Old 16th October 2007, 16:27   #16
1self's Avatar
Thanked: 270 Times
Originally Posted by lordofgondor View Post
I did a visual inspection of the belts while the engine was off and also while it was running. Both of them seemed ok with the right amount of tension and no flexing. Please pardon my ignorance, but what's these belts got to do with engine oil leaking anyway?
if the water pump is not effectively circulating water...your engine is bound to overheat...hence the query.
1self is offline   Reply With Quote
Old 16th October 2007, 19:03   #17
Spitfire's Avatar
Thanked: 707 Times
If you have clocked more then 1Lakh kilometers, then it needs a overhaul. Does the engine heat up? and do you see white smoke coming from the engine bay?
Spitfire is offline   Reply With Quote
Old 17th October 2007, 00:00   #18
nitrous's Avatar
Thanked: 285 Times
Not necessarily. I would suggest checking engine compression to see if its healthy.
Old 17th October 2007, 02:15   #19
rohan_fonseca's Avatar
Better to post some pics for us to judge wether leak is from crankcase or valve cover.
rohan_fonseca is offline   Reply With Quote
How to Clean the Engine Bay ? mithun Technical Stuff 48 23rd August 2017 10:45
Please help - Humming noise from engine bay abhaybakshi Technical Stuff 7 19th September 2009 10:36
Sai services (mumbai) leaves a hammer in my engine bay!! samrat25 Indian Car Dealerships 14 2nd August 2008 23:25
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
