Old 21st October 2007, 04:17   #1
Default need help : swift service
i dont understand or know any thing of :
Valve clearance
cam shaft timing belt
Positive crank case ventilation
drive shaft boot
also
AIR CONDITIONER (If equipped)
12-4. Check func tioning of Recirc flap
12-5. Clean condensor with low pressure water
{good AC service centers in mumbai [clean & disinfect] }
highly appreciate any help
got this from the swift manual
thanks guys
PS
Valve adjustment very important
cyneverdie is offline   Reply With Quote
Old 21st October 2007, 04:41   #2
nitrous's Avatar
Thanked: 285 Times
Valve clearance
drive shaft boot
U dont need to know anything about these for the swift first few services.
When U give all the advice in the Oil-section, I thought U've been marinated in cars for quite sometime with all ur confident statements.
thanks guys
PS
Again, Valve adjustment? Why?
Old 21st October 2007, 04:53   #3
Well ;; ,
valve adjustment AND Positive crank inspection at 5000 & 20 000
cam shaft timing inspection at 20 000
drive shaft boot damage inspection at 5000 10 000 & 20 000
I am at 15000 km on a hard driven swift gonna do an early needed service
next YOU do your homework before YOU post
oil is very important to me i did my homework before those "confident" posts
peace
nitro
cy
Old 21st October 2007, 05:03   #4
nitrous's Avatar
Thanked: 285 Times
So, U read ur service manual thoroughly.
Old 21st October 2007, 05:55   #5
i read every manual i own throughly from my microwave oven to my PC' s RAM
are you trying to imply something man>? cause i dont get it
Old 21st October 2007, 23:52   #6
wolfinstein's Avatar
Valve clearence is adjusting the In-Out Valve for each cylinder, Valves are located above the head and control the Intake-Exhaust cycle for the Piston Chamber. Usually does not need adjustement, unless you notice lot of noise from the tappet, Carbon fouling of Plugs.
Air Re-circulation flap, controlled by the Circulation switch-functions to close outside air-vents and use Air from the Internal Vents. Unless you smell smoke or outside air-No adjustement needed.
About others No clue, but would like to know more.
wolfinstein is offline   Reply With Quote
My Mercedes, My Service - Digital interactions, fast service and service plans up to 200,000 km dZired The Indian Car Scene 3 20th July 2016 16:05
Sai Service Ripoff! Rs. 18,000 for service of Swift (22K kms) UPDATE: Excess refunded AkMar Indian Car Dealerships 158 8th January 2016 18:58
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 4 26th October 2009 22:28
Need Help with Motorcycle Service network AntarAtma Motorbikes 6 26th March 2007 19:50
New Honda City - Need help on choice of Dealer/ Service Station msprabhakar The Indian Car Scene 13 13th June 2005 16:49
