Old 23rd October 2007, 23:34   #1
razor4077's Avatar
Thanked: 258 Times
Default Power window problems in Lancer
Couldn't find an appropriate thread to add to, so creating a new one.
@Mods: if you think otherwise, pls move it to the right place.
The power window controls in my Lancer are acting weird. Here's the situation:
With "Lock other controls" button off:
- Driver's window controls are working fine
- Right rear: up/down ok
- Left front & rear: up not working, down ok
With "Lock other controls" button on:
- Driver's window up/down: ok
- Cannot operate other windows from driver's console
- Other window switches non-operational (this is ok).
Any clue what the problem could be? Could this be a wiring issue, and more importantly, can it be repaired?
Can loose connections be the culprit (haven't checked yet)?
Any help is appreciated. Thanks.
razor4077 is offline   Reply With Quote
Old 24th October 2007, 01:11   #2
1100D's Avatar
Thanked: 2,503 Times
Wiring issue.
If I am not mistaken, You have completely new buttons and the wiring has been newly done.Thats where it gets messed up.
The parallel inputs to each left window (to operate from drivers console) seems to be missed out.
The "lock other control" switch should be up stream of the junction of the individual window wires only (not the drivers control as well).
In other words its just circuitry, your switches seem to be working fine.
HM workshop may come in handy.
However all these connections are plug type, so if you have OEM connectors and the right switches, the problems should not arise at all.
1100D is offline   Reply With Quote
Old 24th October 2007, 11:34   #3
razor4077's Avatar
Thanked: 258 Times
Nah, the switches and wiring are OE... didn't change them. They were taken out during the overhauling, so am guessing they didn't get the wiring right while refitting. Somehow this problem never cropped up before, so wasn't aware of it.
Will try getting it resolved at the local workshop before taking it to HM (I'm allergic to HM workshops )
Old 24th October 2007, 17:13   #4
spadival's Avatar
Thanked: 16 Times
OT: While you are at it, make sure the cigarette lighter terminals have the +/-ve connected correctly.. cigarette lighter itself will work fine even if the terminals are inverted.. but any any attempt to use the charger, the fuse will blow..
Mechanics are the worst electricians !!
spadival is offline   Reply With Quote
Old 25th October 2007, 00:39   #5
razor4077's Avatar
Thanked: 258 Times
Good point... will check that out. Thanks for the tip!
Old 25th October 2007, 01:40   #6
Sideways's Avatar
Thanked: 18 Times
Hi Abhishek,
Checked in my car today
- Left front & rear: up & Down when operated from drivers & individual doors should work
- Cannot operate other windows from driver's console - THIS IS OK
Should be a wiring issue and can be sorted.
OT: Does the ORVM control pad light up when the park lights are switched on, i.e. is the control pad backlit ? Have a doubt and want to clarify. Thanx
Sideways is offline   Reply With Quote
Old 25th October 2007, 02:52   #7
razor4077's Avatar
Thanked: 258 Times
Really? Hmm... works differently in other cars, doesn't it? I thought the purpose of having that lock button is to prevent the passengers from operating the windows, while allowing the driver to do so. Guess it's different in Lancers...
I don't think the ORVM control pad is backlit. Will verify tomorrow.
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Old Honda City VTEC - Power window repair gbpscars Technical Stuff 21 27th August 2011 13:05
Power Window Problem -Santro harish_K Technical Stuff 7 14th December 2009 11:18
Power window doesn't come up! Why? Deeps Technical Stuff 3 10th April 2006 17:27
Need Info: Sunfilm/SeatCover/Power Window/Fog Lamp souravbasu Modifications & Accessories 3 3rd April 2006 10:53
