Old 13th October 2007, 10:43   #16
Thanked: 253 Times
Also, you probably know this, but its reccomended that alloy wheels are retorqued once again 100km after fitting the wheel back on.
cya
R
Could you kindly provide the source? Was not aware of this and am keen to know the reasons why it is so. Is it because because alloys are softer material?
Old 19th October 2007, 03:46   #17
Tightening torque for wheel nut
85 Nm (8.5 kg-m, 61.5 lb-ft)
for the swift
swift's manual is nice
got the torque for its wheels , oil filter , oil drain plug , spark plugs , gear oil plug , drive belt & ac belt tension
Make sure the drive belt tension is correct.
If the belt is too loose, insufficient battery
charging, engine overheating, poor power
steering, poor air conditioning, or excessive
belt wear can result.
+clutch steering & brake play
thats a goood manual
cy
cyneverdie is offline   Reply With Quote
Old 10th October 2012, 17:27   #18
el lobo 6061's Avatar
Thanked: 1,013 Times
Default Re: Torque Wrench help needed
Hi all,
I want to purchase a torque wrench for my car VW Vento TDi which has a torque rating of 120 NM(User Manual). Bhpians can you suggest a shop from where I could purchase the same in Mumbai or Navi Mumbai and what is the approx price of a torque wrench?
Saw some pics which show that end of torque wrench is a square shape and to which we need to attach a attachment so as to tighten the nuts on wheel. Can you all confirm the same. Excuse me for the layman language.
Thanks.
el lobo 6061 is offline   Reply With Quote
Old 10th October 2012, 18:03   #19
vikram_d's Avatar
Thanked: 940 Times
Originally Posted by el lobo 6061 View Post
Hi all,
Thanks.
Contact Macmaster India on the URL below and enquire about dealers in your area.
http://macmasterindia.com/contactus.html
The model number of the torque wrench suitable for you requirement would be the TW-160 from the Macmaster catalog.
Edit: Most reputed auto spare parts dealers also normally sell torque wrenches. Make sure to buy a good make like Macmaster or equivalent. Stay away from the Chinese makes even if they are dirt cheap.
vikram_d is offline   (2) Thanks Reply With Quote
Old 11th October 2012, 01:17   #20
Thanked: 29 Times
Your requirements suggest, you want to use pneumatic wrench for rundown(until thread base contacts with the mating surface), and use callibrated wrench for threshold torque.
1. For commercial applications, it is best to use electric screwdriver with controller( example: Atlas Copco), using which, you can specify all limits, and achieve desired torque values.
2. When new nuts are screwed on and final torque is applied, there is thread extension and pitch of the threads change. On reapplication, this will affect final Torque values, and over Torquing might make the threads to slip and the joint to fail.
cawnpore ghost is offline   (1) Thanks Reply With Quote
Old 11th October 2012, 15:31   #21
Thanked: 52 Times
Originally Posted by Nikhilb2008 View Post
Thanks to a post on t-bhp by Dieselfan, my dad and me want to use Torque wrenches in our shops.
So, what we thought was to calibrate the different settings on the pneumatic gun using a torque wrench.
What am I supposed to do ? any other suggestions ?
Or is there anyway of using the Torque Wrench to check each nut after fitment has been done ?
Is it possible to get the correct torque by controlling the air pressure?
Like have a small bleed value to control air pressure
T1000 is offline   Reply With Quote
Old 11th October 2012, 21:40   #22
Thanked: 8,937 Times
Just some thoughts of a newbie to the Indian car scene.
I have no experience (yet) here in Delhi, but I've lived in several European countries and the last three years in Kansas City USA. Do most of maintenance and repair on all my cars myself
Any (western) professional garage will always use a pneumatic wrench to get the wheel bolts tightened quickly, but will also alway use a proper manual torque wrench to properly torgue the bolts individually. Unless you invest in very fancy pheumatic or electrical wrenches where you set the correct torque, this is the only way to do it.
You need to figure out, either the setting or the time you use your pneumatic gun that gets you tongued to about 60-70% of the recommended value. From there on use a manual precision torque wrench. It will only turn a little bit from there on.
On the matter of using oil/lubrication etc. If the manufacturer manual doesn't mention it specifically don't use anything! In nearly all cases bolts and rim should be dry, free of dirt and grime. Again, unless specified otherwise.
Bolt/nuts should be able to turn freely by hand, or at least with very little resistance initially. If not, clean/fix the thread first.
On the matter on checking the correct torque after 50-100 kilometer. Recommended as a common practice for most western countries, although admittedly very few actually get around to it. In the US if you go to a "quick fitter" to get some new tires, you will need to sign a form which stipulates you need to do so. Because if they don't point it out to you and something happens you could sue them! Welcome to the good old USA!
What you actually do; just take the manual torque and redo all bolts. You don't loosen them, you just put the wrench on it and torgue it again to the prescribed vallue. The idea here is that there might have been some dirt and or slack when you initially bolted the wheels back on. After a little driving that might settle and you need to retighten the bolts to their prescribed torque settings.
I've always done so, but I dont think I've ever seen a bolt or nut move on the re-torqueing. But still, better save than sorry.
Once, I had my Alfa Romeo Spider wheels re-alligned and at my request they also swapped the wheels back to front. Easy to do, once on the ramp. When I got home, two of the wheel bolts where half out. They used the air gun, but forgot to torque one set of wheels! So they were professional enough to always manually torque, but made an honest mistake. Still, could have been a bit of a problem if the whole wheel came off.
How important is torqueing properly? Well, many different opinions, on this forum as well it seems. Over torqueing can lead to damage to the bolt/thread and worst case the rim. So from that point of view it makes a lot of sense. Too loose and you might loose a wheel. See my experience, although that was a case where the bolts were never set properly to start with
Being a former Marine Engineer and having worked on very large diesel engines I adhere rigorously to proper torqueing of any bolt/nut on any engine for that matter.
For instance proper torque setting and procedure on a cylinder head will be the difference between no problems and more or less immediate problems. My personal belief; lot of people don't think torqueing of wheel nuts is of any real value. Fact is that most wheel nuts get overtightened. From a safety point of view that's no problem. (in most cases)
It does become a problem when you have a flat, in the middle of the night, rain pouring down, in the middle of nowhere and you find out that your car toolset consist of a pathetic little wrench that starts bending the minute you point it at the wheel bolt. Then you wish you'd used a proper torgue wrench because you might have stood a chance undoing the bolts!
By the way, I carry a proper set of tools in each one of my cars all the time.
So you could debate the value of torgueing the wheel bolts perhaps. I'd say, from an engineering/professional point of view, you should always do it.
Jeroen
Jeroen is online now   (2) Thanks Reply With Quote
Torque vs BHP? souled Technical Stuff 205 23rd May 2018 11:04
Urgent help needed. please help-Santro Xing not starting iron.head Technical Stuff 3 12th May 2012 08:27
About Gear Ratios & their Relation to Tyre OD, Torque, Speed etc speedsatya Technical Stuff 90 8th April 2008 11:50
12v Impact Wrench for changing Tyres - Opinions please. s0uljah Tyre & Alloy wheel Section 4 14th April 2006 19:53
Impact Wrench powered via Cigarette lighter, Opinions? s0uljah Modifications & Accessories 1 14th April 2006 00:03
