Closed Thread
Old 18th October 2007, 17:45   #1
Default WagonR Gear
Hi all,
Planning on getting a new car this month. Had almost finalised on WagonR till i read the reviews about the issues with the gear.How severe is the issue? Also does the 2007 models have the issue?
Is it true that the issue persists only in the beginning but later works fine?
Is this coz the driver gets used to the issues with the gear?
Kibi
kibi is offline
Old 18th October 2007, 17:57   #2
DCEite's Avatar
Thanked: 607 Times
This issue has been discussed several times in the past. Search around the forums and you will get your answer.
Thread Closed.
DCEite is offline
Closed Thread
Maruti WagonR over Hyundai Eon? EDIT : Bought WagonR with ABS / Airbags BoneCollector Hatchbacks 35 22nd May 2015 11:49
Only a WagonR can replace a WagonR ! From F10D to K10B.. DCEite Test-Drives & Initial Ownership Reports 27 19th April 2014 23:02
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
WagonR or Swift?(calling swift and wagonR owners) rajshenoy Hatchbacks 43 29th March 2007 09:54
