Old 15th October 2007, 18:46   #16
nitrous's Avatar
Thanked: 285 Times
Originally Posted by crazy diablo
These are adjustables right? How do you adjust it once fitted?
Like a tap, clockwise for stiffer and anti-clockwise for softer.
Old 16th October 2007, 17:26   #17
im_srini's Avatar
Thanked: 398 Times
Hi guys, having sport struts from Pedders fitted to my car on Thursday (18th) ! The only thing is that Pedders apparently do not provide appropriate springs for my car, a Alto Vxi. So the plan is for Electra to fit the struts on Thursday, & then to source compatible springs in the coming weeks...
im_srini is offline   Reply With Quote
Old 18th October 2007, 01:39   #18
guys...get blistein or koni...they are the best in this business. dont even think of getting any other brands.
sanchits is offline   Reply With Quote
Old 18th October 2007, 20:59   #19
crazydiablo's Avatar
Thanked: 21 Times
These are externally adjustable shocks, but my question was how would you access the rear shocks.
Just came to know that you need to remove the rears and then adjust it. I guess that answers the question....need to be doubly sure of the settings.
crazydiablo is offline   Reply With Quote
Old 18th October 2007, 23:41   #20
rjstyles69's Avatar
Thanked: 795 Times
Where is eapen now ? Can some-one post the costs involved please.
rjstyles69 is online now   Reply With Quote
Old 24th October 2007, 09:10   #21
islandman's Avatar
Default Eapen - Missing in Action
Right , Eapen where art thou? There are many baleno owners in this forum waitin to see your install....
islandman is offline   Reply With Quote
Old 31st October 2007, 08:38   #22
I am in New York, USA - so the install would take sometime.
eapen is offline   Reply With Quote
Old 31st October 2007, 18:01   #23
im_srini's Avatar
Thanked: 398 Times
Hi guys, I'd upgraded from my 7 year old stock struts to Pedders stock replacement struts last weekend. I'd asked for the Sports Ryder, or the VRD struts, but apparently they're not available for my car (an Alto VXi). I'm told the Pedders are 40% stiffer than stock, & I can feel it. Road-holding seems to have improved noticeably, & the struts seem to have solved other issues I had with the car too, like front-end vibrations while moving off ! In terms of handling, I "think" there's an improvement, but will know for sure only after a "pay & practice" session at the MMST track.
Now for the sad part, the stock springs remain ! Pedders do not make springs for the Alto :( I'm trying to source stiffer springs, but it could take a couple of months - at the least. The question that rankles within me is, would these stock replacement Pedders be sufficient for track use ? Should I go for Koni instead ? In case of Koni, I believe, the stock struts are gutted, & the internals replaced by Koni (Yellow ?) strut internals.
I would also like comments on running stiffer sway bars. I remember reading that the WagonR & the Alto share the same platform, & that the WagonR runs stiffer springs & sway bars to account for it's "tall-boy" design. Is this true ? If so, what are the things I should watch out for if I replace the Alto's springs & sway bars with the ones from the WagonR ?
Old 31st October 2007, 20:16   #24
nitrous's Avatar
Thanked: 285 Times
SAP found a quite a difference in his handling after replacing only his springs in his corsa sail.
Old 1st November 2007, 19:26   #25
im_srini's Avatar
Thanked: 398 Times
Hi Nitrous, it was SAP's comments which inspired me to go with a stiffer setup from Pedders. However, in my case, I was forced to upgrade just the struts, the springs are stock ! The stiffer springs from Pedders are, apparently, incompatible with my car.
I did see on the Pedders website that they carry stiffer springs for the WagonR though. Since my car shares the same platform, emailed them if it would suit my need - haven't got a reply yet. Another option, of course, is to switch to stiffer sway bars, which is why I'm looking at the ones in the WagonR.
Old 2nd November 2007, 20:53   #26
shazikon's Avatar
Thanked: 19 Times
Default How to install koni strut inserts
Found this nice link.. thought of sharing with you guys! Its so DIY...we tools are available
Installing Koni Strut Inserts
shazikon is offline   Reply With Quote
Old 29th January 2008, 22:29   #27
rjstyles69's Avatar
Thanked: 795 Times
**bump**
Eapen was the setup completed ?
Old 29th January 2008, 22:42   #28
Mpower's Avatar
Thanked: 1,687 Times
Measure the OD of both the bars...that will tell you how much stiffer the WagonR bar is.
Old 16th June 2008, 04:00   #29
v1p3r's Avatar
Thanked: 27 Times
Just put some DMS coilovers on the Baleno, and the difference is mindboggling. Of course, the stiffness is now on par with a train, but it's still something else in a corner.
Old 16th June 2008, 10:50   #30
shuvc's Avatar
Thanked: 287 Times
These are a direct fit on the Baleno? Plug and play?
Cost?
Baleno with koni yellows spider77 Modifications & Accessories 4 6th April 2012 09:43
Info required :KONI shocks speedbuster Modifications & Accessories 6 22nd June 2010 13:20
kONI shocks on ZEN sameer_dg Modifications & Accessories 8 26th November 2006 19:27
Gypsy suspension: KONI? COUGAR Modifications & Accessories 7 23rd June 2006 12:25
Please Help..Looking For Koni Sport Dampners In MUMBAI Tool Modifications & Accessories 6 18th May 2006 14:56
