Old 31st July 2011, 01:28   #151
speedsatya's Avatar
Thanked: 712 Times
Default Re: Using HID lamps on cars with Halogen bulbs
Wow !! Thanks so much
I enquired with the local Philips dealer in Bangalore and he was mentioning around 8.5 K for a Philips 6000K/35 W HID kit.
But on Amazon,I did find something similar for around 80 USD.
Now for the next set of questions :
1- Are these HID kits universal ones? or is it specific to a type of manufacturer ?
If yes,I can order something online in the US and get in here .
2- On getting the headlights aligned ,my question is " will the HID give me a noticeable difference in night driving over the 100/90 W that I use now ".I am more than happy with the 100/90 W bulbs that I have now?
speedsatya is offline   Reply With Quote
Old 31st July 2011, 10:46   #152
rahuldevnath's Avatar
Thanked: 51 Times
Smile Re: Using HID lamps on cars with Halogen bulbs
(1) HID kits are universal. There are different holder types, like H1, H4, H7 etc. So, if your car has a H1 type Halogen, any HID of H1 type will fit. Just for some background info; most of older generation cars will have H4 as bulb type. Because H4 uses a single bulb for Hi/Lo operations compared to say H7, which is a single bulb. My vista has vertical stacked headlight, with low beam using H7 and Hi beam making using of H1. So be sure of your vehicle bulb type before ordering. Only the bulbs are different rest of the HID kits remains same.
I have installed "P8" brand 6000K in my car, and "Raylux" brand 4200K in my bike. Although I was searching for 4200K for my car (non availability in Nagpur). There are various brands, apart from "Philips", I can vouch for "P8" and "Raylux". If you are ordering online, be sure about warranty, as there are chances of HIDs getting kaput in initial usage.
(2) There will definitely be an improvement over 100/90 Halogen bulbs, as HID lights are much more penetrating. However depending on your usage, a 100/90 might just suffice your needs. But yes, a 35W HID will run much cooler than 100/90 Halogen and also consume less power. I have seen people running 6 HIDs commonly. (2 Fog + 2 low + 2 High). Something which will be light years ahead of Halogen
BTW if you are happy with your current bulbs, any particular reason to move to HID?
rahuldevnath is offline   (1) Thanks Reply With Quote
Old 1st August 2011, 09:46   #153
Arun Rangamani's Avatar
Default Xenon Lamps for Cedia
I had fitted xenon lamps for my Cedia and it is much better night driving now. The HID lamps are from Osram and there is a 1 yr warranty for this lamp which costed me 9k total.
The interesting aspect I found out during this purchase was the wide variety of options available in terms of price - starting from 6k to 15k, and it takes only 15 to 30 mins to replace the original lamp.
I would like to know if any of you have fitted xenon lamps and any warnings for longevity of the lamps etc.
Arun Rangamani is offline   Reply With Quote
Old 1st August 2011, 10:47   #154
naveen.raju's Avatar
Thanked: 3,726 Times
Default Re: Xenon Lamps for Cedia
How about some pics? It would help others a lot. I have been using HID's with projectors in my Swift for more than 1.5 years. Better throw/visibility and long life. Have to check whether replacement HIDs will be available. Most of the shops sell HIDs as complete kits. There are many online shops offering replacement HIDs though.
naveen.raju is offline   Reply With Quote
Old 1st August 2011, 11:01   #155
Akshay1234's Avatar
Thanked: 7,242 Times
They will last very long. Just make sure not to flash in the day, because the lights will be off and putting the light on and off strains it a lot. In the night your lights will be on anyway so flashing is fine then.
Old 1st August 2011, 11:02   #156
akshay4587's Avatar
Thanked: 1,686 Times
A HID kit has a bulb,a Ballast and a wiring harness.
what is the difference between a normal HID kit,and a replacment kit
Old 1st August 2011, 11:09   #157
MAS
MAS's Avatar
Thanked: 1,211 Times
Did you get them at GP road? Osram is a good choice.
How is the light beam? My experience with HID without projector headlamps is that there is not much increase of light on the road as the focus is missing (due to different length of the Halogen and the HID), but blinds the oncoming traffic.
HID's will last a long time and depends on how you use them. As Askhay has put it, if you flash them very often, then there is a fair chance that they get burned out.
MAS is offline   Reply With Quote
Old 1st August 2011, 12:26   #158
noidaboy's Avatar
Thanked: 260 Times
Just hold the dipper for 3 seconds in the day time when ever you need a pass, It works fine. Give it time to warm up thats the only thing. Multiple or sudden flashing might take away little life but that entirely depending on the quality of the kit
noidaboy is offline   Reply With Quote
Old 1st August 2011, 12:31   #159
I will take some pics and post it shortly. Thanks Navin
Old 1st August 2011, 12:38   #160
mayankk's Avatar
Thanked: 3,559 Times
That would be just the bulb bit.
There's loads of sites offering just the bulb, and so far the best deal.
I met with one dealer who said the whole kit is 7k.
how much for just the bulbs?
5 k.
"So, without bulb just give the ballast and assortments, for 2k?"
no sir, that is 4k.
not going back THERE, at least.
mayankk is offline   Reply With Quote
Old 1st August 2011, 12:52   #161
It's a replacement bulb and not a kit. The bulb alone should cost around 2.5k. Have seen them in many online sites.
No dude. I got it from Cochin. It's Auto Gauge HID's. I got the entire kit for 7.5k.
I find it very good since I use projectors. I had used different configurations before
1) OEM Swift lights
2) Osram Cool Blue 90/100w
3) Philips 90/100w with projectors
4) Auto Gauge 4300k HIDs with projectors - Now
I find the present configuration to be the best. I do flash the bulbs during day at times to warn the blind overtakes by oncoming cars but so far it's been good. Been using it for more than 1.5 years.
Old 1st August 2011, 12:53   #162
akshay4587's Avatar
5 k.
no sir, that is 4k.
ahh ok.
Anyways,i found a source,for that.
Recently purchased a 35W 4300K Bulb for 1K,it comes with 1 year warranty.
akshay4587 is offline   (1) Thanks Reply With Quote
Old 1st August 2011, 17:36   #163
Default Re: HID Xenon
I had taken the photo of the car with the lights on. But I think the question was to get pics of the bulb. Regardless, the picture is loaded.
Old 1st August 2011, 18:23   #164
Thanked: 51 Times
I had previously replaced my H7 kit's bulbs as I wanted 4200k compared to the the default 6000k. after looking for some branded bulbs, I took the plunge and bought a pair of chineese make bulb for 1600 bucks (2 bulbs). 1 year warranty. It has been more than 2 years and they work fine.
rahuldevnath is offline   Reply With Quote
Old 2nd August 2011, 13:18   #165
rajanprash's Avatar
Thanked: 35 Times
My cousin has a Leuci HID kit for nearly 2 years now.6 months before , the relay started malfunctioning ( Only low beam , No high beam ).
The relay controlling the Hi-Lo control magnet was malfunctioning and unable to use high beam.
Visited some dealers , and all of them said that the entire kit has to be changed and there is no other option , a relay cannot be purchased separately as it is integrated with the wiring harness.
Lost all hopes and as a last option , ordered a wiring harness from eBay Singapore. Installed the wiring harness and everything started working fine . No problems at all after that.
AFAIK If the Hi beam is flashed frequently , the relay gets damaged and not the HID bulbs or the ballast ( personal experience in this case ).
rajanprash is offline   Reply With Quote
Best Xenon HID conversion kit venkatrx Modifications & Accessories 392 21st February 2018 10:35
HID Xenon fog / driving lamps for OHC gbpscars Modifications & Accessories 4 17th October 2008 11:14
HID/xenon for 2005 model CR-V absynthguzzler Modifications & Accessories 2 23rd September 2008 21:36
For Sale: German H7 HID xenon kit gbpscars Shifting gears 2 13th September 2007 16:00
Help me out with XENON / HID lights fb1 Modifications & Accessories 16 19th May 2007 02:55
