Old 17th June 2008, 01:17   #31
v1p3r's Avatar
Thanked: 27 Times
Direct fit. No cutting/pasting anything. Cost is mentioned in the link. Please add 50% for shipping and duties.
Old 30th September 2008, 09:18   #32
crazydiablo's Avatar
Thanked: 21 Times
Default Koni Part number
Eapen, whats the update on this man? How can you sit on Konis and not fit it?
Whats the part number for these struts? Can we order it directly from Koni?
crazydiablo is offline   Reply With Quote
Old 30th September 2008, 10:26   #33
iceman91's Avatar
Thanked: 22 Times
They are available in bangalore for 34k from methods just inserts.
Directly from Koni will be a parallel import since they have representatives in India
iceman91 is offline   Reply With Quote
Old 30th September 2008, 19:00   #34
Thanked: 21 Times
I am thinking that it will be much cheaper if we buy it in US and someone gets it along.
Old 30th September 2008, 21:31   #35
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by v1p3r View Post
Just put some DMS coilovers on the Baleno, and the difference is mindboggling. Of course, the stiffness is now on par with a train, but it's still something else in a corner.
Did you get it from Leela?
Old 1st October 2008, 02:46   #36
v1p3r's Avatar
Thanked: 27 Times
I think Eapen is now onto a diesel of sorts.
No Deep, I didn't buy them new. They were off an unused rally car, but I guess Leela initially imported them. He is the DMS India distributor, AFAIK.
Old 10th October 2008, 14:25   #37
I have seen the DMS setup in the Esteem - costs more than 1.5 lakhs. Good for Rallys but too stiff for street.
No I am not into diesels - but very tempted after driving a Swift Turbo Diesel !
My install is on the hold now because I do not want to cut my stock shock ( I got a free replacement for the right under warranty because it was making noises). I have paid a scrap guy to get me used Baloeno shocks. Its been a month & I am still waiting !
eapen is offline   Reply With Quote
Old 10th October 2008, 17:22   #38
iceman91's Avatar
Thanked: 22 Times
Can get scrap baleno shocks for 2k in shivajinagar
I bought a set 2 weeks ago
Old 10th October 2008, 18:09   #39
Well ice - lucky you. I inquired in Shivajinagar 2 months back & couldn't get it. I have given Rs: 3000 to the guy & he says he'll give it to me by next week.
Old 14th October 2008, 09:15   #40
Default Suspensions for santro
Any possibility to change stok suspensions for Santro
bglrsraj is offline   Reply With Quote
Old 15th October 2008, 13:05   #41
ron_9191's Avatar
Thanked: 98 Times
Hey eapen, I have to say this is a very informative thread. I also have a 2006 Baleno Vxi and I really want to work on this car. Could you tell me how much it worked out for you for the Koni Yellows with the installation please?
ron_9191 is offline   Reply With Quote
Old 25th October 2008, 15:47   #42
Can you tell me if koni's are available for Swift Diesel, specially for the rear.
teefosi is offline   Reply With Quote
Old 14th November 2008, 14:48   #43
Finally had it fixed yesterday at RAC, Koramangala
1. Hold the strut on the wrench, cut & remove the internal damper.
2. Drill a hole in the bottom & fix the Koni's inside by hammering the top body - ring part.
eapen is offline   (1) Thanks Reply With Quote
Old 14th November 2008, 15:00   #44
Finished strut - Hammered inside, bolted from bottom, top covered with rubber sleeve & white plastic ring.
Old 14th November 2008, 19:11   #45
binz's Avatar
Thanked: 412 Times
Looks pretty clean,have you driven on them yet?
Do they still cost 7k each?
Baleno with koni yellows spider77 Modifications & Accessories 4 6th April 2012 09:43
Info required :KONI shocks speedbuster Modifications & Accessories 6 22nd June 2010 13:20
kONI shocks on ZEN sameer_dg Modifications & Accessories 8 26th November 2006 19:27
Gypsy suspension: KONI? COUGAR Modifications & Accessories 7 23rd June 2006 12:25
Please Help..Looking For Koni Sport Dampners In MUMBAI Tool Modifications & Accessories 6 18th May 2006 14:56
