Old 23rd October 2007, 09:06   #31
Thanked: 35 Times
There is a technique used in bike jumps, where if you rev the bike in free air - it pitches upward(font tyres lift up) and if you brake in free air it pitches down(front tyres point down). Now when the bike is landing, the front tyres must hit the ground first(the down ramp is a decline) and hence the biker would lean forward + brake to angle his bike with the decline.
Its possible that this applies to cars as well. I'll do a little research on that and let you know. So after the safari took off the front wheels were obviously pointing up and the driver braked(tapped the brake) to get it to point a little down. At this time the rear wheels still had the drive(or the accel was still being pressed) and hence it was merely slowing down whereas the front wheel stopped immediately due to lack of drive.
Question: How does the differential work exactly(LSD, 4L. 4H etc) I wonder if the moment the front wheel took off, the differential locked the front wheels(as it started slipping) and supplied all power to the rear wheels. When the front wheel landed, it would have again started to give the power to the front wheel. Will any differential mode work in this way?
herculesksp is offline   Reply With Quote
Old 23rd October 2007, 09:36   #32
Thanked: 35 Times
To prove that this is not a gimmick and there is a technique/explanation to this.
OT: (Watch the guy at the back of the truck.)
Old 23rd October 2007, 10:21   #33
Venkatesh.C's Avatar
Thanked: 30 Times
@herecules good find. the jeep had its front wheels locked in its short flight. Same about this one. Chekc it out
Maybe its a technique like many of you have pointed out or it is the differential doing its thingy.
Venkatesh.C is offline   Reply With Quote
Old 23rd October 2007, 10:21   #34
Thanked: 244 Times
We will still enjoy the jump with your SX4, provided you are prepared for a chasis replacement as was the case with the adv of earlier petrol safari, mangled and broken chasis.
Originally Posted by Venkatesh.C View Post
Wish I had a safari dude.
Old 23rd October 2007, 20:43   #35
1100D's Avatar
Thanked: 2,360 Times
This is why I love this forum so much.
All this time we said so manythings about this, but no one, including me, thought in the direction of "Limited Slip Differential".
1100D is offline   Reply With Quote
Old 25th October 2007, 18:04   #36
Thanked: 35 Times
So, was I thinking in the right direction or not?
Old 26th October 2007, 09:05   #37
Proxima's Avatar
Does anyone have a mp3 version of the soundtrack of this Safari ad? (or even the previous ones?)
Proxima is offline   Reply With Quote
Old 26th October 2007, 11:36   #38
tsk1979's Avatar
Thanked: 15,648 Times
Try hunting for the soundtrack of "Requiem for a Dream"
Old 26th October 2007, 12:53   #39
arunphilip's Avatar
Thanked: 4,700 Times
As tsk mentioned, its from the OST of Requiem for a Dream, and is called Lux Aeterna (Eternal Light). Haunting.
arunphilip is offline   Reply With Quote
Front Wheel Drive v/s Rear Wheel Drive Revvhead Technical Stuff 269 3rd August 2017 15:48
Rear wheel drive or Front wheel drive : What is your choice ? adrian Technical Stuff 1 25th January 2010 16:26
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
