Old 13th October 2007, 11:06   #1
Thanked: 245 Times
Exclamation How to test for a failed Engine Head Gasket
A head gasket is the coupler between the engine block and cylinder head in an internal combustion engine. Its purpose is to seal the cylinders to ensure maximum compression and avoid leakage of coolant or engine oil into the cylinders as such, it is the most critical sealing application in any engine, and as part of the combustion chamber, it shares the same strength requirements as other combustion chamber components.
Types of Head gaskets
Effects of a failed or "blown" head gasket
The failure of the head gasket will lead to overheating problems, boiling up and pressurisation of the cooling system that can lead to the failure of the radiator, hoses or even the coolant bottle can explode, Oil and water contamination, crack can appear within the cylinder head, poor performance, uneven running and eventual catastrophic engine failure if used for a prolonged period on overheated temperatures.
A damaged head gasket
What are the tell tale signs?
By following this procedure you should be able to identify a failed head gasket:
1. Open the bonnet and with the engine cold check the coolant level and colour. It should be at the normal level and the coolant should be either clear or green coloured, it should still be clean and clear, the interior of the coolant bottle or radiator should also be clean without any signs of a soapy thick creamy deposit. If there is a thick creamy scum then this is a good indication of water and oil contamination and the most common cause is head gasket failure or a cracked cylinder head. If all is as it should be move onto check 2.
2. Take out the oil dipstick, and look at the oil attached to it it should be clear or black, if it is a creamy colour then this indicates that water has mixed with the oil and the most common cause is a failed head gasket or crack in the cylinder head. If the oil is clear or black move onto check 3.
3. Remove the cap to the coolant bottle and start the engine, allow the engine to run up to normal temperature watching that the level remains contant and is rotating as it should, replace the cap to the coolant bottle and leave the engine running, if the vehicle is fitted with an electric cooling fan allow it to cycle on and off on its own and make regular check on the temperature guage, it should sit at normal. Switch the interior heater to hot and turn ON the fan, the heater should blow warm or hot. If after running at normal temperature for 10 mins the guage has stayed at normal, the cooling fan has cycled on and off properly and the interior heater is still blowing hot on demand turn off the engine, goto check 4.
4. Allow the engine to rest for a couple of mins, then with great care and while wearing something to protect you from the heat try sqeezing the top hose from the radiator, if the hose is solid then leave a little longer until you can squeeze it a little then slowly remove the cap to the coolant bottle or radiator. If the gasket or cylinder head has failed there will be a great gushing of boiling water so you must do this carefully. Stand well back and release the pressure slowly, if there is no great gush or just a slight hiss, like opening a soda bottle, it is OK but do not be tempted to dip your finger in it it is still very hot. Now check the oil again and the coolant for clarity if the oil is clear and not creamy coloured and the water is clear and the engine temperature is stable and normal then the likelyhood is that, everything head gasket wise is OK.
The short version (to detect problem)
If the oil is creamy coloured and there are soap like deposits.
If the car over heats for no apparant reason.
If the water is contaminated with oil or a soapy substance.
If the cooling system pressurises abnormally.
Can it be repaired ??
The short answer is yes, but this is not a cheap job, it should be done by an authorised service provider.
The repair will usually involve the purchase of a gasket kit and cylinder head bolts as these are made to stretch and should only be torqued down once.
A replacement head gasket sitting loosely on top of a four cylinder engine block
The cylinder head will need to be sent to a specialist for pressure testing and scanning to take out any warps caused by the excessive temperatures.
If the head has cracked then a replacement head is also required.
Sources: Wiki/Internet
dadu is offline   (3) Thanks Reply With Quote
Old 13th October 2007, 11:10   #2
Gordon's Avatar
Thanked: 197 Times
I've always wondered what a gasket is and its purpose?!
This article has answered the question and more.
Gordon is online now   Reply With Quote
Old 13th October 2007, 11:10   #3
theMAG's Avatar
Thanked: 1,572 Times
Nice compilation. Very helpful, no doubt.
Old 13th October 2007, 11:20   #4
1self's Avatar
Thanked: 270 Times
Hey dadu!
great write-up man! good to know these things....can be a life & money saver some day!!
1self is offline   Reply With Quote
Old 13th October 2007, 11:26   #5
this is an awesome article..... i love it.. thanks for posting it.
bmdesai1987 is offline   Reply With Quote
Old 13th October 2007, 12:08   #6
sushrutha's Avatar
Thanked: 325 Times
Very nice compilation indeed.. THanks DADU...
Old 13th October 2007, 15:02   #7
toiingg's Avatar
Thanked: 83 Times
This should go under the 'Best Threads' section.
Great compilation.
toiingg is online now   Reply With Quote
Old 13th October 2007, 15:11   #8
BUSA's Avatar
Nice compilation Dadu.
I know why you started this thread, to help people understand more about the Safari 2.2 with blown headgaskets.
Old 13th October 2007, 19:27   #9
Thanked: 245 Times
Thanks everyone.
Yes, that was my inspiration and in order to understand it better I had to read about it too.
Old 14th October 2007, 08:57   #10
Thanked: 253 Times
Great job Dadu. Will help a lot of hands-on type of people who would otherwise have had to go to the friendly neighbourhood mechanic.
Old 15th October 2007, 12:01   #11
bruty's Avatar
Till the time i read this thread, i was Greak for me. It is indeed an eye opener for me. Good job.
bruty is offline   Reply With Quote
Old 15th October 2007, 12:24   #12
hkanitkar's Avatar
Thanked: 30 Times
@dadu - nice article ! Informative, technical and yet simple to understand.
Thanks a lot !
btw, is there any criteria to replace the gasket ( like the oil/fuel filters ), as in after say 50k kms or such ??
hkanitkar is offline   Reply With Quote
Old 15th October 2007, 12:29   #13
Thanked: 245 Times
No..never, unless it shows signs of leakage or during overhauls.
Old 15th October 2007, 14:00   #14
sbasak's Avatar
Excellent writeup!
This is another reason why we need a temperature gauge in the dash.
Some cars are now giving up provide one for the sake of cost. A overheat-warning light doesn't gradually indicate a problem of overheating.
sbasak is offline   Reply With Quote
Old 15th October 2007, 14:20   #15
headers's Avatar
Thanked: 464 Times
Thats a good write up...
The best way and the affirmative view is the mixing of water in the engine oil compartment.
Also..in some vehicles..the engine sound changes .. with increase in temperature.
But I do not agree with your final point #4.
Do I need to change the head gasket? archat68 Technical Stuff 44 30th August 2017 15:54
Head gasket, does it have a service interval ramkris Technical Stuff 13 28th February 2015 14:00
piston rings - how do i know? (head gasket change as well) silver_shadow Technical Stuff 27 27th October 2008 21:43
cylinder head gasket & tensioner bearing in 2k1 ikon 1.6? silver_shadow Technical Stuff 7 10th October 2008 16:08
