Closed Thread
Old 11th October 2007, 18:36   #1
Default GEAR shift pattern - is this right?
The MATIZ manual says 1 gear upto 20 KMPH . 2nd gear 20 to 40. 3rd gear 40-50 . 4th gear 50-60 . 5th gear 60km upwards. How right is this. is this appropriate for getting better FE in city & HIghways. opinion invited. TIA
shapath is offline
Old 11th October 2007, 18:44   #2
nitroxx's Avatar
Thanked: 26 Times
shapath, really dont worry about the speedometer, just shift between 2k-2.5k rpm range to get best mileage.
nitroxx is offline
Old 11th October 2007, 18:46   #3
Jay
Jay's Avatar
You can shift gears at lower speeds too depending on the road, the above mentioned speeds for each gear can be considered for a good FE.
Jay is offline
Old 11th October 2007, 18:57   #4
Akshay1234's Avatar
Thanked: 7,242 Times
i doubt the matiz would have a tacho.
Akshay1234 is online now
Old 11th October 2007, 19:03   #5
NO. Matiz donot have TACHO.
shapath is offline
Old 11th October 2007, 19:49   #6
shapath, the best compromise between performance and mileage is to shift up at 15-30-45-60 for 2-3-4-5.
hrag is offline
Old 11th October 2007, 22:22   #7
nitroxx's Avatar
Thanked: 26 Times
oh damn i forgot there were cars that didnt have a tacho ..sorry! hmm then follow the other route! cheers!
nitroxx is offline
Old 12th October 2007, 13:21   #8
Rehaan's Avatar
Thanked: 25,040 Times
Hi Shapath,
This has been discussed MANNNY times before. Please do search around the Technical Stuff section a bit.
Heres one such thread to get you started >
http://www.team-bhp.com/forum/techni...ar-shifts.html (The right Gear shifts?)
cya
R
Rehaan is offline
Closed Thread
Cable Shift vs Direct Shift Gearboxes BlackPearl Technical Stuff 14 15th September 2013 13:35
Does the fuel price hike affect your driving pattern? GTO The Indian Car Scene 144 2nd June 2012 08:38
Gear levers - Shifting pattern, positioning ashwanth Technical Stuff 4 8th August 2008 12:29
