Thread Tools
Old 5th October 2007, 17:39   #1 (permalink)
moralfibre's Avatar
Default Skoda Octavia: Should the entire panel be replaced or not
This is the damage. There are two options. Mend the panel and make it factory finish OR replace the entire panel that includes: wheel arch, door frame top, B-Pillar, A-Pillar and a straight panel behind the front right fender.
Reason for the query, the accidents department in charge told me that the entire one piece panel is welded and is a part of the monocoque. Welding tools at the body shop in a dealership body shop differ vastly from what are used in factory assembly lines. This panel hasn't taken much of a knock to consider replacement but if we insist he can do it for us. He suggested that the panel be mended without taking it out. Please advise what would be right approach?
__________________
"As long as there are short, balding, middle-aged men, there will always be a market
for the Porsche 911." - A BMW Owner. :)
Last edited by normally_crazy : 11th October 2007 at 12:58. Reason: Pictures added
Old 5th October 2007, 17:43   #2 (permalink)
mithun's Avatar
I think the panel can be mended up. But it may not look gorgeous as a replacement.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 5th October 2007, 17:46   #3 (permalink)
Rtech's Avatar
Replace the door. Fix the panel. It's not bad enough to cut through. And if the service centre themselves are not confident of doing a good job, there really is no debate on this.
A good job fixing the panel and a good paint job later, you will not be able to tell the difference.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 5th October 2007, 18:06   #4 (permalink)
kunal2202's Avatar
Bingo!!! i agree with Rtech!! and i have witnessed ppl doing wonders with crashed bodies.
__________________
KS.....
Racing is a matter of spirit not strength
.....Race your Spirits
kunal2202 is offline   Reply With Quote
Old 5th October 2007, 18:18   #5 (permalink)
quicksilver's Avatar
Replacement sounds messier compared to mending the panel in your case. I do not think the damage is going to be vey hard to mend. Like Robin says, replace the door and mend the panel.
An added advantage, you can claim full insurance for labour costs hence mending the panel may work out to be a better option if you are claiming insurance.
__________________
The world looks different after 5000 RPM in my rear view mirror!
quicksilver is offline   Reply With Quote
Old 5th October 2007, 18:43   #6 (permalink)
moralfibre's Avatar
Its not cut through, its just crumpled which is why the accident dept. incharge recommended repair. He is confident of doing a good job but warned me about the welding part. He says it can never be done to factory standards (at least the welding part) when done in a body shop of ANY dealership.
I saw a Skoda Rider with a changed panel and roof which looked horrible because I saw the welding spots all over. I'd suggest repair against replacement too. He has assured that we wouldn't be able to make out the difference.
Door is going to be replaced. Running board repaired and as you guys suggested, I'll ask him to go ahead with repair than replacement. I'll post pictures of a replaced side panel of a SMASHED Skoda Rider with a blown roof. I have pictures of the smashed panel too. It looked very messy to me.
Thanks for the suggestions.
__________________
Old 5th October 2007, 18:49   #7 (permalink)
viper's Avatar
I agree with RT's suggestion. That is what I would do as well and had communicated to NC directly as well.
Viper
viper is offline   Reply With Quote
Old 5th October 2007, 19:30   #8 (permalink)
horsepower's Avatar
I think there is no need to replace the panel. Any good accidental repair workshop can make dent it back to the original shape.
horsepower is online now   Reply With Quote
Old 5th October 2007, 19:39   #9 (permalink)
V-16's Avatar
I too agree with Viper and Rtech. Thats the way to go!!
__________________
Dear God, Why Is Life So Unfair??!!!!
V-16 is offline   Reply With Quote
Old 5th October 2007, 20:17   #10 (permalink)
shrivz's Avatar
No point welding a new panel, repairing it is the way to go!!!
__________________
Don't part with your illusions. When they are gone you may still exist, but you have ceased to live.
Mark Twain
shrivz is offline   Reply With Quote
Old 5th October 2007, 21:35   #11 (permalink)
Ram
Ram's Avatar
I did once have my Maruti 800's entire quarter panel with integrated C-pillar, roof section and A-pillar replaced for a silly 30 mm x 150 mm gash.
In the case of my Maruti 800, it meant buying a new entire sheet metal component (including A, B, C1 and C2 pillars), worth Rs. 6,700, cutting away and discarding some sheetmetal, plus tinwork and painting, plus the rubber gasket around the rear quarter glass. A total damage of Rs. 9,000+ in Jan 2006.
But then it was a tinfoil Maruti 800 not a Skoda Octavia.
Replacing is nevertheless the brute-force solution. It's throwing money at the problem.
Meant for countries where labor is too expensive and workers have more overpaid attitude than skilled craftsmanship.
But, surely in the country of the Taj Mahal, there would be master-craftsmen, brazers and tinkerers who could do an excellent job. It won't be in the overpaid megapolises, though, I suspect.
__________________
On Google Chrome 0.2.149.27 since Tue. 02-Sep-2008.
When you struggle for something and fail, that’s when you get Experience!
Ram is offline   Reply With Quote
Old 6th October 2007, 02:52   #12 (permalink)
moralfibre's Avatar
Secondly Ram, don't you think resale value of the car will go down for a replaced panel once someone gets into the service records? A replaced panel points to a major accident which this car hasn't been suspected to.
__________________
Old 6th October 2007, 08:55   #13 (permalink)
Ram
Ram's Avatar
I'd imagine, not too many people in India ask to see, nor get to see, complete service records.
And suppressing incriminating evidence is the done desi thing.
So why worry?
And I'm sure Skoda dealerships would have tons of good sheet metal, perfectly complete good doors, etc. from other crashed Octavias, that the unscrupulous ones might palm off as new.
Skoda quality being so good, it would be hard for the untrained eye to distinguish between pristine sheet metal and sheet metal from a good Octavia that was totalled on (say) the other side.
That said, I'm sure there are good dealerships and bad dealership to get accident work done.
All Skoda bodyshops were not born equal. Some time invested in finding the right bodyshop, will doubtless, pay off in the results.
Ram
__________________
Old 6th October 2007, 09:19   #14 (permalink)
kpzen's Avatar
MF
I'm not able to view the pic but i assume the talk is about replacing the quarter panel.
It depends on how the quarter panel is fixed by the bodyshop ppl. If they cut the quarter panel from the original joints n fix it there then it can be found out if the quarter panel has been changed or not.
Normal procedure is not to mess with the original joints unless there's damage near the pillar or the running board.
__________________
Prajesh
Pssssssh thE whisTling is gonna gEt Deadlier ..Coming Sooooon....;)
kpzen is online now   Reply With Quote
Old 6th October 2007, 10:28   #15 (permalink)
vid6639's Avatar
MF
yup, me too. Cannot see the picture at all. MF can you please upload it again?
__________________
I live my life a quarter mile at a time. For those ten minutes or less, I'm free and nothing else matters.
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Thread Tools
New Skoda Octavia abhinav.gupta88 The Indian Car Scene!! 30 5th December 2008 18:04
Skoda Octavia RS navin Test-Drives & Initial Ownership Reports 72 22nd December 2005 01:13
Skoda Octavia sbfx Modifications & Accessories 24 31st August 2004 17:17
New Skoda Octavia thehondaguy The Indian Car Scene!! 21 13th July 2004 18:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
