View Poll Results: Does Your Car have ABS
Yes 93 50.27%
No 91 49.19%
Whats that????????? 1 0.54%
Voters: 185. You may not vote on this poll
Old 14th June 2010, 15:11   #76
ElantraGT's Avatar
Year & Make of Car : 2004 Hyundai Elantra GT
Tyres : Stock - Bridgetone 195/65/R15
Discs : All four
Was ABS std/optional : Standard
If Optional for How Much More :
EBD : Yes with Brake Assist & Traction Contrl System
ElantraGT is offline   Reply With Quote
Old 14th June 2010, 15:28   #77
viky_s's Avatar
Year & Make of Car : 2008 Skoda Octavia L&K
Tyres :205/60/R15 Stock
Discs : Front
EBD :Yes
viky_s is offline   Reply With Quote
Old 14th June 2010, 16:57   #78
vc.vinay's Avatar
Thanked: 30 Times
or Copy Pasting
Year & Make of Car :2008 toyota corrolla
Tyres : stock
Discs : all
Was ABS std/optional :STD
If Optional for How Much More :NA
EBD :yes
or Copy Pasting
Year & Make of Car :2008 swift VDI ABS
Tyres : stock
Discs : front
Was ABS std/optional :optional
If Optional for How Much More :20 grands
EBD :dont know
In my corolla i have seen ABS working on a negative side, on high speeds and sudden braking the brake pedal vibrates.i raised this issue with toyota as the car is still under warranty.the engineer from toyota visited my place and after driving the car he told me that it is because of EBD.please guide me if anyone is facing same problem with ABS + EBD.
vc.vinay is offline   Reply With Quote
Old 14th June 2010, 17:22   #79
DWind's Avatar
Thanked: 170 Times
This is normal. Infact, the juddering is to show that ABS is working in your car. This usually happens just before the sensor detects that your wheels are going to lockup and modulates the brake force applied so that you do not lose traction. You can confirm this by trying this in an secluded area by asking another person posted outside to visually look for wheel lock up.
DWind is online now   Reply With Quote
Old 14th June 2010, 18:35   #80
gavinimurthy's Avatar
Hi Vinay
DWind is right. There is nothing to worry. In fact you should worry if you don't feel the vibration in the circumstances you described and the ABS light comes up. That means a malfunctioning of the ABS system and should be attended to ASAP.
Murthy
gavinimurthy is offline   Reply With Quote
Old 24th June 2010, 04:07   #81
Moonraker's Avatar
@Vinay: The juttering is because ABS is working properly and you need not worry about it. When the juttery thing is happening ensure that you are not lifting your feet off the brake pedal or not reducing the pressure you are applying, ABS would do the pump stop for you so that you can concentrate on turning the car from the obstacle.
Moonraker is offline   Reply With Quote
Old 24th June 2010, 06:08   #82
Awaiting Email Confirmation
Thanked: 4,225 Times
I voted for 'Yes' as my Fiat Linea is equipped with ABS.
Year & Make of Car : 2009 October - Fiat Linea 1.4 FIRE Emotion Pack
Tyres : 195/60 R15
Discs : Both Front
EBD : YES
J.Ravi is offline   Reply With Quote
Old 24th June 2010, 08:17   #83
ghodlur's Avatar
Thanked: 2,434 Times
Smile
My Fiesta has the ABS on all variants except the entry level varaint and Limited Editions.
Year & Make of Car : 2009 November - Ford Fiesta 1.6 ZXi (petrol)
Tyres : 175/65 R14 Tubeless
Discs : Only Front
EBD : YES
Go Fida.
ghodlur is online now   Reply With Quote
Old 25th June 2010, 16:30   #84
Thanked: 1,066 Times
Slightly OT:
One of my friends told me that ABS isn't really effective without rear disc brakes as well - and that's it's not really useful having ABS + front disc brakes only. Is this true?
StarrySky is offline   Reply With Quote
Old 25th June 2010, 16:47   #85
vikrantj's Avatar
Thanked: 370 Times
Year & Make of Car : 2010 Fiat Linea
Tyres : 195/60/R15
Discs : front
Was ABS std/optional : std
EBD : yes
vikrantj is offline   Reply With Quote
Old 25th June 2010, 16:55   #86
the truth is that today's disc/drum setups are completely adequate for the majority of new cars. Remember that both disc and drum brake design has been vastly improved in the last 20 years. In fact, the current rear drum brake systems on today's cars would provide better stopping performance then the front disc setups of the '70s. And today's front disc brakes are truly exceptional in terms of stopping power. Combined with the fact that between 60 and 90 percent of a vehicle's stopping power comes from the front wheels, it's clear that a well-designed, modern drum brake is all that's required for most rear wheel brake duty.
Brakes: Drum vs. Disc
ABS is nothing but automatic pumping. Pumping much more efficiently than a human can do. My SX4 has front disc (ventilated) and rare drum brakes. The surer stopping even at high speeds is to be seen to be believed.
I am afraid your friend is wrong. :-)
Murthy
Would you like to have ABS and Airbags sreenivass The Indian Car Scene 253 4th July 2012 11:40
"Mobile Court" have you been there, i have! xinome Street Experiences 24 2nd August 2007 17:39
Can you get car back even if you have taken insurance claim? udit78 The Indian Car Scene 8 6th February 2007 13:58
What do you know about the places you have visited? DRC Route / Travel Queries 4 23rd August 2006 14:49
