Old 27th October 2007, 21:14   #16
I have Kiran's email Id. I had enquired and have received some material about the Eureka kit from him. Not sure whether I'm allowed to post it on the forum.
Nish75 is offline   Reply With Quote
Old 28th October 2007, 20:04   #17
Sankar's Avatar
Thanked: 4,655 Times
Why not?
I would like to have his email id. Could you send it to me as pm?
Old 28th October 2007, 20:30   #18
Kiran's (AutoEscorts) Mail Id: kiran.bhide@rediffmail.com you can also try autoescorts@rediffmail.com . I received quick response from Kiran's ID.
He has quoted 3.5K for M800 (Replaces CB points, ignition Coils etc.) and there is another one which replaces only the CB points quoted for 1.5K.
Will PM you the documents I received.
Old 23rd May 2008, 12:31   #19
Originally Posted by dkamath View Post
Hi guys, came across an ad some time back, in the mags, about a Co. that claims to have developed an electronic ignition for carburetted Maruti 800 (the Co. name goes by 'Eureka' or so). The system, they say, would enhance the performance of the car, also providing fail-safe service.
My question: Do any of you have an idea on this? Please comment.
Dear Friend,
Hello, I am Kiran Bhide from Autoescorts, Mumbai. We make electronic ignition conversion kits for Carburetor type cars you are looking for.
Our contact nos. are 28321645/ 65783949 or 9820914008.
Thank you.
With best regards,
For Autoescorts.
Kiran Bhide.
kbhide4 is offline   Reply With Quote
Old 23rd May 2008, 13:13   #20
sumeethaldankar's Avatar
Thanked: 1,160 Times
Originally Posted by kbhide4 View Post
Dear Friend,
Thank you.
With best regards,
For Autoescorts.
Kiran Bhide.
Hi Kiran ,
I have a Carb 800.Can you tell me the benefits of converting to a electronic ignition
sumeethaldankar is offline   Reply With Quote
Old 31st January 2009, 20:45   #21
HIGHNOON's Avatar
Thanked: 56 Times
Originally Posted by sumeethaldankar View Post
Hi Kiran ,
sorry its a rather late reply.
But had done this on my old carb 800. Well there was some improvement in FE , a marginal increase in power and smoothness but the most important thing is that even if you drive thru a little poodle on the rod and splash water on the coil , point condenser , the engine would not sputter and die on you.
i had put a single point one but i guess multi point after market sets are available.
HIGHNOON is offline   Reply With Quote
Old 31st January 2009, 20:48   #22
HIGHNOON's Avatar
Thanked: 56 Times
Hi Kiran ,
Having said that you can even put booster brake kit in your car. Spectra motors used to sell the KBX setup thru their retail outlet ( now closed ). I had installed one in my 800 , the assisted brakes made life a lot easier.
It ought to be primary safety requirement of any vehicle !
Old 1st February 2009, 13:40   #23
km120's Avatar
I have got KBX Brake Booster installed in my M800. It is working perfect. I recommend it to all of those who would consider improving braking efficiency.
km120 is offline   Reply With Quote
Old 3rd February 2009, 10:35   #24
Shashank.A's Avatar
Is this specific to carb 800 or other carb cars can benefit from it too ?
Shashank.A is offline   Reply With Quote
Old 4th February 2009, 11:01   #25
HIGHNOON's Avatar
Thanked: 56 Times
Thumbs up
Hi Shashank,
I believe it can be used for any carb. car. If u sift thru one of the car magazines you may even find a dealer for the same in delhi.
We are discussing 800 here as the question was pertaining to it.
Afterfitment of power steering , boosted brakes kits and electronic ignition to older gen. of vehicles is very much possible.
Only one has to take trouble to find a right vendor to procure stuff from and right technician to modify.
Kedar
Old 30th November 2009, 17:30   #26
dr.faramroze's Avatar
Thanked: 13 Times
Dear Friends,
I got my last Maruti 800 fitted with Eureka Magnetic Pulse Proximity Sensing MPPS ignition system from Kiran Bhide, Auto Escorts, Mumbai. I have my car in prestine condition, with no issues of fuel consumption, pickup etc. After I got the kit installed, there is a whooping 30% increase in throttle response. I use the car mostly on highways, always wondered about retrofitting an ECU, but now, I am happy with this fitment. The kit consists of transistorised modules, a magnetic pickup, and a series of induction coils and offcourse the NGK platinum spark plugs. It took 50 minutes to install, his guy came to my home in Mumbai and did a decent job. It costed me Rs 3200 + Rs 600 for the spark plugs. Installed it on Saturday. Drove it till Ahmedabad the next day. The main point is this kit improves engine efficiency to stock conditioned cars also.
dr.faramroze is offline   Reply With Quote
Understanding Electronic Distributorless Ignition System (EDIS) dar3dev|l Technical Stuff 3 16th February 2010 12:31
Engine Overhaul - Maruti 800 ( 1999 - Carb ) hitman1980 Technical Stuff 21 17th November 2009 14:27
Maintenance cost - Maruti 800 Carb and MPFI models vinfriend Technical Stuff 9 17th November 2009 12:16
Carb for first model Maruti 800 Rudra Sen Shifting gears 22 10th August 2004 01:51
