My car went thro knee-deep water. I drove in 1st gear and had to revv up in 1st for like 5minutes. it seemed as if the engine wud die (due to the water-level) but it didnt.
I have driven the car twice since Friday; it seeems to b running fine..
Shud i get it checked anyways..?
BUXX is offline   Reply With Quote
Old 4th October 2007, 18:09   #2
Hello BUXX,
Yes you are right its time to change the battery, go for the OEm specs, not necessarily the OEM brand.
Just note down capacity (in Ah..eg 12V/45Ah written on battery), use same spec & search for a brand which suits your: Pocket, warranty expectation & service.
If the water was below air intake(which obvios was as engine didnt died), there is no need for major check-up. Just get it cleaned with pressurised water, including radiator & a/c heat exchanger fins. And ofcourse underbody to get rid of slush.
arunforu1 is offline   Reply With Quote
Old 5th October 2007, 09:50   #3
Thanked: 327 Times
Originally Posted by arunforu1 View Post
Hello BUXX,
^^it DID sputter for a moment there..
i revved it and it didnt die tho..
I am getting that pressurised was asap tho.. was thinking of gettin it done but then just got lazy..
Thx for the reply arun!
Old 5th October 2007, 10:27   #4
anandtheleo's Avatar
Thanked: 208 Times
Hello Buxx,
I changed the battery to my Alto just a few weeks back. I got myself a Amaron Hi-life. It costed me 3200 after exchange of my old battery. It comes with 36 months pro-rata warranty.
Anand.S
anandtheleo is offline   Reply With Quote
Old 5th October 2007, 19:47   #5
Well a momentarily sputter was due to higher back pressure, caused by exhaust pipe immersed in water.More important is not letting engine stall while fording through water & keeping air intake above water level(if possible exhaust too). Engine will experience back pressure if tailpipe is immersed in water, but if you revv it hard, exhaust pressure is powerfull enough to keep water out of system.
So you did right thing by revving it hard.
Old 5th October 2007, 20:46   #6
im_srini's Avatar
Thanked: 398 Times
Hi Buxx, I had an odd problem when I bought myself a new battery for my Alto. The placement of the terminals on the battery matters since the new battery had a different terminal placement than the old one. Because of this difference, the negative terminal strap could not be connected ! The switch was finally made by relocating the negative terminal itself, i.e. the spot where it is connected to the frame...
And here I was thinking it was going to be a simple 2 minute job
im_srini is offline   Reply With Quote
Old 5th October 2007, 21:00   #7
n_aditya's Avatar
Thanked: 2,780 Times
Check out these threads :
http://www.team-bhp.com/forum/techni...ery-brand.html
http://www.team-bhp.com/forum/ask-gu...hat-brand.html
Old 6th October 2007, 00:36   #8
mail4ajo's Avatar
Thanked: 261 Times
Whats a prorata warranty?
mail4ajo is offline   Reply With Quote
Old 6th October 2007, 17:12   #9
Thanked: 208 Times
Well the warranty is broken up in 2 parts 18+18 months. In the first 18 months if the there is a problem with the battery and its not serviceable then its replaced free of cost. But if the battery goes kaput after 18 months, say at 22nd month then if we buy a new Amaron battery we would be charged only 40% or so of the new battery and this %age increases as the age of the battery increases (at 32 month we may have to pay 80% of the new battery cost). Hope this explains it.
Anand.S
Old 19th October 2007, 13:29   #10
yasw_anth's Avatar
Default battery capacity for zen 2003
hi ,
my car's stock battery(exide) nearing its end.just installed a sub yest and the battery charge was down(orange light in the battery) today! my mechanic said stock battery has capacity of 12v.38amps and the capacity shouldnt be changed . im using 100/90 bulbs,hella fog lamps and now sub setup,can i change to battery with increased amps(38amps++ ) ? increasing the capacity requires a change in alternator . etc ? what will be the ideal battery capacity for my car . plz help guys , require changing the battery soon ..
yasw_anth is offline   Reply With Quote
For sale- Fully Loaded- ZEN LXi 2003 ..With 11 month MYTVS warranty. shapath Shifting gears 0 8th December 2007 00:40
Baleno lxi 2003 sankeerthreddy Sedans 2 6th November 2006 00:10
Baleno Vs Lancer (2003) model naveendhyani Sedans 16 19th April 2006 06:10
