Old 19th October 2007, 03:36   #16
Shan2nu's Avatar
Thanked: 89 Times
I understand that the tc not only brakes the wheels but does other things as well but how are electronic stability control and traction control different.
Traction control is generally limited to the driving wheels and works effectively under acceleration. When a car begins to oversteer or understeer due to acc, the TCS applies braking force and/or reduces power supply to the driving wheel that has lost traction.
Stability control uses ABS and TCS technology along with Active Yaw Control, to keep the vehicle from spinning out due to either deceleration or acceleration.
SC calculates your steering angle wrt to the turning angle of the car and if it finds a mismatch between the two, it'l start applying braking force not only to the driving wheel but to each individual wheel that needs to be kept under check.
Here's Tiff Needell showing us the diff between ABS, TCS and ESP (Stability Control) -
Shan2nu
Old 20th October 2007, 02:20   #17
paras211's Avatar
Thanked: 57 Times
wow never new tc and esp are so helpful.
my 12lac corolla dont even have abs. sheeshh . rip offf
paras211 is offline   Reply With Quote
Traction control explained vikrantj Road Safety 28 9th October 2017 10:53
Spotted! Ford F-Series Pickup being used for Tyre Traction Testing mr_hardcore Super-Cars & Imports in India 8 1st April 2017 11:18
Minardi suspects Vettel's car has Traction Control D33-PAC Int'l Motorsport 46 8th April 2014 15:22
A Device that can control all my gadgets / Universal Remote Control a4_attitude Gadgets, Computers & Software 28 24th August 2011 11:10
Can the functionality of ABS be simulated on Non-ABS cars? abhinav.s Technical Stuff 54 24th February 2010 14:51
